查看: 10615|回復: 9
proteus8.10仿真stm32控制舵機程序(pwm舵機)
       本貼使用Proteus8.10,如低版本打不開可自行根據原理圖繪制(很簡單)
單片機型號為:stm32f103系列
運行穩定,舵機角度自行更改程序中的pwm輸出函數值即可。
   案例中只做了一個,按鍵按下舵機轉動,實際測試過timer2-4的通道0-3,共12路pwm。
       如有問題,評論區留言,看到回~
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. #define LED0 PCout(2)
  7. #define KEY0  GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_5)                                                 //讀取按鍵0
  8. #define KEY1  GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_15)                                               //讀取按鍵1
  9. #define WK_UP GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0)
  10. void KEY_Init(void)
  11. {
  12.
  13.         GPIO_InitTypeDef GPIO_InitStructure;
  14.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,ENABLE);  //使能PORTA,PORTC時鐘
  15.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);                               //關閉jtag使能SWD,可以用SWD模式調試
  16.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_15;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                    //設置成上拉輸入
  18.          GPIO_Init(GPIOA, &GPIO_InitStructure);        //初始化GPIOA15
  19.
  20.         GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_5;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                   //設置成上拉輸入
  22.          GPIO_Init(GPIOC, &GPIO_InitStructure);        //初始化GPIOC5
  23.                 GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0;
  24.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
  25.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  26.
  27. }
  28. void LED_Init(void)
  29. {
  30. GPIO_InitTypeDef  GPIO_InitStructure;
  31. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);          //使能PA,PD端口時鐘
  32. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;                                   //LED0-->PA.8 端口配置
  33. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                   //推挽輸出
  34. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                  //IO口速度為50MHz
  35. GPIO_Init(GPIOC, &GPIO_InitStructure);                                        //根據設定參數初始化GPIOA.8
  36. GPIO_SetBits(GPIOC,GPIO_Pin_2);                                                //PA.8 輸出高
  37. }
  38. void TIM1_PWM_Init(u16 arr,u16 psc)
  39. {
  40.          GPIO_InitTypeDef GPIO_InitStructure;
  41.         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  42.         TIM_OCInitTypeDef  TIM_OCInitStructure;
  43.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  44.          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);             //使能GPIO外設時鐘使能
  45.
  46.    //設置該引腳為復用輸出功能,輸出TIM1 CH1的PWM脈沖波形
  47.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;                                      //TIM_CH1
  48.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                        //復用推挽輸出
  49.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  50.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  51.
  52.         TIM_TimeBaseStructure.TIM_Period = arr; //設置在下一個更新事件裝入活動的自動重裝載寄存器周期的值         80K
  53.         TIM_TimeBaseStructure.TIM_Prescaler =psc; //設置用來作為TIMx時鐘頻率除數的預分頻值  不分頻
  54.         TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設置時鐘分割:TDTS = Tck_tim
  55.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計數模式
  56.         TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據TIM_TimeBaseInitStruct中指定的參數初始化TIMx的時間基數單位
  57.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時器模式:TIM脈沖寬度調制模式2
  58.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
  59.         TIM_OCInitStructure.TIM_Pulse = 0; //設置待裝入捕獲比較寄存器的脈沖值
  60.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
  61.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據TIM_OCInitStruct中指定的參數初始化外設TIMx
  62.   TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主輸出使能
  63.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1預裝載使能
  64.
  65.         TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預裝載寄存器
  66.
  67.         TIM_Cmd(TIM1, ENABLE);  //使能TIM1
  68.
  69. }
  70. int main(void)
  71. {
  72.         delay_init();
  73.         LED_Init();
  74.         KEY_Init();
  75.         TIM1_PWM_Init(1999,72);
  76.         TIM_SetCompare1(TIM1,1899);
  77.         while(1)
  78.         {
  79.                 if(WK_UP==1)
  80.                 {
  81.                         LED0=0;
  82.                         TIM_SetCompare1(TIM1,1899);
  83.                 }
  84.                 else
  85.                 {
  86.                         LED0=1;
  87.                         TIM_SetCompare1(TIM1,699);
  88.                 }
  89.         }
  90. }
[ stm32控制舵機.7z (196.33 KB, 下載次數: 389)
本貼為原創,轉載請注明出處!
時間:2020/11/
祝好!
收藏收藏10 分享淘帖 頂1 踩
ID:917281 發表于 2021-5-7 22:11 | 只看該作者
想問一下 如果弄4個舵機的話 程序要怎么改
ID:242753 發表于 2021-5-9 10:15 | 只看該作者
最近正在研究舵機,正好可以好好分析了
ID:841381 發表于 2021-5-13 19:27 | 只看該作者
樓主你好,如果拖動4個電機,然后發現功率不夠該怎么辦?
ID:985711 發表于 2021-11-28 21:13 | 只看該作者
感謝樓主的分享,下來研究下
ID:1013164 發表于 2022-5-8 20:13 | 只看該作者
為啥我就改了PWM頻率,他就生成不了.hex文件了,顯示有一個fatal error
ID:1024276 發表于 2022-5-10 23:28 | 只看該作者
樓主你好 為啥我按照你的方法配置 配置的PWM  PA8 電平只是在跳動 舵機卻沒有反應 ,代碼也一樣 用的正點原子的模板
ID:1024276 發表于 2022-5-10 23:29 | 只看該作者
為啥我按照樓主的配置 PA8  只是電平再跳 ,而舵機沒有反應,模板用的正點原子的
ID:1060890 發表于 2023-3-6 13:25 | 只看該作者
試一下能不能用,自己配置的總有問題
ID:316613 發表于 2023-5-21 10:56 | 只看該作者
只能轉動一下,813版本,不知道為啥
