基于MM32F103 USB Custom_HID 通訊例程,基于32位 ARM Cortex M3 的MM32F103xBx8的例程
- /* Includes ------------------------------------------------------------------*/
- #include "MM32F103.h"
- #include "usb_lib.h"
- #include "hw_config.h"
- #include "usbio.h"
- #include "usb_regs.h"
- #include "usb_pwr.h"
- #include "usb_desc.h"
- #include "sys.h"
- #include "uart.h"
- #include "delay.h"
- #include "led.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Extern variables ----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- void Delay(__IO uint32_t nCount);
- extern uint8_t Flag_Receive;
- /* Private functions ---------------------------------------------------------*/
- * Function Name : main.
- * Description : main routine.
- * Input : None.
- * Output : None.
- * Return : None.
- uint8_t table_data[64]={
- 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
- int main(void)
- delay_init();
- uart_initwBaudRate(115200);
- LED_Init();
- Set_System();
- USB_Interrupts_Config();
- Set_USBClock();
- USB_Init();
- printf("System Initial Success\r\n");
- while (1)
- if(bDeviceState == CONFIGURED) //等待USB初始化完成
- // if(Flag_Receive)
- // USB_Send_Buffer[0] = 0xaa;
- // USB_Send_Buffer[1] = 0x55;
- // USB_Send_Buffer[2] = 0xaa;
- // USB_Send_Buffer[3] = 0x55;
- // USB_Send_Buffer[4] = 0xaa;
- // USB_Send_Buffer[5] = 0x55;
- // USB_SendData(USB_Send_Buffer,64);
- // Flag_Receive = 0;
- USB_SendData(table_data,5);
- delay_ms(5000);
- //USB_SendData(table_data,64);
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nCount: specifies the delay time length.
- * Output : None
- * Return : None
- for(; nCount!= 0;nCount--);
- #ifdef USE_FULL_ASSERT
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert_param error line source number
- * Output : None
- * Return : None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while(1)
- #endif
- /******************* (C) COPYRIGHT 2009 Mindmotion *****END OF FILE****/
MM32F103_USB_Custom_HID.7z
(161.23 KB, 下載次數(shù): 43)
2020-7-30 16:39 上傳
USB HID 下載積分: 黑幣 -5
