查看: 3970|回復: 6
STM32f405 ADC配置的問題
ID:720684 發表于 2020-7-30 22:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
STM32F405的adc采集配置中感覺ADC的設置都對了為什么采集不到數據呢。下面是程序,有錯誤的地方幫忙指出來謝謝。
void ADC1_Init()
DMA_InitTypeDef DMA_InitStructure;
ADC_CommonInitTypeDef  ADC_CommonInitStructure;
ADC_InitTypeDef ADC_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ADC1,ENABLE);   //ADC1復位
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
DMA_DeInit(DMA2_Stream0);
DMA_InitStructure.DMA_Channel= DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue;      //(u32)&ADC_ConvertedValue接收到的數據存放在ADC_ConvertedValue里面
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory ; //外設設為數據源
DMA_InitStructure.DMA_BufferSize = N*M;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//數據寬度為16位
  DMA_InitStructure.DMA_MemoryDataSize=DMA_MemoryDataSize_HalfWord; //數據寬度為16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  //工作在循環緩存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA通道X擁有高優先級
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;   //指定fifo模式還是直接模式
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;//指定fifo閾值
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; //內存突發每次傳輸一個數據
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;//外設突發每次傳輸一個數據
//DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道X沒有設置為內存到內存傳輸
DMA_Init(DMA2_Stream0,&DMA_InitStructure);   //根據DMA_InitStruct中指定的參數初始化DMA的通道
DMA_Cmd(DMA2_Stream0,ENABLE);
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
// NVIC_InitStructure.NVIC_IRQChannel =DMA2_Stream0_IRQn;
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
// NVIC_Init(&NVIC_InitStructure);
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;//獨立模式,即軟件觸發模式
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;//兩個采樣階段之間的延遲5個時鐘
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; //DMA失能
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;//預分頻4分頻。ADCCLK=PCLK2/4=84/4=21Mhz,ADC時鐘最好不要超過36Mhz //配置ADC的時鐘分頻
  ADC_CommonInit(&ADC_CommonInitStructure);//初始化
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;//12位模式
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;//模數轉換工作在掃描模式
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//模數轉換工作在連續掃描模式
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//
//  ADC_InitStructure.ADC_ExternalTrigConv =ADC_ExternalTrigConv_Ext_IT11;//
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//右對齊
  ADC_InitStructure.ADC_NbrOfConversion = 1;//通道數
  ADC_Init(ADC1, &ADC_InitStructure);//ADC初始化
//ADC_ExternalTrigInjectedConvConfig(ADC1,ADC_ExternalTrigInjecConv_T2_TRGO);
ADC_RegularChannelConfig(ADC1,ADC_Channel_12,1,ADC_SampleTime_56Cycles);
////// ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);DMA節點為多adc模式開啟或者關斷
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
DMA_ITConfig(DMA2_Stream0,DMA_IT_TC, ENABLE);//開啟DMA中斷
  ADC_Cmd(ADC1, ENABLE);//開啟AD轉換器
ADC_SoftwareStartConv(ADC1);
// while(RESET == DMA_GetFlagStatus(DMA2_Stream0,DMA_FLAG_TCIF0));
ID:739545 發表于 2020-7-31 08:49 | 只看該作者
一個ADC采集需要這么多配置么?
ID:804115 發表于 2020-7-31 11:43 | 只看該作者
ADC的時鐘好像沒開哎,還有ADC的時鐘源也要選一下。
ID:720684 發表于 2020-7-31 21:59 | 只看該作者
lovezjf234 發表于 2020-7-31 08:49
一個ADC采集需要這么多配置么?
用了DMA
ID:720684 發表于 2020-7-31 22:00 | 只看該作者
1692483014 發表于 2020-7-31 11:43
大概第7行APB2開了的
ID:804115 發表于 2020-8-1 01:10 | 只看該作者
精通點燈 發表于 2020-7-31 22:00
大概第7行APB2開了的
你的第七行是復位ADC,不是打開時鐘,看清楚哦!
你的第七行:
ADC時鐘打開:
RCC_APB2PeriphclockCmd( RCC_APB2Periph_ADC1, ENABLE);
ID:720684 發表于 2020-8-2 22:53 | 只看該作者
1692483014 發表于 2020-8-1 01:10
你的第七行:
謝謝了
