查看: 5830|回復: 1
STM32F407用0.96寸OLED顯示屏實現按鍵切換屏幕 源程序
ID:591382 發表于 2020-8-8 12:05 | 顯示全部樓層 |閱讀模式
//主要程序代碼如下所示:
int main(void)
u8 key;
Stm32_Clock_Init(336,8,2,7);//設置時鐘,168Mhz
delay_init(168);   //延時初始化
uart_init(84,115200);  //初始化串口波特率為115200
LED_Init();     //初始化LED
  OLED_Init();    //初始化OLED
KEY_Init();   //初始化與按鍵連接的硬件接口
LED0=!LED0;
  key=KEY_Scan(0);  //得到鍵值
  if(key)
   switch(key)
    case KEY0_PRES:
     OLED_ShowString(0,0,"music",12);
      OLED_ShowString(0,10,"hello",12);
      OLED_ShowString(0,20,"cycle",12);
      OLED_ShowString(0,30,"world",12);
      OLED_Refresh_Gram();//更新顯示到OLED
      delay_us(1000);
          break;
        case KEY1_PRES:
          OLED_ShowString(0,0,"enter",12);
          OLED_ShowString(0,10,"dream",12);
      OLED_ShowString(0,20,"eager",12);
      OLED_ShowString(0,30,"drink",12);
      delay_us(1000);
          break;
    case KEY2_PRES:
          OLED_ShowString(0,0,"final",12);
          OLED_ShowString(0,10,"flash",12);
      OLED_ShowString(0,20,"float",12);
      OLED_ShowString(0,30,"fruit",12);
      delay_us(1000);
          break;
  }else delay_ms(10);
全部程序51hei下載地址:
OLED顯示實驗(按鍵切換).7z (110.45 KB, 下載次數: 130)
ID:634672 發表于 2021-4-27 08:09 | 顯示全部樓層
請問我怎么沒找到翻頁的程序啊
