單片機(jī)源程序如下:
- #include<reg52.h>
- sbit IN1=P2^7;
- sbit IN2=P2^6;
- sbit ENA=P2^5;
- bit flag1s=0;//1s定時(shí)標(biāo)志
- unsigned char T0RH=0;
- unsigned char T0RL=0;
- int temp;//讀取到的當(dāng)前溫度值
- unsigned char len;
- int intT,decT;//溫度值的整數(shù)和小數(shù)部分
- unsigned char str[12];
- void Compare();
- void GetTemp();
- void ConfigTimer0(unsigned int ms);
- unsigned char IntToString(unsigned char *str,int dat);
- extern bit Start18B20();
- extern bit Get18B20Temp(int *temp);
- extern void InitLcd1602();
- extern void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str);
- void main()
- bit res;
- EA=1;
- ConfigTimer0(10);//T0定時(shí)10ms
- Start18B20();//啟動(dòng)DS18B20
- InitLcd1602();//初始化液晶
- while(1)
- if(flag1s)//每秒更新一次溫度
- flag1s=0;
- res=Get18B20Temp(&temp);//讀取當(dāng)前溫度
- if(res)//讀取成功時(shí),刷新當(dāng)前溫度顯示
- GetTemp();
- LcdShowStr(0,0,"Welcome to use");//顯示字符及溫度值
- LcdShowStr(0,1,"Current T:");
- LcdShowStr(10,1,str);
- Compare();
- else //讀取失敗時(shí),提示錯(cuò)誤信息
- LcdShowStr(0,0,"error!");
- Start18B20();//重新啟動(dòng)下一次轉(zhuǎn)換
- /*溫度獲取函數(shù),獲取當(dāng)前環(huán)境溫度值并保存在str數(shù)組中*/
- void GetTemp()
- intT=temp>>4;//分離出溫度值整數(shù)部分
- decT=temp &0x0F;//分離出溫度值小數(shù)部分
- len=IntToString(str,intT);//整數(shù)部分轉(zhuǎn)換成字符串
- str[len++]='.';
- decT=(decT*10)/16;//二進(jìn)制的小數(shù)部分轉(zhuǎn)換為1位十進(jìn)制位
- str[len++]=decT+'0';//十進(jìn)制小數(shù)位再轉(zhuǎn)換為ASCII字符
- while(len<6)//用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
- str[len++]=' ';
- str[len++]='\0';
- /*延時(shí)函數(shù),用于PWM控制*/
- void delay(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- /*比較函數(shù),通過(guò)溫度值的比較設(shè)置電機(jī)的轉(zhuǎn)速*/
- void Compare()
- unsigned int i=0;
- unsigned char j;
- if((intT>= 24) && (intT<26)) //以兩度為一個(gè)溫差范圍,并設(shè)溫度范圍索引
- j=0;
- else if((intT>=26) &&(intT<28))
- j=1;
- else if((intT>=28) &&(intT<30))
- j=2;
- else if(intT>=30)
- j=3;
- switch(j) //根據(jù)溫度索引設(shè)置電機(jī)轉(zhuǎn)速
- case 0: IN1=1;
- IN2=0;
- for(i=0;i<200;i++)
- ENA=1;
- delay(20);
- ENA=0;
- delay(30);
- break;
- case 1: IN1=1;
- IN2=0;
- ENA=1;
- delay(30);
- ENA=0;
- delay(30);
- break;
- case 2: IN1=1;
- IN2=0;
- ENA=1;
- delay(55);
- ENA=0;
- delay(30);
- break;
- case 3: IN1=1;
- IN2=0;
- ENA=1;
- break;
- default:break;
- /*整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長(zhǎng)度*/
- signed char i=0;
- unsigned char len=0;
- unsigned char buf[6];
- if(dat<0)//如果為負(fù)數(shù),首先取絕對(duì)值,并在指針上添加負(fù)號(hào)
- dat=-dat;
- *str++='-';
- len++;
- do{ //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
- buf[i++]=dat%10;
- dat /=10;
- }while(dat>0);
- len += i;//i最后的值就是有效字符的個(gè)數(shù)
- while(i-->0)//將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
- *str++=buf[i]+'0';
- *str='\0';
- return len;
- unsigned long tmp;
- tmp=11059200/12;
- tmp=(tmp*ms)/1000;
- tmp=65536-tmp;
- tmp=tmp+12;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
基于紅外感應(yīng)的溫控轉(zhuǎn)速型風(fēng)扇設(shè)計(jì)資料.7z
(72.26 KB, 下載次數(shù): 62)
2020-7-21 00:47 上傳
點(diǎn)擊文件名下載附件
溫控風(fēng)扇設(shè)計(jì)
評(píng)分
查看全部評(píng)分
