查看: 2662|回復(fù): 2
單片機(jī)寫數(shù)據(jù)到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM源程序
ID:171036 發(fā)表于 2020-8-27 11:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 51黑電子會(huì)員 于 2020-8-27 13:27 編輯
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. #define LCD12864Data P2//LCD12864點(diǎn)陣型液晶顯示器輸入輸出數(shù)據(jù)/命令端口
  5. sbit LCD12864_RS=P0^7;//LCD12864點(diǎn)陣型液晶顯示器數(shù)據(jù)/命令選擇端
  6. sbit LCD12864_RW=P0^6;//LCD12864點(diǎn)陣型液晶顯示器讀/寫端
  7. sbit LCD12864_EN=P0^5;//LCD12864點(diǎn)陣型液晶顯示器使能端
  8. //太陽
  9. uchar code sun[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x08,0x10,0x00,0x00,0x10,0x08,0x00,0x00,0x10,0x08,0x00,0x00,0x08,0x10,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00};
  10. //月亮
  11. uchar code moon[]={0x00,0x00,0x00,0x00,0x03,0x80,0x02,0x40,0x02,0x20,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x20,0x02,0x40,0x03,0x80,0x00,0x00,0x00,0x00};
  12. //星星
  13. uchar code star[]={0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x80,0x00,0x00,0x54,0x54,0x20,0x08,0x08,0x20,0x02,0x80,0x12,0x90,0x08,0x20,0x20,0x08,0x00,0x00,0x00,0x00};
  14. //人
  15. uchar code robot[]={0x07,0xE0,0x08,0x10,0x12,0x48,0x10,0x08,0x1F,0xF8,0x10,0x08,0x30,0x0C,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x5F,0xFA,0x04,0x20,0x04,0x20,0x04,0x20,0x0E,0x70};
  16.   void Delay(uint i)
  17. {
  18.    while(--i);
  19. }
  20.   void ReadBuzy()//讀忙函數(shù)
  21. {
  22.    P2=0x00;
  23.    LCD12864_RS=0;
  24.    LCD12864_RW=1;
  25.    LCD12864_EN=1;
  26.    while(P2 & 0x80);
  27.    LCD12864_EN=0;
  28. }
  29.   void LCD12864WriteCommand(uchar command)//寫指令函數(shù)
  30. {
  31.    ReadBuzy();//讀忙
  32.    LCD12864_RS=0;
  33.    LCD12864_RW=0;
  34.    LCD12864_EN=1;
  35.    LCD12864Data=command;
  36.    Delay(100);
  37.    LCD12864_EN=0;
  38. }
  39.   void LCD12864WriteData(uchar value)//寫數(shù)據(jù)函數(shù)
  40. {
  41.    ReadBuzy();//讀忙
  42.    LCD12864_RS=1;
  43.    LCD12864_RW=0;
  44.    LCD12864_EN=1;
  45.    LCD12864Data=value;
  46.    Delay(100);
  47.    LCD12864_EN=0;
  48. }
  49.   void LCD12864Init()//LCD12864點(diǎn)陣型液晶顯示器初始化函數(shù)
  50. {
  51.    ReadBuzy();//讀忙
  52.    Delay(4000);
  53.    LCD12864WriteCommand(0x30);//8位數(shù)據(jù)端口傳輸,且設(shè)置為基本指令集動(dòng)作。
  54.    Delay(100);
  55.    LCD12864WriteCommand(0x30);//8位數(shù)據(jù)端口傳輸,且設(shè)置為基本指令集動(dòng)作。
  56.    Delay(37);
  57.    LCD12864WriteCommand(0x0c);//設(shè)置整體顯示,光標(biāo)、閃爍全關(guān),不反白。
  58.    Delay(100);
  59.    LCD12864WriteCommand(0x01);//清屏,并且DDRAM數(shù)據(jù)指針清零。
  60.    Delay(10000);
  61.    LCD12864WriteCommand(0x06);//進(jìn)入點(diǎn)設(shè)定模式,設(shè)置地址指針自動(dòng)加1。
  62. }
  63.   void CGRAM()//寫自定義字符函數(shù)
  64. {
  65.    uchar i;
  66.    LCD12864WriteCommand(0x30);//設(shè)置LCD12864點(diǎn)陣型液晶顯示器數(shù)據(jù)端口D0-D7為8位控制接口,且這8位控制接口接收基本指令操作。
  67.    LCD12864WriteCommand(0x40);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第1個(gè)內(nèi)存地址
  68.           for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯示器16(行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
  69.   {
  70.      LCD12864WriteData(sun[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  71.      LCD12864WriteData(sun[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
  72.     }
  73.    LCD12864WriteCommand(0x50);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第2個(gè)內(nèi)存地址
  74.    for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯示器16(行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
  75. {
  76.     LCD12864WriteData(moon[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  77.     LCD12864WriteData(moon[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
  78.    }
  79.    LCD12864WriteCommand(0x60);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第3個(gè)內(nèi)存地址
  80.    for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯示器16(行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
  81. {
  82.     LCD12864WriteData(star[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  83.     LCD12864WriteData(star[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
  84.    }
  85.    LCD12864WriteCommand(0x70);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第4個(gè)內(nèi)存地址
  86.    for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯器16(示行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
  87. {
  88.     LCD12864WriteData(robot[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  89.     LCD12864WriteData(robot[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
  90.    }
  91. }
  92.   void main()//主函數(shù)
  93. {
  94.    LCD12864Init();//LCD12864點(diǎn)陣型液晶顯示器初始化函數(shù)
  95.    CGRAM();//寫自定義字符函數(shù)
  96.    LCD12864WriteCommand(0x98);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第1個(gè)顯示位置
  97.    LCD12864WriteData(0x00);//清空DRAM內(nèi)存地址上的內(nèi)容
  98.    LCD12864WriteData(0x00);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x00,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  99.    LCD12864WriteCommand(0x99);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第2個(gè)顯示位置
  100.    LCD12864WriteData(0x00);//清空DRAM內(nèi)存地址上的內(nèi)容
  101.    LCD12864WriteData(0x02);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x02,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  102.    LCD12864WriteCommand(0x9A);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第3個(gè)顯示位置
  103.    LCD12864WriteData(0x00);//清空DRAM內(nèi)存地址上的內(nèi)容
  104.    LCD12864WriteData(0x04);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x04,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  105.    LCD12864WriteCommand(0x9B);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第4個(gè)顯示位置
  106.    LCD12864WriteData(0x00);//清空DRAM內(nèi)存地址上的內(nèi)容
  107.    LCD12864WriteData(0x06);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x06,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
  108.    while(1);//固定循環(huán)
  109. }
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏2 分享淘帖 頂 踩
ID:815648 發(fā)表于 2020-8-30 10:35 | 只看該作者
寫的真詳細(xì),感謝作者的分享
ID:121859 發(fā)表于 2020-9-1 08:48 | 只看該作者
額,作者注釋詳細(xì)的有點(diǎn)過了,重復(fù)部分沒必要如此注解。
