/*==================================================================* * 3個IO接識別22鍵測試程序 * * ------------------------------------------------ * * MCU: AT89C2051 * * OSC: 12M cysytel * * 程序設計:Cowboy * * 程序版本:V1.0 * *==================================================================*/ #include //================== IO口線連接 ================== sbit Bus = P1^0; sbit IO_a = P1^4; sbit IO_b = P1^3; sbit IO_c = P1^2; //================== 變量聲明 ==================== unsigned char Disp_buf[3]; unsigned char Dig; unsigned char Key_count; unsigned char bdata Key_state; sbit KB0 = Key_state^0; sbit KB1 = Key_state^1; sbit KB2 = Key_state^2; sbit KB3 = Key_state^3; sbit KB4 = Key_state^4; sbit KB5 = Key_state^5; //================== 表格數據 ==================== code unsigned char LED_font[24]= { 0x84,0x9f,0xa2,0x8a,0x99,0xc8,0xc0,0x9e,0x80, //012345678 0x88,0x90,0xc1,0xe4,0x83,0xe0,0xf0,0xff,0xfb, //9abcdef - }; code unsigned char Key_tab[64]= //鍵碼映射表 {// 0 1 2 3 4 5 6 7 8 9 22, 0, 2, 0, 0, 0, 0, 0, 4, 0, //0 0, 0, 0, 0, 0,18, 0, 0, 0, 0, //1X 0, 0, 0, 0, 0, 0, 3,14, 0, 0, //2X 20,10, 6, 0, 0, 0, 0, 0, 1,19, //3X 0, 5, 0, 0, 0,15, 0,11, 0, 0, //4X 0,17, 0, 0,13, 8, 0,21, 0, 9, //5X 16,12, 7, 0 //6X }; //=============== 檢測按鍵 ================= void Key_scan() { unsigned char i; Key_count --; //掃描次序 Key_count &= 3; switch (Key_count) //按次序處理 { case 2: //第一輪掃描 KB0 = IO_b; KB1 = IO_c; IO_a = 1; IO_b = 0; break; case 1: //每二輪掃描 KB2 = IO_c; KB3 = IO_a; IO_b = 1; IO_c = 0; break; case 0: //每三輪掃描 KB4 = IO_a; KB5 = IO_b; IO_c = 1; break; default: //每四輪掃描 if (!IO_a) KB0 = 0; if (!IO_b) KB2 = 0; if (!IO_c) KB4 = 0; IO_a = 0; //======更新顯示緩沖區======= i = Key_tab[Key_state]; if (i == 0) { Disp_buf[2] = 0x11; //顯示三橫 Disp_buf[1] = 0x11; Disp_buf[0] = 0x11; } else { Disp_buf[2] = 0x0c; //字符"C" Disp_buf[1] = i / 10; //鍵碼十位 Disp_buf[0] = B;于 //鍵碼個位 } Key_state = 0; } } /*=================================================================== ONE WIRE 顯示總線驅動程序 ===================================================================*/ //=============== 發送一位 ================= void Send_bit(bit Dat) { unsigned char i = 3; if (!Dat) Bus = 0; else { Bus = 0; Bus = 1; } while(--i); //延時8us Bus = 1; } //=============== 總線驅動 ================= void Bus_drive() { unsigned char i = 0; unsigned char Sdat; Send_bit(1); //Bit6消隱 do Bus = 1; while(--i); //延時768us do Bus = 0; while(--i); //延時768us Bus = 1; Sdat = LED_font[Disp_buf[Dig++]]; //獲取顯示數據 Send_bit(Sdat & 0x01); //發送位0 Send_bit(Sdat & 0x02); //發送位1 Send_bit(Sdat & 0x04); //發送位2 Send_bit(Sdat & 0x08); //發送位3 Send_bit(Sdat & 0x10); //發送位4 Send_bit(Sdat & 0x20); //發送位5 Send_bit(Dig & 0x01); //發送位選1 Send_bit(Dig & 0x02); //發送位選2 while(--i); //延時512us Send_bit(Sdat & 0x40); //發送位6 for (i = 7;i> 0;i--) Send_bit(1); //位6移至Dout if (Dig == 3) Dig = 0; } /*=================================================================== 延時 5ms 程序 ===================================================================*/ void Delay_5ms() { while(!TF1); TF1 = 0; TH1 = (- 5000) / 256; TL1 = (- 5000) % 256; } /*=================================================================== 主程序 ===================================================================*/ void main() { TMOD = 0x10; //定時器1,16位模式 TCON = 0xc0; //TR1=1;TF1=1; while(1) //主循環 { Bus_drive(); //顯示總線驅動 Key_scan(); //檢測按鍵 Delay_5ms(); //延時5MS } } |
