查看: 3224|回復: 4
stc89c52單片機eeprom問題
ID:358460 發表于 2020-8-19 17:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
近期制作了一個計數器,想增加eeprom來掉電存儲。但是發現數碼管數字增加一次就不再增加(從512跳到2),不知是何故,求指教
#include <reg52.h>
#include <intrins.h>
float c=2;
uchar duan[]={
          0x3f,  /*0*/
      0x06,  /*1*/
      0x5b,  /*2*/
      0x4f,  /*3*/
      0x66,  /*4*/
      0x6d,  /*5*/
      0x7d,  /*6*/
      0x07,  /*7*/
      0x7f,  /*8*/
      0x6f,   /*9*/
          0x00    //ximie
sbit key=P3^2;//霍爾傳感器
sbit nnn=P1^7;//小數點dp控制位
unsigned long jishu=4294967295;
double meterd;
unsigned long meter;<font color="#ff0000">//在此以上是原來的,無誤</font>
/*eeprom<font color="#ff0000">(這些是復制的stc示例程序)</font>*/
/*Declare SFR associated with the IAP */
sfr IAP_DATA    =   0xE2;           //Flash data register
sfr IAP_ADDRH   =   0xE3;           //Flash address HIGH
sfr IAP_ADDRL   =   0xE4;           //Flash address LOW
sfr IAP_CMD     =   0xE5;           //Flash command register
sfr IAP_TRIG    =   0xE6;           //Flash command trigger
sfr IAP_CONTR   =   0xE7;           //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE    0               //Stand-By
#define CMD_READ    1               //Byte-Read
#define CMD_PROGRAM 2               //Byte-Program
#define CMD_ERASE   3               //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
#define ENABLE_IAP   0x81           //if SYSCLK<20MHz
//Start address for STC89C58xx EEPROM
#define IAP_ADDRESS 0x2000<font color="#ff0000">//這里已經改成89c52的eeprom地址</font>
/*MCU初始設置<font color="#ff0000">(開中斷)</font>*/
void init_MCU(void)
         EX0=1;
         IT0=1;
         EA=1;
/*1ms delay*/
void delayms(uint xms)
uint timems;
for(;xms>0;xms--)
        for(timems=115;timems>0;timems--);
/*顯示*/
void display(uint dat)
uchar ge,shi,bai,qian;
ge=dat%1000%100%10;
shi=dat%1000%100/10;
bai=dat%1000/100;
qian=dat/1000;
P2=0XF7;//個位
P1=duan[ge];
delayms(3);
P2=0XFB;//十位
P1=duan[shi];
delayms(3);
P2=0XFD;//百位
P1=duan[bai];
delayms(3);
P2=0XFE;//千位
P1=duan[qian];
delayms(3);
/*eeprom(<font color="#ff0000">也是示例程序</font>)*/
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
    IAP_CONTR = 0;                  //Close IAP function
    IAP_CMD = 0;                    //Clear command to standby
    IAP_TRIG = 0;                   //Clear trigger register
    IAP_ADDRH = 0x80;               //Data ptr point to non-EEPROM area
    IAP_ADDRL = 0;                  //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
uchar IapReadByte(uint addr)
    uchar dat;                       //Data buffer
    IAP_CONTR = ENABLE_IAP;         //Open IAP function, and set wait time
    IAP_CMD = CMD_READ;             //Set ISP/IAP/EEPROM READ command
    IAP_ADDRL = addr;               //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = addr >> 8;          //Set ISP/IAP/EEPROM address high
    IAP_TRIG = 0x46;                //Send trigger command1 (0x46)
    IAP_TRIG = 0xb9;                //Send trigger command2 (0xb9)
    _nop_();                        //MCU will hold here until ISP/IAP/EEPROM operation complete
    dat = IAP_DATA;                 //Read ISP/IAP/EEPROM data
    IapIdle();                      //Close ISP/IAP/EEPROM function
    return dat;                     //Return Flash data
Program one byte to ISP/IAP/EEPROM area
       dat (ISP/IAP/EEPROM data)
Output:-
void IapProgramByte(uint addr, uchar dat)
    IAP_CMD = CMD_PROGRAM;          //Set ISP/IAP/EEPROM PROGRAM command
    IAP_DATA = dat;                 //Write ISP/IAP/EEPROM data
    IapIdle();
Erase one sector area
Output:-
void IapEraseSector(uint addr)
    IAP_CMD = CMD_ERASE;            //Set ISP/IAP/EEPROM ERASE command
    IapIdle();
/*主程序(和原來一樣)*/
uint i;
init_MCU();
meterd=jishu*c;
meter=meterd;
if (meter<10000)
P1=0X00;
P2=0XFE;
nnn=1;
delayms(3);
P2=0XFF;
display (meter);
P1=0X00;
P2=0XFD;
nnn=1;
delayms(3);
P2=0XFF;
display(meter/10);
void Int0() interrupt 0<font color="#ff0000">//這里面改了
delayms(50);
if(key==0)
jishu=IapReadByte(IAP_ADDRESS);
jishu++;
    IapProgramByte(IAP_ADDRESS,jishu);
ID:213173 發表于 2020-8-19 21:10 | 只看該作者
stc單片機的eeprom哪怕只寫1個字節也得先把整個扇區擦除才能正常寫入。如果只改寫某一個或多個字節就得把有效地址的數據全部讀出來保存,改變其中一個或多個數據后再將整個扇區擦除,把改變后的和原樣的數據一道按原地址寫回去。
        delayms(50);
        if(key==0)
                jishu++;
                IapEraseSector(IAP_ADDRESS);//擦除扇區
ID:71233 發表于 2020-8-20 07:58 | 只看該作者
wulin 發表于 2020-8-19 21:10
stc單片機的eeprom哪怕只寫1個字節也得先把整個扇區擦除才能正常寫入。如果只改寫某一個或多個字節就得把有 ...
沒錯,讀寫STC內部eeprom麻煩變麻煩在這里
ID:213173 發表于 2020-8-20 10:05 | 只看該作者
新新科技 發表于 2020-8-20 07:58
這是由于硬件材料的物理特性所致,Data Flash只能寫0不能寫1,只有全部擦除后全部都為1。
ID:358460 發表于 2020-8-21 13:24 來自觸屏版 | 只看該作者
謝謝大家的幫助。問題現在已經解決了,一個是大家所說的問題.需要先把整個扇區給擦掉才能寫。第二點是對eeprom操作時候要關掉系統的總中斷,我的程序是在中斷里邊兒直接就把中斷給關了,還沒有寫入進去,中斷就跳出。
