我在程序里已經定義了E RW RS CS1 CS2等管腳,也都說明了,為什么在我自己畫的這個圖上面,這幾個管腳都沒有定義啊,但是在我參考的那個是可以顯示的,下面是程序,請問一下大佬們問題在哪
lcd.h:
- #ifndef __LCD_H
- #define __LCD_H
- #include "stm32f10x.h"
- #include "word.h"
- #include "sys.h"
- #define LCD12864_GPIO GPIOC
- #define LCD12864_Periph RCC_APB2Periph_GPIOC
- #define LCD12864_E_GPIO GPIO_Pin_8
- #define LCD12864_RW_GPIO GPIO_Pin_9
- #define LCD12864_RS_GPIO GPIO_Pin_10
- #define LCD12864_CS2_GPIO GPIO_Pin_11
- #define LCD12864_CS1_GPIO GPIO_Pin_12
- #define LCD12864_RES_GPIO GPIO_Pin_13
- #define LCD12864_DATA_GPIO GPIO_Pin_0|GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4| GPIO_Pin_5| GPIO_Pin_6|GPIO_Pin_7
- #define LCD12864_RES_0 GPIO_ResetBits(LCD12864_GPIO,LCD12864_RES_GPIO)
- #define LCD12864_RES_1 GPIO_SetBits(LCD12864_GPIO,LCD12864_RES_GPIO)
- #define LCD12864_E_0 GPIO_ResetBits(LCD12864_GPIO,LCD12864_E_GPIO)
- #define LCD12864_E_1 GPIO_SetBits(LCD12864_GPIO,LCD12864_E_GPIO)
- #define LCD12864_RW_W GPIO_ResetBits(LCD12864_GPIO,LCD12864_RW_GPIO)
- #define LCD12864_RW_R GPIO_SetBits(LCD12864_GPIO,LCD12864_RW_GPIO)
- #define LCD12864_RS_CMD GPIO_ResetBits(LCD12864_GPIO,LCD12864_RS_GPIO)
- #define LCD12864_RS_DATA GPIO_SetBits(LCD12864_GPIO,LCD12864_RS_GPIO)
- #define LCD12864_CS1_ON GPIO_ResetBits(LCD12864_GPIO,LCD12864_CS1_GPIO)
- #define LCD12864_CS1_OFF GPIO_SetBits(LCD12864_GPIO,LCD12864_CS1_GPIO)
- #define LCD12864_CS2_ON GPIO_ResetBits(LCD12864_GPIO,LCD12864_CS2_GPIO)
- #define LCD12864_CS2_OFF GPIO_SetBits(LCD12864_GPIO,LCD12864_CS2_GPIO)
- //開啟或關閉
- #define ON 1
- #define OFF 0
- //LCD命令
- #define CMD_DIS_ON 0X3F
- #define CMD_DIS_OFF 0X3E
- #define CMD_BUSY 0X80
- #define CMD_COLUNM 0XC0
- #define CMD_LINE 0X40
- #define CMD_PAGE 0XB8
- //顯示屏幕選擇
- #define DIS_NONE 0
- #define DIS_LEFT 1
- #define DIS_RIGHT 2
- #define DIS_ALL 3
- //尺寸
- #define SMALL 1
- #define MIDDLE 2
- #define LONG 3
- //方向選擇
- #define UP 1
- #define DOWN 2
- //內部處理函數
- void LCD_CMD_DIS(u8 Switch); //開關函數
- void LCD_CMD_COLUNM(u8 Colunm);//指定初始行
- void LCD_CMD_Line(u8 Line); //寫入列
- void LCD_CMD_COLUNM(u8 Colunm); //寫入頁
- void LCD_INITIAL_COLUNM(u8 Colunm);//初始行
- void LCD_DATA_WRIRE(u8 data); //寫一位數據
- void LCD_CMD_PAGE(u8 Page); //初始頁
- //外部調用函數
- void LCD_Init(void); //初始化
- void LCD_DIS_Char(u8 row,u8 col,u8* data,int size);//顯示字符
