查看: 3932|回復: 1
Arduino軟件模擬RS485通信,雙線,半雙工 源程序
ID:496997 發表于 2020-10-27 21:54 | 顯示全部樓層 |閱讀模式
  1. #include <Arduino.h>
  2. static unsigned char D_0 = 2;
  3. static unsigned char D_1 = 3;
  4. void rs_485_all_pin_high()
  5. {
  6.   digitalWrite(D_0,HIGH);
  7.   digitalWrite(D_1,HIGH);
  8. }
  9. void rs_485_all_pin_low()
  10. {
  11.   digitalWrite(D_0,LOW);
  12.   digitalWrite(D_1,LOW);
  13. }
  14. void rs_485_all_pin_logic_1()
  15. {
  16.   digitalWrite(D_0,LOW);
  17.   digitalWrite(D_1,HIGH);
  18. }
  19. void rs_485_all_pin_logic_0()
  20. {
  21.   digitalWrite(D_0,HIGH);
  22.   digitalWrite(D_1,LOW);
  23. }
  24. unsigned char rs_485_read_pin()
  25. {
  26.   unsigned char temp_rs_485_read_pin_value = digitalRead(D_0);
  27.
  28.   return ((temp_rs_485_read_pin_value << 1) + digitalRead(D_1));
  29. }
  30. unsigned char rs_485_read_bit()
  31. {
  32.   unsigned char temp_from_485_read_pin_value = rs_485_read_pin();
  33.
  34.   if(temp_from_485_read_pin_value == 0)// 0-0
  35.   {
  36.     return 2;
  37.   }
  38.   if(temp_from_485_read_pin_value == 1)//0-1
  39.   {
  40.     return 1;
  41.   }
  42.   if(temp_from_485_read_pin_value == 3)//1-1
  43.   {
  44.     return 3;
  45.   }
  46.   if(temp_from_485_read_pin_value == 2)//1-0
  47.   {
  48.     return 0;
  49.   }
  50. }
  51. void rs_485_write(unsigned char rs_485_write_value)
  52. {
  53.   unsigned char i = 0,time_write_delay = 80;
  54.   rs_485_all_pin_high();
  55.
  56.   delayMicroseconds(time_write_delay);
  57.
  58.   for(;i < 8; i++)
  59.   {
  60.     unsigned char temp_rs_485_write_value = (rs_485_write_value & 128);
  61.     if(temp_rs_485_write_value)
  62.     {
  63.       rs_485_all_pin_logic_1();
  64.     }
  65.     else if(temp_rs_485_write_value == 0)
  66.     {
  67.       rs_485_all_pin_logic_0();
  68.     }
  69.     rs_485_write_value = rs_485_write_value << 1;
  70.     delayMicroseconds(time_write_delay);
  71.   }
  72.   rs_485_all_pin_low();
  73. }
  74. unsigned char rs_485_read(unsigned int delay_time_485)
  75. {
  76.   unsigned char i=0,temp_read_value = 0;
  77.
  78.   delayMicroseconds(110);
  79.
  80.   for(;i<8;i++)
  81.   {
  82.     temp_read_value = ((temp_read_value << 1) + rs_485_read_bit());
  83.     delayMicroseconds(delay_time_485);
  84.   }
  85.   return temp_read_value;
  86. }
  87. unsigned char rs_485_test()
  88. {
  89.   if(rs_485_read_pin() == 0)
  90.   {
  91.     return 1;
  92.   }
  93.   else
  94.   {
  95.     return 0;
  96.   }
  97. }
  98. void rs_485_init()
  99. {
  100.   pinMode(D_0,INPUT);
  101.   pinMode(D_1,INPUT);
  102.   rs_485_all_pin_low();
  103. }
RS-485.rar (1.77 KB, 下載次數: 21)
ID:937433 發表于 2021-6-14 18:34 | 顯示全部樓層
how can i apply in my code void main.... how to send the message
thanks in advance
