$regfile = "m16def.dat"
$crystal = 8000000
Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portc.2 , Rs = Portc.0
Config Lcd = 16 * 2
Config 1wire = Porta.0
Dim Id(8) As Byte
Dim I As Byte
Dim C(2) As Byte
Dim T As Word
Deflcdchar 0 , 14 , 10 , 14 , 32 , 32 , 32 , 32 , 32 ' 定義度的顯示字符
Deflcdchar 1 , 4 , 10 , 17 , 4 , 31 , 2 , 4 , 8 '定義漢字今的顯示字符
Deflcdchar 2 , 31 , 4 , 31 , 4 , 12 , 10 , 18 , 17 '定義漢字天的顯示字符
Dim Shi As Byte , Fen As Byte , Miao As Byte
Dim S As String * 2 , F As String * 2 , M As String * 2
Dim N_shi As Byte , N_fen As Byte , Zt As Bit
Dim N_s As String * 2 , N_f As String * 2
Dim Key_in As Byte
Dim Beep_times As Byte
Config Portb = Input
Portb = &HFF
Initlcd
Cls
Shi = 12
Fen = 0
Miao = 0
N_shi = 12
N_fen = 0
Zt = 0
Cursor Off
Main:
Cls
Gosub Disp
Gosub Ds18b20csh
Gosub 18b20js
Gosub Key_scan
Gosub Naoshi
Gosub Jishi
Goto Main
End
程序是正確的,實(shí)驗(yàn)是成功的,溫度是能顯示的,時(shí)間是很準(zhǔn)確的
小問(wèn)題也是存在的,基本上也是能解決的.湊合湊合也是能用的
bascom-m16-18b20.zip
2020-9-16 10:31 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
1.65 KB, 下載次數(shù): 9, 下載積分: 黑幣 -5
能顯示溫度及時(shí)間(能調(diào)時(shí)鬧時(shí))的bascom-avr程序
評(píng)分
查看全部評(píng)分