- void LCD_MODE_ROLL(u8 path,u8 step,u8 direction,u16 delay);//滾動模式
- void LCD_DIS_Number(u8 row,u8 col,float num,int size);//顯示數字
- void LCD_CLEAR_COL(u8 row);//清零一行
- void LCD_CLEAR_ALL(void);//清屏
- void LCD_DIS_WORD(u8 row,u8 col,u8* data,int size);//寫字
- #endif
- main.h:
- #include "delay.h"
- #include "sys.h"
- #include "lcd.h"
- #include "adc.h"
- #include "bsp_key.h"
- void display_20200505()
- u8 xym[5]={11,12,1,2,3};
- u8 time[2] = {13,14};
- u8 company[2]={17,18};
- LCD_DIS_PICTURE();
- LCD_CLEAR_ALL();
- LCD_DIS_WORD(2,25,xym,LONG);
- LCD_DIS_WORD(5,20,time,LONG);
- LCD_DIS_Char(5,50,"20200505",MIDDLE);
- LCD_CLEAR_ALL();
- LCD_DIS_WORD(1,20,company,LONG);
- LCD_DIS_Char(1,60,"g",MIDDLE);
- int main(void)
- u32 adc_data=1;
- u8 display_flage=0;
- u8 flage=0;
- u8* mode="g";
- u8 clean=0;
- LCD_Init();
- Key_GPIO_Config();
- ADC_GPIO_Config();
- display_20200505();
- while(1)
- lcd.c:
- #include "lcd.h"
- static u8 INITIAL_COLUNM=0;
- void LCD_FUNCTION_Config(void)
- GPIO_InitTypeDef LCD_Struct;
- RCC_APB2PeriphClockCmd(LCD12864_Periph,ENABLE);
- LCD_Struct.GPIO_Mode = GPIO_Mode_Out_PP;
- LCD_Struct.GPIO_Speed = GPIO_Speed_50MHz;
- LCD_Struct.GPIO_Pin = LCD12864_RES_GPIO;
- GPIO_Init(LCD12864_GPIO,&LCD_Struct);
- LCD_Struct.GPIO_Pin = LCD12864_E_GPIO;
- LCD_Struct.GPIO_Pin = LCD12864_RS_GPIO;
- LCD_Struct.GPIO_Pin = LCD12864_RW_GPIO;
- LCD_Struct.GPIO_Pin = LCD12864_CS1_GPIO;
- LCD_Struct.GPIO_Pin = LCD12864_CS2_GPIO;
- void LCD_GPIO_Config(void)
- LCD_Struct.GPIO_Mode = GPIO_Mode_Out_OD;
- LCD_Struct.GPIO_Pin = LCD12864_DATA_GPIO;
- void LCD_Init(void) //lcd初始化
- LCD_GPIO_Config();
- LCD_FUNCTION_Config();
- LCD12864_RES_0;
- delay_ms(10);
- LCD12864_RES_1;
- delay_ms(50);
- LCD_CMD_DIS(ON);
- LCD_INITIAL_COLUNM(INITIAL_COLUNM);
- void LCD_GPIO_MASK(u8 data) //數據掩碼包裝
- u16 mask;
- mask = GPIO_ReadOutputData(LCD12864_GPIO) & 0XFF00 ;
- mask = mask | data ;
- GPIO_Write(LCD12864_GPIO,mask);
- void LCD_CMD_BUSY(void) //忙檢測
- LCD12864_RS_CMD;
- LCD12864_RW_R;
- LCD12864_E_1;
- LCD_GPIO_MASK(0xFF);
- while(1)
- LCD12864_E_0;
- delay_us(2);
- LCD12864_E_1;
- if(!(GPIO_ReadInputData(LCD12864_GPIO)&CMD_BUSY))
- break;
- LCD12864_E_0;
- //parameter: ON/OFF
- LCD_CMD_BUSY();
- LCD12864_RS_CMD;
- LCD12864_RW_W;
- LCD12864_E_1;
