查看: 3984|回復(fù): 10
單片機(jī)程序編譯出現(xiàn)一大堆錯誤,怎樣解決?
ID:143767 發(fā)表于 2020-8-11 15:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序里面錯的地方是我從別的程序移植過來的,想請大家?guī)臀曳治鲆幌洛e在哪里,怎樣解決,謝謝!
單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. //宏定義
  3. #define uint unsigned int
  5. #define Data_ADC0809 P0                   //定義P0口為Data_ADC0809
  6. //sbit PARSER = P2^0;                              //串并行控制位
  7. //sbit BYTE = P2^1;                                //高低字節(jié)控制位
  8. //sbit RC = P2^4;                                  //讀取轉(zhuǎn)換控制位
  9. //sbit BUSY = P2^2;        //忙狀態(tài)位
  10. //函數(shù)聲明
  11. extern uchar ADC0809();
  12. sbit ST=P2^0;
  13. sbit EOC=P2^1;
  14. sbit OE=P2^2;
  15. sbit ADDR_A = P3^5;                              //低位地址控制位
  16. sbit ADDR_B = P3^6;                              //低位地址控制位
  17. sbit ADDR_C = P3^7;        //高位地址控制位
  18. void ConfigUART(unsigned int baud);              //串行口配置函數(shù)
  19. void ConfigTimer0();                             //定時器0配置函數(shù)
  20. void SendData(unsigned char ch);                 //字符發(fā)送函數(shù)
  21. void SendString(char *s);                        //字符串發(fā)送函數(shù)
  22. void GetVoltage();                               //ADC電壓獲取函數(shù)
  23. unsigned int Linear(double v);                   //線性插值函數(shù),參數(shù)v為實測電壓
  24. void DataProcess();                              //數(shù)據(jù)處理函數(shù)
  25. void LedBufRefresh();                            //數(shù)碼管顯示緩沖區(qū)刷新函數(shù)
  26. void UartSend();        //串口數(shù)據(jù)發(fā)送函數(shù)
  27. void delay(uint t);
  28. unsigned char voltage[] = {'0','.','0','0','0',0};
  29. unsigned char time_used[] = {'0','0','0',0};
  30. unsigned char percentage[] = {'0','0','0',0};
  31. unsigned long j,time_used_value,result,percentage_value,voltage_value;
  32. unsigned int code time_sample[21]={0,18,36,54,72,90,108,126,144,162,180,198,216,234,252,270,288,306,324,342,360};
  33. double code voltage_sample[21]={4.35,4.24,4.135,4.005,3.92,3.889,3.858,3.826,3.8,3.78,3.762,3.743,3.725,3.705,3.686,3.667,3.65,3.628,3.492,3.05,2};
  34. //共陽數(shù)碼管顯示字符轉(zhuǎn)換表
  35. unsigned char code LedChar[] = {
  36.         0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
  37.     0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
  38. };
  39. //數(shù)碼管顯示緩沖區(qū),初值0x00確保啟動時都不亮
  40. unsigned char LedBuff[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  41. void main()
  42. {
  43.         ConfigUART(9600);                            //配置串行口工作模式及參數(shù)
  44.         ConfigTimer0();                              //配置定時器0用于數(shù)碼管刷新
  45.         EA = 1;                                      //打開總中斷
  46.         while(1)
  47.         {
  48.                    //正常模式
  49.                 if(Mode==0)
  50.                 {
  51.                         //讀取AD值
  52.                         temp=ADC0809();
  53. }
  54.                 GetVoltage();                            //獲取ADC電壓值
  55.                 DataProcess();                           //數(shù)據(jù)處理
  56.                 LedBufRefresh();                         //顯示緩沖區(qū)刷新
  57.                 UartSend();                              //串口發(fā)送
  58.                 for(j=0;j<30000;j++);                    //延時讀取
  59.         }
  60. }
  61. /* 數(shù)據(jù)處理函數(shù) */
  62. void DataProcess()
  63. {
  64.         /* 計算電壓值 */
  65.         voltage_value = (unsigned long)(((double)result * 10 / 32767) * 1000 + 0.5);
  66.         /* 電壓值數(shù)組 */
  67.         voltage[4] = '0' + voltage_value % 10;
  68.         voltage[3] = '0' + (voltage_value /10) % 10;
  69.         voltage[2] = '0' + (voltage_value /100) % 10;
