查看: 3254|回復(fù): 1
51單片機+HX711電子秤源程序+視頻
ID:523178 發(fā)表于 2020-7-24 19:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機驅(qū)動HX711,實現(xiàn)稱重、單價選擇、計價,顯示使用的是LCD1602。已通過軟件標定校準和砝碼校準。附上視頻鏈接:鏈接:https://pan.baidu.com/s/1laQH_O64TADYU5DC_vQFNQ
提取碼:ljfe和源碼。
  1. #include "lcd1602.h"
  2. #include "hx711.h"
  3. #include "key.h"
  4. typedef unsigned char u8;
  5. typedef unsigned int u16;
  6. u8 code word[] = "Weight:  .   KG";
  7. u8 word1[] = "SP:";
  8. u8 Weight_Val[5];
  9. u8 Price_Val[4];
  10. float Total_Price;
  11. void Weight_Datapro(unsigned int value)
  12. {
  13.                 Weight_Val[0] = value / 10000;
  14.                 Weight_Val[1] = value % 10000 / 1000;
  15.                 Weight_Val[2] = value % 1000 / 100;
  16.                 Weight_Val[3] = value % 100 / 10;
  17.                 Weight_Val[4] = value % 10;
  18.
  19.                 DisplayOneChar(7,0,Weight_Val[0]+0x30);
  20.                 DisplayOneChar(8,0,Weight_Val[1]+0x30);
  21.                 DisplayOneChar(10,0,Weight_Val[2]+0x30);
  22.                 DisplayOneChar(11,0,Weight_Val[3]+0x30);
  23.                 DisplayOneChar(12,0,Weight_Val[4]+0x30);
  24. }
  25. void Price_Datapro(unsigned int value)
  26. {
  27.                 value /= 10;
  28.                 Price_Val[0] = value / 1000;
  29.                 Price_Val[1] = value % 1000 /100;
  30.                 Price_Val[2] = value % 100 / 10;
  31.                 Price_Val[3] = value % 10;
  32.
  33.                 DisplayOneChar(8,1,Price_Val[0]+0x30);
  34.                 DisplayOneChar(9,1,Price_Val[1]+0x30);
  35.                 DisplayOneChar(10,1,'.');
  36.                 DisplayOneChar(11,1,Price_Val[2]+0x30);
  37.                 DisplayOneChar(12,1,Price_Val[3]+0x30);
  38.                 DisplayOneChar(13,1,'
  39. );
  40. }
  41. void main(void)
  42. {
  43.                 LcdInit();
  44.                 LcdShowStr(0, 0, word);
  45.                 LcdShowStr(0, 1, word1);
  46.                 LcdShowStr(5, 1, "TP:");
  47.                 Get_Maopi();
  48.
  49.                 while(1)
  50.                 {
  51.                                 Key_Down();
  52.                                 Get_Weight();
  53.                                 Weight_Datapro(Weight_Shiwu);
  54.                                 Total_Price = price * Weight_Shiwu;
  55.                                 Price_Datapro(Total_Price);
  56.                 }
  57. }
QX-1602.rar (47.02 KB, 下載次數(shù): 69)
HX711參考驅(qū)動程序(C51).pdf (46.28 KB, 下載次數(shù): 50)
收藏收藏5 分享淘帖 頂1 踩
ID:56960 發(fā)表于 2020-7-30 11:05 | 只看該作者
樓主發(fā)帖分享不容易,我來坐個沙發(fā)!
