只需一步,快速開(kāi)始
查看: 2710|回復(fù): 0
OKdo E1開(kāi)發(fā)板驅(qū)動(dòng)雙色OLED屏顯示
OKdo E1開(kāi)發(fā)板是一款以硬幣大小而為人稱(chēng)道的開(kāi)發(fā)板,它體積小巧那自然要為它配置一塊同樣小巧的顯示屏才稱(chēng)得上是絕配,下面就通過(guò)I/O口來(lái)模擬I2C通訊了,使得OLED屏能夠顯示出信息來(lái)。
OLED屏與MCU的連接關(guān)系為:
SCL---PIO0_7
SDA---PIO1_0
相關(guān)引腳輸出高低電平的語(yǔ)句定義:
#define OLED_SCLK_Clr()  GPIO_PinWrite(GPIO, 0u, 7u, 0)
#define OLED_SCLK_Set()  GPIO_PinWrite(GPIO, 0u, 7u, 1)
#define OLED_SDIN_Clr()  GPIO_PinWrite(GPIO, 1u, 0u, 0)
#define OLED_SDIN_Set()  GPIO_PinWrite(GPIO, 1u, 0u, 1)
OLED屏引腳配置函數(shù):
  1. void app_oled_init(void)
  2. {
  3. gpio_pin_config_t   gpioPinConfig;
  4. gpioPinConfig.pinDirection = kGPIO_DigitalOutput;
  5. gpioPinConfig.outputLogic  = 1u;
  6. GPIO_PinInit (GPIO, 0u, 7u, &gpioPinConfig);
  7. GPIO_PinInit (GPIO, 1u, 0u, &gpioPinConfig);
  8. }
OLED屏初始化函數(shù):
  1. void OLED_Init(void)
  2. {
  3. Write_IIC_Command(0xAE); //display off
  4. Write_IIC_Command(0x20); //Set Memory Addressing Mode
  5. Write_IIC_Command(0x10);
  6. Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
  7. Write_IIC_Command(0xc8);//Set COM Output Scan Direction
  8. Write_IIC_Command(0x00);//---set low column address
  9. Write_IIC_Command(0x10);//---set high column address
  10. Write_IIC_Command(0x40);//--set start line address
  11. Write_IIC_Command(0x81);//--set contrast control register
  12. Write_IIC_Command(0xdf);
  13. Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
  14. Write_IIC_Command(0xa6);//--set normal display
  15. Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
  16. Write_IIC_Command(0x3F);//
  17. Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
  18. Write_IIC_Command(0xd3);//-set display offset
  19. Write_IIC_Command(0x00);//-not offset
  20. Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
  21. Write_IIC_Command(0xf0);//--set divide ratio
  22. Write_IIC_Command(0xd9);//--set pre-charge period
  23. Write_IIC_Command(0x22); //
  24. Write_IIC_Command(0xda);//--set com pins hardware configuration
  25. Write_IIC_Command(0x12);
  26. Write_IIC_Command(0xdb);//--set vcomh
  27. Write_IIC_Command(0x20);//0x20,0.77xVcc
  28. Write_IIC_Command(0x8d);//--set DC-DC enable
  29. Write_IIC_Command(0x14);//
  30. Write_IIC_Command(0xaf);//--turn on oled panel
  31. }
OLED屏顯示主程序:
  1. int main(void)
  2. {
  3. POWER_SetBodVbatLevel(kPOWER_BodVbatLevel1650mv, kPOWER_BodHystLevel50mv, false);
  4. CLOCK_EnableClock(kCLOCK_Gpio0);
  5. CLOCK_EnableClock(kCLOCK_Gpio1);
  6. BOARD_BootClockFROHF96M();
  7. app_oled_init();
  8. OLED_Init();
  9. OLED_Clear();
  10. OLED_ShowString(0,0,"OKDOE1 TEST",16);
  11. OLED_ShowString(0,2,"OLED Display",16);
  12. OLED_ShowString(0,4,"jinglixixi",16);
  13. OLED_ShowString(0,6,"2020.11.2",16);
  14. while (1);
  15. }
經(jīng)程序的編譯下載,其運(yùn)行效果如圖所示。
OLED屏顯示效果
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
