查看: 1717|回復: 0
求分析51單片機2046觸摸屏畫圖程序的錯誤
ID:382699 發(fā)表于 2020-9-2 21:36 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 分立元件 于 2020-9-3 13:31 編輯
搞了好多天都不行,不知道哪里錯了,現(xiàn)在X軸正常,Y軸定位不對,寫上,就顯示下,反過來了,還有屏幕最下面不能顯示
#include<reg51.h>
#include<absacc.h>
#include<intrins.h>
#include<string.h>
//液晶屏引腳
sbit cs        =P1^0;//片選
sbit reset     =P1^1;//復位
sbit rs        =P1^2;//地址/數(shù)據(jù)切換
sbit sda       =P1^3;// SDI  MOSI
sbit scl       =P1^4;//時鐘
//SDO引腳可以不連接
//觸摸屏引腳
sbit  clk=P0^4;
sbit  cs1=P0^3;
sbit  din=P0^2;
sbit  out=P0^1;
sbit  a=P0^0;
uchar bdata bitdata;
sbit bit7=bitdata^7;
sbit bit6=bitdata^6;
sbit bit5=bitdata^5;
sbit bit4=bitdata^4;
sbit bit3=bitdata^3;
sbit bit2=bitdata^2;
sbit bit1=bitdata^1;
sbit bit0=bitdata^0;
uint shuju;
void delay(uint time)
uint i;
  for(i=0;i<time;i++);
void  write_command(uchar c)
        cs=0;
        rs=0;
        bitdata=c;
        sda=bit7;scl=0;scl=1;
        sda=bit6;scl=0;scl=1;
        sda=bit5;scl=0;scl=1;
        sda=bit4;scl=0;scl=1;
        sda=bit3;scl=0;scl=1;
        sda=bit2;scl=0;scl=1;
        sda=bit1;scl=0;scl=1;
        sda=bit0;scl=0;scl=1;
        cs=1;
void  write_data(uchar d)
        cs=0;
        rs=1;
        bitdata=d;
        cs=1;
void wr_com16(unsigned char i,unsigned char j)
        cs=0;
        rs=1;
        bitdata=i;
        cs=1;
        cs=0;
        rs=1;
        bitdata=j;
        cs=1;
void lcd_initial()
        reset=0;
        delay(100);
        reset=1;
        delay(100);
        write_command(0x11);
        write_data(0x00);
        write_command(0xCF);
        write_data(0X00);
        write_data(0XC1);
        write_data(0X30);
        write_command(0xED);
        write_data(0X64);
        write_data(0X03);
        write_data(0X12);
        write_data(0X81);
        write_command(0xE8);
        write_data(0X85);
        write_data(0X11);
        write_data(0X78);
        write_command(0xF6);
        write_data(0X01);
        write_data(0X30);
        write_data(0X00);
        write_command(0xCB);
        write_data(0X39);
        write_data(0X2C);
        write_data(0X00);
        write_data(0X34);
        write_data(0X05);
        write_command(0xF7);
        write_data(0X20);
        write_command(0xEA);
        write_data(0X00);
        write_data(0X00);
        write_command(0xC0);
        write_data(0X20);
        write_command(0xC1);
        write_data(0X11);
        write_command(0xC5);
        write_data(0X31);
        write_data(0X3C);
        write_command(0xC7);
        write_data(0XA9);
        write_command(0x3A);
        write_data(0X55);
    write_command(0x36);
        write_data(0x48);//豎屏參數(shù)
        write_command(0xB1);
        write_data(0X00);
        write_data(0X18);
        write_command(0xB4);
        write_data(0X00);
        write_data(0X00);
        write_command(0xF2);
        write_data(0X00);
        write_command(0x26);
        write_data(0X01);
        write_command(0xE0);
        write_data(0X0F);
        write_data(0X17);
        write_data(0X14);
        write_data(0X09);
        write_data(0X0C);
        write_data(0X06);
        write_data(0X43);
        write_data(0X75);
        write_data(0X36);
        write_data(0X08);
        write_data(0X13);
        write_data(0X05);
        write_data(0X10);
        write_data(0X0B);
        write_data(0X08);
        write_command(0xE1);
        write_data(0X00);
        write_data(0X1F);
        write_data(0X23);
        write_data(0X03);
        write_data(0X0E);
        write_data(0X04);
        write_data(0X39);
        write_data(0X25);
        write_data(0X4D);
        write_data(0X06);
        write_data(0X0D);
        write_data(0X0B);
        write_data(0X33);
        write_data(0X37);
        write_data(0X0F);
    write_command(0x29);
void addset(unsigned int x,unsigned int y)
                write_command(0x2a);
                wr_com16(0,x);
                write_command(0x2b);
                wr_com16(0,y);
                write_command(0x2c);
void dsp_single_colour(DH,DL)
           unsigned int i;
        for (i=0;i<1;i++)
    wr_com16(DH,DL);
//觸摸屏程序
void write(uchar DAT)                //寫XY坐標
uchar i;
for(i=0;i<8;i++)
if(DAT&0x80)
   din=1;
   else din=0;
   DAT<<=1;
   clk=0;
   clk=1;
uint read()                                        //讀XY坐標數(shù)據(jù)
uint date=0;
uchar i;
clk=0;
for(i=0;i<12;i++)
date<<=1;
clk=1;
clk=0;
date|=out;
return date;
uint ad_read(uchar cmd)
char i;
clk=0;
cs1=0;
write(cmd);
for(i=6;i>0;i--);
clk=1;
clk=0;
shuju=read();
cs1=1;
return  shuju;
main()
{           uint aa,bb,x,y;
                lcd_initial();        //液晶屏初始化
                aa=0;
                bb=0;
                    if(a==0)   //有觸摸低電平
                         // delay(1);
ad_read(0xd0);   //讀x坐標指令
   aa=shuju;        //x坐標數(shù)據(jù)給aa
    ad_read(0x90);    //讀y坐標指令
    bb=shuju;        //y坐標數(shù)據(jù)給bb
    x=aa/(4095/240);//觸摸和液晶坐標轉換
                         y=bb/(4095/320);
                         addset(x,y);                                          //液晶屏坐標
                     dsp_single_colour(0xFF,0xFF);         //顯示白色定位點
收藏收藏2 分享淘帖 頂 踩
無效樓層,該帖已經(jīng)被刪除
