查看: 1542|回復: 0
基于STM32F103ZET6的平衡小車設計
ID:837715 發(fā)表于 2020-11-2 12:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "Inductance.h"
// 通道10-15
void ADCx_Init(void)
        GPIO_InitTypeDef GPIO_InitStructure; //定義結構體變量
        ADC_InitTypeDef       ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);//設置ADC分頻因子6 72M/6=12,ADC最大時間不能超過14M
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;//ADC
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;        //模擬輸入
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(GPIOC,&GPIO_InitStructure);
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ScanConvMode = DISABLE;//非掃描模式
        ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//關閉連續(xù)轉換
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//禁止觸發(fā)檢測,使用軟件觸發(fā)
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右對齊
        ADC_InitStructure.ADC_NbrOfChannel = 1;//1個轉換在規(guī)則序列中 也就是只轉換規(guī)則序列1
        ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
        ADC_Cmd(ADC1, ENABLE);//開啟AD轉換器
        ADC_ResetCalibration(ADC1);//重置指定的ADC的校準寄存器
        while(ADC_GetResetCalibrationStatus(ADC1));//獲取ADC重置校準寄存器的狀態(tài)
        ADC_StartCalibration(ADC1);//開始指定ADC的校準狀態(tài)
        while(ADC_GetCalibrationStatus(ADC1));//獲取指定ADC的校準程序
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能或者失能指定的ADC的軟件轉換啟動功能
u16 Get_ADC_Value(u8 ch,u8 times)
        u32 temp_val=0;
        u8 t;
        //設置指定ADC的規(guī)則組通道,一個序列,采樣時間
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5);        //ADC1,ADC通道,239.5個周期,提高采樣時間可以提高精確度
        for(t=0;t<times;t++)
                ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能指定的ADC1的軟件轉換啟動功能
                while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉換結束
                temp_val+=ADC_GetConversionValue(ADC1);
                delay_ms(5);
        return temp_val/times;
        Get_ADC_Value(ADC_Channel_1,20);
無效樓層,該帖已經(jīng)被刪除
