搞了半天了,用標準庫最高配置66M,hal庫都配最高只能配置到64M,難道和STM32F103一樣?
標準庫配置如下:
static void SetSysClock(void)
__IO uint32_t HSIStartUpStatus = 0;
// 把RCC外設初始化成復位狀態
RCC_DeInit();
//使能HSI, HSI=16M
RCC_HSICmd(ENABLE);
// 等待 HSI 就緒
HSIStartUpStatus = RCC->CR & RCC_CR_HSIRDY;
// 只有 HSI就緒之后則繼續往下執行
if (HSIStartUpStatus == RCC_CR_HSIRDY) {
// 如果要超頻就得在這里下手啦
// 設置PLL來源時鐘,設置VCO分頻因子m,設置VCO倍頻因子n,
// 設置系統時鐘分頻因子p,設置OTG FS,SDIO,RNG分頻因子q
RCC_PLLConfig(RCC_PLLSource_HSI, 16, 264, 4, 7);
// 使能PLL
RCC_PLLCmd(ENABLE);
// 等待 PLL穩定
while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {}
//開啟 OVER-RIDE模式,以能達到更高頻率
// PWR->CR |=PWR_CR_VOS;
// while ((PWR->CSR & PWR_CSR_ODRDY) == 0) { }
// PWR->CR |= PWR_CR_ODSWEN;
// while ((PWR->CSR & PWR_CSR_ODSWRDY) == 0) {}
// 配置FLASH預取指,指令緩存,數據緩存和等待狀態
FLASH->ACR = FLASH_ACR_PRFTEN
| FLASH_ACR_ICEN
|FLASH_ACR_DCEN
|FLASH_ACR_LATENCY_3WS;
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
// 讀取時鐘切換狀態位,確保PLLCLK被選為系統時鐘
while (RCC_GetSYSCLKSource() != 0x08) {}
// 調壓器電壓輸出級別配置為1,以便在器件為最大頻率
// 工作時使性能和功耗實現平衡
RCC->APB1ENR |= RCC_APB1ENR_PWREN;
PWR->CR |= PWR_CR_VOS;
// HCLK = SYSCLK / 1
RCC_HCLKConfig(RCC_SYSCLK_Div1);
// PCLK2 = HCLK / 2
RCC_PCLK2Config(RCC_HCLK_Div2);
// PCLK1 = HCLK / 4
RCC_PCLK1Config(RCC_HCLK_Div4);
} else {
// HSI啟動出錯處理
while (1) {}
hal庫配置如下:
void SystemClock_Config(void)
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable Power Control clock */
__HAL_RCC_PWR_CLK_ENABLE();
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
/* Enable HSI Oscillator and activate PLL with HSI as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 0x10;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 16;
RCC_OscInitStruct.PLL.PLLN = 384;
RCC_OscInitStruct.PLL.PLLP = 6;
RCC_OscInitStruct.PLL.PLLQ = 7;
if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