- if(Switch)
- LCD_GPIO_MASK(CMD_DIS_ON);
- else
- LCD_GPIO_MASK(CMD_DIS_OFF);
- delay_us(2);
- LCD12864_E_0;
- void LCD_DIS_SELECT(u8 select) //0全滅 1左屏 2右屏 3全屏
- select%=4;
- switch(select)
- case DIS_RIGHT:
- LCD12864_CS2_ON;
- LCD12864_CS1_OFF;
- break;
- case DIS_LEFT:
- LCD12864_CS2_OFF;
- LCD12864_CS1_ON;
- break;
- case DIS_ALL:
- LCD12864_CS2_ON;
- LCD12864_CS1_ON;
- break;
- case DIS_NONE:
- LCD12864_CS2_OFF;
- LCD12864_CS1_OFF;
- break;
- //指令起始行
- //parameter: 0-63
- Colunm%=64;
- Colunm = 64 - Colunm;
- LCD_CMD_BUSY();
- LCD12864_RS_CMD;
- LCD12864_RW_W;
- LCD12864_E_1;
- Colunm = CMD_COLUNM|Colunm;
- LCD_GPIO_MASK(Colunm);
- delay_us(2);
- LCD12864_E_0;
- //指令寫入數據顯示列
- //parameter: 0-128
- Line %= 128;
- if(Line<64)
- LCD_DIS_SELECT(DIS_LEFT);
- else
- LCD_DIS_SELECT(DIS_RIGHT);
- LCD_CMD_BUSY();
- LCD12864_RS_CMD;
- LCD12864_RW_W;
- LCD12864_E_1;
- Line = CMD_LINE|Line;
- LCD_GPIO_MASK(Line);
- delay_us(2);
- LCD12864_E_0;
- //指令寫入數據顯示頁
- //parameter: 0-7
- Page%=8;
- LCD_CMD_BUSY();
- LCD12864_RS_CMD;
- LCD12864_RW_W;
- LCD12864_E_1;
- Page = CMD_PAGE|Page;
- LCD_GPIO_MASK(Page);
- delay_us(2);
- LCD12864_E_0;
- //寫入數據0-7行
- Colunm%=8;
- Colunm=Colunm-INITIAL_COLUNM/8;
- LCD_CMD_PAGE(Colunm);
- //計算數據長度
- u8 LCD_NUMS_SIZE(int num)
- u8 size=0;
- if(num==0)
- size=1;
- }else
- while(num)
- size++;
- num=num/10;
- return size;
- int LCD_POW(u8 mi) //計算10的次方
- int di=1;
- while(mi--)
- di=di*10;
- return di;
- void LCD_DATA_WRIRE(u8 data) //寫一位數據
- LCD_CMD_BUSY();
- LCD12864_RS_DATA;
- LCD12864_RW_W;
- LCD12864_E_1;
- LCD_GPIO_MASK(data);
- delay_us(2);
- LCD12864_E_0;
- //顯示一個字符 支持小、中尺寸 反側顯示
- //parameter: 行0-7 列0-127 data數據 size尺寸SMALL MIDDLE
- u8 length=0;
- u8 line;
- u8 i;
- row%=8;
- col%=128;
- LCD_CMD_Line(col);
- line=col-1;
- if(size==SMALL)
- LCD_CMD_COLUNM(row);
- while(data[length])
- for(i=0;i<6;i++)
- line+=1;
- if(line==64)
- LCD_CMD_Line(line);
- }else if(line==128)
- line=0;
- LCD_DATA_WRIRE(CHAR_SMALL[data[length]-32][i]);
- length++;
- }else if(size==MIDDLE)
- for(i=0;i<16;i++)
- line+=1;
- if(i==8)
- if(line<8)
- line=128-(8-line);
- else
- line-=8;
- LCD_CMD_COLUNM(row+1);
- else if(line==64)
- if(i<8)
- }else if(i>=8)
- line=0;
- if(i<8)
- }else if(i>=8)
- LCD_DATA_WRIRE(CHAR_MIDDLE[data[length]-32][i]);