  70.         voltage[0] = '0' + (voltage_value /1000) % 10;
  71.         /* 剩余用時數(shù)組 */
  72.         time_used_value =  Linear((double)result * 10 / 32767);
  73.         time_used[2] = '0' + time_used_value % 10;
  74.         time_used[1] = '0' + (time_used_value / 10) % 10;
  75.         time_used[0] = '0' + (time_used_value / 100) % 10;
  76.         /* 百分比數(shù)組 */
  77.         percentage_value =
  78.         (unsigned long)((double)(180000 - time_used_value * 500) / 168000 * 100 + 0.5);//改過數(shù)據(jù)
  79.         percentage[2] = '0' + percentage_value % 10;
  80.         percentage[1] = '0' + (percentage_value / 10) % 10;
  81.         percentage[0] = '0' + (percentage_value / 100) % 10;
  82.         if((percentage_value / 100) % 10)            //處理百分比最高位
  83.         {
  84.                 percentage[0] = '0' + (percentage_value / 100) % 10;
  85.         }
  86.         else
  87.         {
  88.                 percentage[0] = ' ';
  89.         }
  90. }
  91. /* 線性插值函數(shù),參數(shù)v為實測電壓,返回插值時間結(jié)果 */
  92. unsigned int Linear(double v)
  93. {
  94.         unsigned int i,t1,t2,t;
  95.         double v1,v2;
  96.         if(v >= 4.35)                                //大于最大電壓
  97.         {
  98.                 t = 0;
  99.                 return t;
  100.         }
  101.         if(v <= 2)                                   //小于最小電壓
  102.         {
  103.                 t = 360;
  104.                 return t;
  105.         }
  106.         for(i=0; i<21; i++)                          //遍歷插值范圍
  107.         {
  108.                 if(voltage_sample[i] < v)
  109.                 {
  110.                         v1 = voltage_sample[i-1];
  111.                         v2 = voltage_sample[i];
  112.                         t1 = time_sample[i-1];
  113.                         t2 = time_sample[i];
  114.                         t = t2 - (v - v2) * (double)(t2 - t1) / (v1 - v2);
  115.                         break;                               //計算插值結(jié)果t
  116.                 }
  117.                 else if(voltage_sample[i] == v)
  118.                 {
  119.                         t = time_sample[i];                  //恰好取采樣值
  120.                         break;
  121.                 }
  122.         }
  123.         return t;
  124. }
  125. /* ADC電壓獲取函數(shù) */
  126. void GetVoltage()
  127. uchar ADC0809()
  128. {
  129.         uchar temp_=0x00;
  130.         //初始化高阻太
  131.         OE=0;
  132.         //轉(zhuǎn)化初始化
  133.         ST=0;
  134.         //開始轉(zhuǎn)換
  135.         ST=1;
  136.         ST=0;
  137.         //外部中斷等待AD轉(zhuǎn)換結(jié)束
  138.         while(EOC==0)
  139.         //讀取轉(zhuǎn)換的AD值
  140.         OE=1;
  141.         temp_=Data_ADC0809;
  142.         OE=0;
  143.         return temp_;
  144. }
  145. /* 定時器0中斷服務(wù)函數(shù) */
  146. void InterruptTimer0() interrupt 1
  147. {
  148.         static unsigned char i = 0;                  //動態(tài)掃描的索引
  149.     TH0 = 0xFC;                                  //重新加載初值
  150.     TL0 = 0x67;
  151.                                                  //以下代碼完成數(shù)碼管動態(tài)掃描刷新
  152.     P1 = 0x00;        //顯示消隱
  153.     switch(i)                                    //動態(tài)掃描
  154.     {
  155.         case 0: ADDR_C = 0; ADDR_B = 0; ADDR_A = 0; i++; P1=LedBuff[0]; break;
  156.         case 1: ADDR_C = 0; ADDR_B = 0; ADDR_A = 1; i++; P1=LedBuff[1]; break;
  157.         case 2: ADDR_C = 0; ADDR_B = 1; ADDR_A = 0; i++; P1=LedBuff[2]; break;
  158.         case 3: ADDR_C = 0; ADDR_B = 1; ADDR_A = 1; i++; P1=LedBuff[3]; break;
