查看: 3870|回復: 0
一個經典的按鍵掃描加按鍵消抖的程序
ID:661718 發表于 2020-9-15 22:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
先寫了一個按鍵消抖函數然后將兩種狀態存為兩種變量,0代表松開,1代表按下按鍵。
f(HAL_GPIO_ReadPin(GPIOx,GPIO_Pin)==GPIO_PIN_SET)這個函數是讀取引腳電平的一個函數,返回值為0或1.
后面函數是一個外部中斷函數,根據第一個函數return的值,做出選擇。
uint16_t Key_Detection(GPIO_TypeDef *GPIOx,uint16_t GPIO_Pin)
                        uint16_t Key_Value=0;
                        if(HAL_GPIO_ReadPin(GPIOx,GPIO_Pin)==GPIO_PIN_SET)
                                HAL_Delay(18);
                                if(HAL_GPIO_ReadPin(GPIOx,GPIO_Pin)==GPIO_PIN_SET)                        //yan shi xiao dou
                                        Key_Value=1;
                                //while(HAL_GPIO_ReadPin(Key_GPIO_Port,Key_Pin)==GPIO_PIN_RESET);                //song shou jian ce
                        return Key_Value;
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
        uint32_t K[6]={10,100,1000,10000,100000,1000000};
        if(GPIO_Pin ==Key3_Pin )
                        if(Key_Detection(Key3_GPIO_Port ,GPIO_Pin)==1)
                        {a++;}
        if(GPIO_Pin==Key2_Pin  )
        {if(Key_Detection(Key1_GPIO_Port ,GPIO_Pin)==1)
        {                HAL_GPIO_TogglePin (GPIOE,GPIO_PIN_5 );
                Freq =Freq+K[a%6];
                //Freq++;
        if(GPIO_Pin==Key1_Pin )
                        Freq =Freq-K[a%6];
                        //Freq--;
ad9851_init ();
ad9851_writefrq (Freq );
收藏收藏2 分享淘帖 頂 踩
