最近做設(shè)計(jì)的成果,參考了一些資料;
波形發(fā)生器包含正弦波、方波、鋸齒波、三角波;
可通過按鍵改變波形和頻率;
示波器可觀察到波形,LCD12864上顯示波形和頻率。
仿真圖和代碼全在壓縮包里了。
2020-9-26 16:58 上傳
2020-9-26 16:58 上傳
2020-9-26 16:58 上傳
2020-9-26 16:58 上傳
單片機(jī)源程序如下:
- #include <reg52.h>
- #include <math.h>
- #include <intrins.h>
- #include <lcd12864.h>
- #define DAC_OUT P2
- sbit change_wave=P3^2; //改變波形按鍵
- sbit change_rate=P3^3; //改變頻率按鍵
- uchar mode=0,rate=0,delay_time=0,k,p; //為波形發(fā)生模塊提供中間變量
- uchar *which_wave,*which_wave2;
- uint rate_num;
- uchar code Sine_wave[64]= //DA輸出對(duì)應(yīng)電壓值對(duì)應(yīng)的數(shù)字量,正弦波
- 128,114,102,90,78,66,55,45,36,28,20,14,9,5,2,1,1,1,
- 3,7,11,17,24,32,41,50,61,72,84,96,108,121,133,146,
- 158,170,182,193,204,213,222,230,237,243,247,251,253,
- 254,254,252,249,245,240,234,226,218,209,199,188,176,
- 167,158,145,135
- uchar code Sawtooth_Wave[64]= //鋸齒波
- 255,251,247,243,239,235,231,227,223,219,215,210,206,202,
- 198,194,190,186,182,178,174,170,166,162,158,154,150,146,
- 142,138,134,130,125,121,117,113,109,105,101,97,93,89,85,
- 81,77,73,69,61,57,53,49,45,40,36,32,28,24,20,16,12,8,4,0
- uchar code Square_wave[64]= //方波
- 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
- 0,0,0,0,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- uchar code Triangular_Wave[64]= //三角波
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,
- 144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,
- 136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- void wave_delay() //波形延時(shí)函數(shù)
- int a,b;
- for(a=1; a>0; a--)
- for(b=122; b>0; b--);
- void wave_init() //波形發(fā)生模塊的初始化(外部中斷0、1)
- EA=1;
- IT0=1; //下降沿觸發(fā)
- EX0=1;
- IT1=1;
- EX1=1;
- void disp_wave(uchar *wave) //顯示波形函數(shù)
- uchar page,i;
- uint date;
- select(1); //選擇左屏
- for(i=32; i<64; i++)
- page=7-(wave[i]/4)/8;
- date=7-(wave[i]/4)%8;
- date=pow(2,date);
- setpos(page,i); //選擇行列
- lcd_wdat(date);
- select(2); //選擇右屏
- for(i=0; i<64; i++)
- date=pow(2,date);
- lcd_wdat(date);
- void main()
- lcd_init();
- clr_screen();
- which_wave=&Sine_wave[0];
- disp_chinese();
- disp_function(chinese_sine);
- disp_rate(400);
- disp_xy();
- disp_wave(which_wave);
- wave_init();
- while(1)
- delay_time=rate; //rate=0時(shí),12mhz下,為400hz的波形。循環(huán)一次的時(shí)間為0.00025ms
- DAC_OUT=*(which_wave+k);
- k++;
- if(k==64)
- k=0;
- while(delay_time)
- delay_time--;
- void int0() interrupt 0 //波形選擇中斷服務(wù)程序
- EX0=0;
- wave_delay();
- mode++;
- if(mode==4)
- mode=0;
- switch(mode)
- case 0 : //顯示正弦波
- which_wave2=&chinese_sine[0];
- break;
- case 1 : //顯示三角波
- which_wave=&Triangular_Wave[0];
- which_wave2=&chinese_triangular[0];
- break;
- case 2 : //顯示方波
- which_wave=&Square_wave[0];
- which_wave2=&chinese_square[0];
- break;
- case 3 : //顯示鋸齒波
- which_wave=&Sawtooth_Wave[0];
- which_wave2=&chinese_sawtooth[0];
- break;
- wave_delay();
- clr_screen();
- disp_chinese();
- disp_rate(400/rate);
- disp_function(which_wave2);
- disp_xy();
- while(!change_wave);
- EX0=1;
- void int1() interrupt 2 //頻率選擇
- EX1=0;
- wave_delay();
- p++;
- if(p==50)
- p=0;
- rate=p;
- wave_delay();
- rate_num=1/((0.000036+0.000006*rate)*64);
- clc_rate();
- disp_rate(rate_num);
- while(!change_rate);
- EX1=1;
所有資料51hei提供下載(內(nèi)含Proteus8.8仿真圖與代碼):
單片機(jī)51hei設(shè)計(jì).zip
(145.89 KB, 下載次數(shù): 171)
2020-9-26 16:59 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