  159.                 case 4: ADDR_C = 1; ADDR_B = 0; ADDR_A = 0; i++; P1=LedBuff[4]; break;
  160.         case 5: ADDR_C = 1; ADDR_B = 0; ADDR_A = 1; i++; P1=LedBuff[5]; break;
  161.         case 6: ADDR_C = 1; ADDR_B = 1; ADDR_A = 0; i=0; P1=LedBuff[6]; break;
  162.         //case 7: ADDR_C = 1; ADDR_B = 1; ADDR_A = 1; i=0; P1=LedBuff[7]; break;
  163.                 //保留最低為數(shù)碼管不使用
  164.         default: break;
  165.     }
  166. }
  167. /* 數(shù)碼管顯示緩沖區(qū)刷新函數(shù) */
  168. void LedBufRefresh()
  169. {
  170.         LedBuff[6] = ~LedChar[percentage_value % 10];
  171.         LedBuff[5] = ~LedChar[(percentage_value / 10) % 10];
  172.         if((percentage_value / 100) % 10)                           //百分比最高位處理
  173.         {
  174.                 LedBuff[4] = ~LedChar[(percentage_value / 100) % 10];   //為1則顯示
  175.         }
  176.         else
  177.         {
  178.                 LedBuff[4] = 0;                                         //否則不顯示
  179.         }
  180.         LedBuff[3] = ~LedChar[voltage_value % 10];
  181.         LedBuff[2] = ~LedChar[(voltage_value /10) % 10];
  182.         LedBuff[1] = ~LedChar[(voltage_value /100) % 10];
  183.         LedBuff[0] = ~(LedChar[(voltage_value /1000) % 10] & 0x7F); //最高位小數(shù)點處理
  184. }
  185. void UartSend()
  186. {
  187.         SendString("當(dāng)前電壓:");
  188.         SendString(voltage);
  189.         SendString("V");
  190. //        SendString("    已用時間:");
  191. //        SendString(time_used);
  192. //        SendString("Min");
  193.         SendString("    剩余電量:");
  194.         SendString(percentage);
  195.         SendString("%\r\n");
  196. }
  197. /* 串口配置函數(shù),baud-通信波特率 */
  198. void ConfigUART(unsigned int baud)
  199. {
  200.     SCON  = 0x50;                                //配置串口為模式1
  201.     TMOD &= 0x0F;                                //清零T1的控制位
  202.     TMOD |= 0x20;                                //配置T1為模式2
  203.     TH1 = 256 - (11059200/12/32)/baud;           //計算T1重載值
  204.     TL1 = TH1;                                   //初值等于重載值
  205.     ET1 = 0;                                     //禁止T1中斷
  206.     ES  = 1;                                     //使能串口中斷
  207.     TR1 = 1;                                     //啟動T1
  208. }
  209. /* 定時器0配置函數(shù) */
  210. void ConfigTimer0()
  211. {
  212.     TMOD &= 0xF0;                                //清零T0的控制位
  213.         TMOD |= 0x01;                                //設(shè)置T0為模式1
  214.     TH0  = 0xFC;                                 //為T0賦初值0xFC67,定時1ms
  215.     TL0  = 0x67;
  216.         ET0  = 1;                                    //使能T0中斷
  217.     TR0  = 1;                                    //啟動T0
  218. }
  219. /* UART中斷服務(wù)函數(shù) */
  220. void InterruptUART() interrupt 4
  221. {
  222.     if(RI)                                       //接收到字節(jié)
  223.     {
  224.         RI = 0;                                  //清零接收中斷標(biāo)志位
  225.     }
  226.     if(TI)                                       //字節(jié)發(fā)送完畢
  227.     {
  228.         TI = 0;                                  //清零發(fā)送中斷標(biāo)志位
  229.     }
  230. }
  231. /* UART字符發(fā)送函數(shù) */
  232. void SendData(unsigned char ch)
  233. {
  234.     SBUF = ch;                                   //啟動發(fā)送
  235.         while(!TI);                                  //等待結(jié)束
  236. }
  237. /* UART字符串發(fā)送函數(shù) */
  238. void SendString(unsigned char *s)
  239. {
  240.     while(*s)                                    //循環(huán)發(fā)送
  241.     {
  242.         SendData(*s++);
  243.     }
  244. }
編譯后報錯如下:
Build target 'Target 1'
compiling main.c...
