OLED屏是一種小巧的顯示器件,特別是I2C接口的OLED 屏更能節(jié)省I/O口資源。本次使用的是一款0.91'的單色OLED屏,它比常規(guī)的OLED屏要長(zhǎng)且窄,故更適于顯示信息和參數(shù),也更適于用在便攜裝置上。 1. OLED屏顯示 1)OLED屏與NV32F100的連接關(guān)系如下: SCL --- PE1 SDA --- PE0
2)為進(jìn)行顯示定義引腳輸出高低電平的語(yǔ)句為: #defineOLED_SCLK_Clr() GPIO_PinClear(GPIO_PTE1); #defineOLED_SCLK_Set() GPIO_PinSet(GPIO_PTE1);
#defineOLED_SDIN_Clr() GPIO_PinClear(GPIO_PTE0); #defineOLED_SDIN_Set() GPIO_PinSet(GPIO_PTE0);
3)OLED屏初始化函數(shù)為: - void OLED_Init(void)
- Delay_1ms(800);
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
- OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
- OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
- OLED_WR_Byte(0x81,OLED_CMD); // contract control
- OLED_WR_Byte(0xFF,OLED_CMD);//--128
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x1F,OLED_CMD);//--1/32 duty
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
- OLED_WR_Byte(0x00,OLED_CMD);
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0xF0,OLED_CMD);
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0x22,OLED_CMD);
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x02,OLED_CMD);
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x49,OLED_CMD);//30
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- OLED_Clear();
- 4)字符串顯示函數(shù)為:
- void OLED_ShowChar(unsigned char x,unsigned char y,unsigned char chr,unsigned char Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';
- if(x>Max_Column-1){x=0;y=y+2;}
- if(Char_Size ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
2. RTC計(jì)時(shí) NV32F100提供了RTC計(jì)時(shí)器,但并未提供相關(guān)的寄存器進(jìn)行計(jì)時(shí)的進(jìn)制控制。為此。我們可以RTC提供的基準(zhǔn)計(jì)時(shí)信號(hào)來(lái)自行構(gòu)建進(jìn)制處理。 1)以RTC進(jìn)行秒計(jì)時(shí),并利用變量ss來(lái)進(jìn)行計(jì)時(shí),所用的函數(shù)如下: - void RTC_Task(void)
- GPIO_Toggle(GPIOB, GPIO_PTE7_MASK);
- ss++;
2)進(jìn)制處理,采用如下代碼: - if(ss==60)
- ss=0;
- mm=mm+1;
- if(mm==60)
- mm=0;
- hh=hh+1;
- if(hh==24)
- hh=0;
3)RTC計(jì)時(shí)主程序,其代碼如下: - int main (void)
- sysinit();
- cpu_identify();
- RTC_ConfigType sRTCConfig;
- RTC_ConfigType *pRTCConfig = &sRTCConfig;
- pRTCConfig->u16ModuloValue = 9;
- pRTCConfig->bInterruptEn = RTC_INTERRUPT_ENABLE;
- pRTCConfig->bClockSource = RTC_CLKSRC_1KHZ;
- pRTCConfig->bClockPresaler = RTC_CLK_PRESCALER_100;
- RTC_SetCallback(RTC_Task);
- RTC_Init(pRTCConfig);
- GPIO_Init(GPIOB, GPIO_PTE7_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTE0_MASK, GPIO_PinOutput);
- GPIO_Init(GPIOB, GPIO_PTE1_MASK, GPIO_PinOutput);
- OLED_Init();
- OLED_Clear();
- cd ();
- while (1)
- OLED_ShowNum(24,2,hh,2,16);
- OLED_ShowChar(40,2,':',16);
- OLED_ShowNum(48,2,mm,2,16);
- OLED_ShowChar(64,2,':',16);
- OLED_ShowNum(72,2,ss,2,16);
- if(ss==60)
- ss=0;
- mm=mm+1;
- if(mm==60)
- mm=0;
- hh=hh+1;
- if(hh==24)
- hh=0;
4)運(yùn)行效果如圖所示
2020-8-15 10:52 上傳
運(yùn)行效果圖
