查看: 12137|回復: 5
Arduino出現avrdude: ser_open(): can't set com-state for "\\.\COM4
ID:815969 發表于 2020-8-27 22:57 | 顯示全部樓層 |閱讀模式
如題,Arduino出現這個指令怎么辦,求大神解答
“avrdude: ser_open(): can't set com-state for "\\.\COM4"”怎么辦?
ID:813826 發表于 2020-8-28 14:32 | 顯示全部樓層
重啟下, 可能是口子狀態錯誤
ID:815969 發表于 2020-8-29 09:54 | 顯示全部樓層
謝謝大神解答,問題已解決
ID:728064 發表于 2022-1-16 18:18 | 顯示全部樓層
我也碰到這個問題。咋解?
ID:238149 發表于 2024-1-18 20:20 | 顯示全部樓層
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean,
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\xiaoj\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't set com-state for "\\.\COM7"
avrdude done.  Thank you.
上傳項目出錯