MAIN.C(57): error C202: 'Mode': undefined identifier
MAIN.C(60): error C202: 'temp': undefined identifier
MAIN.C(138): error C132: 'ADC0809': not in formal parameter list
MAIN.C(138): error C141: syntax error near '{'
MAIN.C(139): error C244: 'temp_': can't initialize, bad type or class
MAIN.C(139): error C132: 'temp_': not in formal parameter list
MAIN.C(141): error C244: 'OE': can't initialize, bad type or class
MAIN.C(141): error C132: 'OE': not in formal parameter list
MAIN.C(143): error C244: 'ST': can't initialize, bad type or class
MAIN.C(143): error C132: 'ST': not in formal parameter list
MAIN.C(145): error C244: 'ST': can't initialize, bad type or class
MAIN.C(145): error C132: 'ST': not in formal parameter list
MAIN.C(146): error C244: 'ST': can't initialize, bad type or class
MAIN.C(146): error C132: 'ST': not in formal parameter list
MAIN.C(148): error C141: syntax error near 'while'
MAIN.C(148): error C141: syntax error near '==', expected ')'
MAIN.C(150): error C231: 'OE': redefinition
MAIN.C(151): error C247: non-address/-constant initializer
MAIN.C(152): error C279: 'OE': multiple initialization
MAIN.C(152): error C231: 'OE': redefinition
MAIN.C(153): error C141: syntax error near 'return'
MAIN.C(154): error C141: syntax error near '}'
Target not created
ID:165455 發(fā)表于 2020-8-11 16:25 | 只看該作者
直接根據(jù)錯誤提示改就好了。你的error都是“未定義”,“重復(fù)定義”,“類型出錯”這種。很容易排查的
ID:654028 發(fā)表于 2020-8-11 17:24 | 只看該作者
沒有聲明變量。要定義變量。134行少了分號等等,總之雙擊錯誤去定位,然后去改,很容易的,這是基本的錯誤。
ID:143767 發(fā)表于 2020-8-12 10:15 | 只看該作者
程序經(jīng)過改錯就剩下一個地方有問題,不知怎樣解決,求高手指點,謝謝
#include<reg52.h>
//ADC0809
sbit ST=P2^0;
sbit EOC=P2^1;
sbit OE=P2^2;
//函數(shù)聲明
//void GetVoltage();                               //ADC電壓獲取函數(shù)
uhar temp=0;
        EA = 1;                                      //打開總中斷
                //GetVoltage();                            //獲取ADC電壓值
                        //讀取AD值
                temp=ADC0809();
void DataProcess()
        /* 計算電壓值 */
        /* 電壓值數(shù)組 */
        /* 剩余用時數(shù)組 */
        /* 百分比數(shù)組 */
        percentage_value =
        double v1,v2;
                t = 0;
                return t;
        if(v <= 2)                                   //小于最小電壓
                t = 360;
                return t;
                        break;
        return t;
//ADC0809讀取信息
uchar ADC0809()
uchar temp_=0x00;
        //初始化高阻太
        OE=0;
        //轉(zhuǎn)化初始化
        ST=0;
        //開始轉(zhuǎn)換
        ST=1;
        ST=0;
        while(EOC==0)
        //讀取轉(zhuǎn)換的AD值
        OE=1;
        temp_=Data_ADC0809;
        OE=0;
        return temp_;
    TL0 = 0x67;
    P1 = 0x00;        //顯示消隱
                //保留最低為數(shù)碼管不使用
        default: break;
void UartSend()
        SendString("V");
    ET1 = 0;                                     //禁止T1中斷
    ES  = 1;                                     //使能串口中斷
    TR1 = 1;                                     //啟動T1
/* 定時器0配置函數(shù) */
void ConfigTimer0()
    TL0  = 0x67;
        ET0  = 1;                                    //使能T0中斷
    TR0  = 1;                                    //啟動T0
    if(RI)                                       //接收到字節(jié)
        SendData(*s++);
報錯信息:
compiling main.c...
MAIN.C(14): error C129: missing ';' before 'ADC0809'
Target not created
ID:810978 發(fā)表于 2020-8-12 10:37 | 只看該作者
建議檢查錯誤的常用單詞還是要記一下的 對修改錯誤很有幫助
ID:143767 發(fā)表于 2020-8-12 17:45 | 只看該作者
就是查不出所以才求助各位的,謝謝提醒
ID:105449 發(fā)表于 2020-8-13 15:57 | 只看該作者
依提示修改,注意在輸入代碼前一定要切換到英文輸入模式,否則會報syntax error,特別是在沒切換的時候輸了空格,一時不知問題出在哪里。
無效樓層,該帖已經(jīng)被刪除
9#
ID:814007 發(fā)表于 2020-8-13 23:26 | 只看該作者
dj3365191 發(fā)表于 2020-8-12 10:15
#include
#define Data_ADC0809 P ...
在#include<reg52.h>下面添加#define uchar unsigned char
無效樓層,該帖已經(jīng)被刪除
11#
ID:143767 發(fā)表于 2020-8-14 16:36 | 只看該作者
菜中菜 發(fā)表于 2020-8-13 23:26
在#include下面添加#define uchar unsigned char
謝謝指點,加入以后出現(xiàn)如下錯誤信息:
compiling main.c...
MAIN.C(29): error C129: missing ';' before 'temp'
Target not created
ID:155507 發(fā)表于 2020-8-15 14:33 | 只看該作者
你這里錯了
uhar temp=0;
改成這樣:
unsigned char temp=0;
ID:744327 發(fā)表于 2020-8-15 15:18 | 只看該作者
uhar temp=0;沒有定義,需要加這一條語句 #define uchar unsigned char
