查看: 2501|回復: 0
nodemcu esp8266 網(wǎng)絡(luò)編譯固件
ID:370473 發(fā)表于 2020-7-24 00:14 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
latest
19模塊:dht, enduser_setup, file, gpio, http, i2c, mdns, mqtt, net, node, pwm, sjson, spi, tmr, uart, websocket, wifi, wps, tls.
This was built against the master branch and includes the following modules: dht, enduser_setup, file, gpio, http, i2c, mdns, mqtt, net, node, pwm, sjson, spi, tmr, uart, websocket, wifi, wps, tls.
yesterday16模塊:dht, enduser_setup, file, gpio, http, i2c, mqtt, net, node, pwm, spi, tmr, uart, wifi, wps, tls
This was built against the master branch and includes the following modules: dht, enduser_setup, file, gpio, http, i2c, mqtt, net, node, pwm, spi, tmr, uart, wifi, wps, tls
nodemcu_固件包_esp8266.rar
1.96 MB, 下載次數(shù): 16, 下載積分: 黑幣 -5
參與人數(shù) 1黑幣 +50 收起 理由
