查看: 12213|回復: 0
單片機按鍵的的三種方法 附源程序
ID:808771 發表于 2020-8-24 19:32 | 顯示全部樓層 |閱讀模式
分享單片機按鍵的三種方法
方法一:
#include <reg52.h>typedef unsigned int uInt16;sbit LED1 = P2^0;
sbit KEY1 = P3^4;
sbit KEY2 = P3^5;void DelayMS(uInt16 ValMS)
        uInt16 uiVal,ujVal;
        for(uiVal = 0; uiVal < ValMS; uiVal++)
                for(ujVal = 0; ujVal < 113; ujVal++);
}// 函數功能:毫秒延時// 函數功能:掃描按鍵并做出相應LED燈亮滅動作void main(void)
                if(0 == KEY1)                                   // 檢測按鍵是否按下
                        DelayMS(5);                                 // 延時去抖
                        if(0 == KEY1)                          // 再次檢測
                                LED1 = 0;                   // 點亮LED燈
                                while(!KEY1);                // 等待按鍵彈起
                if(!KEY2)
                        DelayMS(5);
                        if(!KEY2)
                                LED1 = 1;
                                while(!KEY2);
方法二:行列掃描法
#include <reg52.h>#define uInt16 unsigned int
#define uChar8 unsigned char
#define DATA P0                                          //數據口
#define KEYPORT         P3                                  //鍵盤接入端口sbit SEG_SELECT = P1^7;                          //段選控制端
sbit BIT_SELECT = P1^6;                          //位選控制端uChar8 code SEG_Tab[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};//段選顯示表格uChar8 g_ucKeyNum = 16;                        //鍵值// 函數功能:毫秒延時void DelayMS(uInt16 ValMS)
        uInt16 uiVal,ujVal;
                for(ujVal = 0; ujVal < 121; ujVal++);
}// 函數功能:矩陣按鍵掃描void ScanKey(void)
        uChar8 ucTemp;
        KEYPORT = 0xfe;                                          //檢測第一行
        ucTemp = KEYPORT;                                  //讀取鍵盤端口數值
        if(ucTemp != 0xfe)                                 //若是不等于0xF0表示有按鍵按下
                DelayMS(5);                 //去抖
                ucTemp = KEYPORT;                        //讀端口值
                if(ucTemp != 0xfe)                        //再次判斷
                        ucTemp = KEYPORT;                //取鍵值
                        switch(ucTemp)                        //判斷鍵值對應鍵碼
                                case 0xee:g_ucKeyNum = 0;break;
                                case 0xde:g_ucKeyNum = 1;break;
                                case 0xbe:g_ucKeyNum = 2;break;
                                case 0x7e:g_ucKeyNum = 3;break;
                        while(KEYPORT != 0xfe);        //按鍵釋放檢測
        KEYPORT = 0xfd;
        ucTemp = KEYPORT;
        if(ucTemp != 0xfd)
                DelayMS(5);
                ucTemp = KEYPORT;
                if(ucTemp != 0xfd)
                        ucTemp = KEYPORT;
                        switch(ucTemp)
                                case 0xed:g_ucKeyNum = 4;break;
                                case 0xdd:g_ucKeyNum = 5;break;
                                case 0xbd:g_ucKeyNum = 6;break;
                                case 0x7d:g_ucKeyNum = 7;break;
                        while(KEYPORT != 0xfd);
        KEYPORT = 0xfb;
        ucTemp = KEYPORT;
        if(ucTemp != 0xfb)
                DelayMS(5);
                ucTemp = KEYPORT;
                if(ucTemp != 0xfb)
                        ucTemp = KEYPORT;
                        switch(ucTemp)
                                case 0xeb:g_ucKeyNum = 8;break;
                                case 0xdb:g_ucKeyNum = 9;break;
                                case 0xbb:g_ucKeyNum = 10;break;
                                case 0x7b:g_ucKeyNum = 11;break;
                        while(KEYPORT != 0xfb);
        KEYPORT = 0xf7;
        ucTemp = KEYPORT;
        if(ucTemp != 0xf7)
                DelayMS(5);
                ucTemp = KEYPORT;
                if(ucTemp != 0xf7)
                        ucTemp = KEYPORT;
                        switch(ucTemp)
                                case 0xe7:g_ucKeyNum = 12;break;
                                case 0xd7:g_ucKeyNum = 13;break;
                                case 0xb7:g_ucKeyNum = 14;break;
                                case 0x77:g_ucKeyNum = 15;break;
                        while(KEYPORT != 0xf7);
// 函數名稱:Display()
// 函數功能:數碼管刷新
// 入口參數:需顯示的數值(ucVal)
// 出口參數:無
void Display(uChar8 ucVal)
        if(ucVal == 16)                        //若鍵值是16即沒有按鍵按下,則不顯示
                   BIT_SELECT = 1;
                DATA = 0xff;
                BIT_SELECT = 0;
        else                                   //若有按下,顯示對應鍵值
                BIT_SELECT = 1;
                DATA = 0x00;
                BIT_SELECT = 0;
                SEG_SELECT = 1;
                DATA = SEG_Tab[ucVal];
                SEG_SELECT = 0;
                DelayMS(10);
                DATA = 0xff;
// 函數名稱:main()
// 函數功能:矩陣按鍵掃描并用數碼管顯示鍵值
// 入口參數:無
// 出口參數:無
void main(void)
                ScanKey();
                Display(g_ucKeyNum);
方法三:
  1. void key4(void)
  2. {
  3.         static uchar i = 0;
  4.         static uchar keybuff[4] = {0xff,0xff,0xff,0xff};
  5.         static uchar keybackup = 1;
  6.         keybuff[0] = (keybuff[0] << 1)|KEY1;
  7.         keybuff[1] = (keybuff[1] << 1)|KEY2;
  8.         keybuff[2] = (keybuff[2] << 1)|KEY3;
  9.         keybuff[3] = (keybuff[3] << 1)|KEY4;
  10.         if(keybuff[i] == 0xf0 && keybackup)
  11.         {
  12.                 key = 1 + i;
  13.                 keybackup = 0;
  14.         }
  15.         else if(keybuff[i] == 0xff)
  16.         {
  17.                 i++;
  18.                 if(i == 4)
  19.                 {
  20.                         i = 0;
  21.                 }
  22.                 keybackup = 1;
  23.         }
  24. }
