適用于:stc15f2k60s2型號單片機(其它型號的51單片機如果想用這個程序,就得修改程序的波特率和某一些的地方才能用)
藍牙模塊:hc-05模塊
你用手機給藍牙發個0,led燈亮,發個1,led燈滅。
51單片機
- #include <stc15f2k60s2.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar receiveData;
- sbit led=P0^0;
- void UartInit(void) //9600bps@ 11.0592MHz
- PCON &= 0x7F; //波特率不倍速
- SCON = 0x50; //8位數據,可變波特率
- AUXR |= 0x40; //定時器1時鐘為Fosc,即1T
- AUXR &= 0xFE; //串口1選擇定時器1為波特率發生器
- TMOD &= 0x0F; //清除定時器1模式位
- TMOD |= 0x20; //設定定時器1為8位自動重裝方式
- TL1 = 0xDC; //設定定時初值
- TH1 = 0xDC; //設定定時器重裝值
- ET1 = 0; //禁止定時器1中斷
- TR1 = 1; //啟動定時器1
- EA=1; //打開總中斷
- ES=1; //打開接收中斷
- void send1_Byte(unsigned char byte)//發送字符
- SBUF = byte;
- while(TI==0); //發送完會自動置1
- TI=0; //手動清零
- void Send1_String(char *str) //發送字符串
- while (*str!='\0') //檢測字符串結束標志
- send1_Byte(*str++);
- void Usart() interrupt 4 //串口中斷函數接收程序
- if (RI==1)
- receiveData = SBUF;
- RI=0;
- void working()
- if(receiveData == '0') //發現有數據輸入0
- send1_Byte('0'); led=0 ;
- receiveData = 'A';}
- if(receiveData == '1')
- send1_Byte('1');
- led=1 ;
- int main()
- UartInit();
- while(1)
- working();
51單片機hc-05藍牙點燈程序.zip
(257.03 KB, 下載次數: 67)
2020-9-8 21:26 上傳
51單片機
