查看: 4113|回復: 3
籃球計分牌Proteus仿真 單片機源程序
籃球計分牌的程序和仿真
  1. #include "reg51.h"
  2. sbit SEG1 = P1^7;
  3. sbit SEG2 = P1^6;
  4. sbit SEG3 = P1^5;
  5. sbit SEG4 = P1^4;
  6. sbit MARK1 = P3^0;
  7. sbit MARK2 = P3^1;
  8. sbit MARK3 = P3^2;
  9. unsigned char MARK;
  10. char code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};        //段碼
  11. void delay(unsigned int t)
  12. {
  13.         while(t--);
  14. }
  15. void DigDisplay(void)
  16. {
  17.         unsigned char i;
  18.         for(i = 0;i < 4;i++)
  19.         {
  20.                 switch(i)         //位選,選擇點亮的數碼管,
  21.                 {
  22.                    case(0):
  23.                                 SEG4 = 0;SEG3 = 1;SEG2 = 1;SEG1 = 1;P2 = table[MARK % 10];break;
  24.                         case(1):
  25.                                 SEG4 = 1;SEG3 = 0;SEG2 = 1;SEG1 = 1;P2 = table[MARK % 100 / 10];break;
  26.                         case(2):
  27.                                 SEG4 = 1;SEG3 = 1;SEG2 = 0;SEG1 = 1;P2 = table[MARK % 1000 / 100];break;
  28.                         case(3):
  29.                                 SEG4 = 1;SEG3 = 1;SEG2 = 1;SEG1 = 1;P2 = table[MARK % 1000 / 1000];break;
  30.                 }
  31.                 delay(100); //間隔一段時間掃描
  32.                 P2 = 0x00;//消隱
  33.         }
  34. }
  35. void Points(void)
  36. {
  37.         if(MARK1 == 0)
  38.         {
  39.                 delay(500);
  40.                 if(MARK1 == 0)
  41.                 {
  42.                         MARK = MARK + 1;
  43.                 }
  44.                 while(!MARK1);
  45.         }
  46.
  47.         if(MARK2 == 0)
  48.         {
  49.                 delay(500);
  50.                 if(MARK2 == 0)
  51.                 {
  52.                         MARK = MARK + 2;
  53.                 }
  54.                 while(!MARK2);
  55.         }
  56.
  57.         if(MARK3 == 0)
  58.         {
  59.                 delay(500);
  60.                 if(MARK3 == 0)
  61.                 {
  62.                         MARK = MARK + 3;
  63.                 }
  64.                 while(!MARK3);
  65.         }
  66. }
  67. void main(void)
  68. {
  69.         while(1)
  70.         {
  71.                 Points();
  72.                 DigDisplay();
  73.         }
  74. }
計分牌.zip (78.96 KB, 下載次數: 27)
收藏收藏2 分享淘帖 頂 踩
ID:89286 發表于 2020-7-26 02:13 | 只看該作者
Thanks for sharing
ID:92643 發表于 2024-10-9 09:28 | 只看該作者
Proteus8.13版本的仿真
ID:344646 發表于 2025-4-28 16:40 | 只看該作者
可以跑起來
