查看: 2368|回復(fù): 0
單片機(jī)精確控制步進(jìn)電機(jī)步數(shù)程序問題
ID:827402 發(fā)表于 2020-10-9 20:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg51.h>
#include<intrins.h>
sbit K1 = P3^2;//加速
sbit K2 = P3^3;//減速
sbit K3 = P3^4;//正傳
sbit K4 = P3^5;//反轉(zhuǎn)
sbit K5 = P3^6;//啟動(dòng)
sbit K6 = P3^7;//停止
sbit RS=P2^6;
sbit RW=P2^7;
void main( )
        bit fangxiang = 1;//0是逆時(shí)針
        bit kaiqi=0;//0是停止
        int sudu= 4;//每次步進(jìn)間隔時(shí)間為 1ms * sudu,也就是最快每秒25轉(zhuǎn)
        char str_buff[] = { "00.00" };
        int speed = 0;
        init_lcd();
        lcd( 0, 0, "LCD_INIT" );
        delay( 100 );
        lcd( 0, 0, "        " );
        Init_Motor();
        Set_Motor(kaiqi, fangxiang, sudu);
        lcd( 1, 0, "    reversal    " );
        lcd( 0, 0, "Speed: " );
        lcd( 0, 12, "r/s" );
        speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
        str_buff[0] = speed / 10000 % 10 + '0';
        str_buff[1] = speed / 1000 % 10 + '0';
        str_buff[3] = speed / 100 % 10 + '0';
        str_buff[4] = speed % 10 + '0';
        lcd( 0, 6, str_buff );
               //加速
                if( K1 == 0 )
                        delay( 50 );
                        if( K1 == 0 )
                                sudu--;
                                if( sudu <= 3 )
                                        sudu = 4;
//                                while( K1 == 0 );
                //減速
                if( K2 == 0 )
                        delay( 50 );
                        if( K2 == 0 )
                                sudu++;
                                if( sudu >= 60000 )
                                        sudu = 60000;
                //正
                if( K3 == 0 )
                        delay( 50 );
                        if( K3 == 0 )
                                fangxiang = 1;
                                lcd( 1, 0, "Forward rotation" );
                                while( K3 == 0 );
               //反
                if( K4 == 0 )
                        delay( 50 );
                        if( K4 == 0 )
                                fangxiang = 0;
                                while( K4 == 0 );
               //啟
                if( K5 == 0 )
                        delay( 50 );
                        if( K5 == 0 )
                                kaiqi = 1;
                                while( K6 == 0 );
               //停
                if( K6 == 0 )
                        delay( 50 );
                        if( K6 == 0 )
                                kaiqi = 0;
                                while( K6 == 0 );
求一個(gè)可以控制步數(shù)的程序另外有大佬可以看一下程序哪里有問題嗎