- length++;
- //寫數字 支持小、中尺寸 數字可支持小數 小數位數只包括2位 反側顯示
- u8 line;
- u8 length;
- u8 i;
- u8 flag=0;
- float number=0;
- row%=8;
- col%=128;
- length=LCD_NUMS_SIZE((int)num);
- line=col-1;
- if(num-(int)num>0)
- flag=1;
- number=num;
- if(size==SMALL)
- LCD_CMD_COLUNM(row);//1行
- while(length--)//6位
- for(i=0;i<6;i++)
- line+=1;
- if(line==64)
- line=0;
- if(flag==2)
- LCD_DATA_WRIRE(CHAR_SMALL[14][i]);
- }else
- LCD_DATA_WRIRE(CHAR_SMALL[(int)num/LCD_POW(length)+16][i]);
- if(flag==2)
- flag=0;
- continue;
- num=(int)num%LCD_POW(length);
- if(flag==1&&length==0)
- flag=2;
- length=3;
- num=(int)((number- (int)number)*100);
- }else if(size==MIDDLE)//中尺寸
- while(length--)
- for(i=0;i<16;i++)
- line+=1;
- if(i==8)
- if(line<8)
- else
- line-=8;
- else if(line==64)
- if(i<8)
- }else if(i>=8)
- line=0;
- if(i<8)
- }else if(i>=8)
- if(flag==2)
- LCD_DATA_WRIRE(CHAR_MIDDLE[14][i]);
- }else
- LCD_DATA_WRIRE(CHAR_MIDDLE[(int)num/LCD_POW(length)+16][i]);
- if(flag==2)
- flag=0;
- continue;
- flag=2;
- length=3;
- num=(int)((number-(int)number)*100);
- }else if(size==LONG)//大尺寸
- while(length--)
- for(i=0;i<36;i++)
- line+=1;
- if(i==12)
- if(line<12)
- line=128-(12-line);
- else
- line-=12;
- }else if(i==24)
- if(line<12)
- else
- line-=12;
- LCD_CMD_COLUNM(row+2);
- else if(line==64)
- if(i<12)
- }else if(i>=12&&i<24)
- }else if(i>=24)
- line=0;
- if(i<12)
- }else if(i>=24)
- if(flag==2)
- LCD_DATA_WRIRE(NUMBER_LONG[10][i]);
- }else
- LCD_DATA_WRIRE(NUMBER_LONG[(int)num/LCD_POW(length)][i]);
- if(flag==2)
- flag=0;
- continue;
- flag=2;
- length=3;
- //寫漢字 支持中、大尺寸 data為庫
- u8 length=0;
- u8 i;
- u8 line;
- row%=8;
- col%=128;
- line=col-1;
- if(size==MIDDLE)
- while(data[length]!=0)
- for(i=0;i<20;i++)
- line+=1;
- if(i==10)
- if(line<10)
- line=128-(10-line);
- else
- line-=10;
- else if(line==64)
- if(i<10)
- }else if(i>=10)
- line=0;
- if(i<10)
- }else if(i>=10)
- LCD_DATA_WRIRE(WORD_MIDDLE[data[length]-1][i]);
- length++;
- for(i=0;i<32;i++)
- line+=1;
- if(i==16)
- if(line<16)
- line=128-(16-line);
- else
- line-=16;
- else if(line==64)
- if(i<16)
- }else if(i>=16)
- line=0;
- if(i<16)
- }else if(i>=16)
- LCD_DATA_WRIRE(WORD_LONG[data[length]-1][i]);
- length++;
- //清除屏幕單獨一行
- u8 j;
- LCD_DIS_SELECT(DIS_ALL);
- for(j=0;j<128;j++)
- LCD_DATA_WRIRE(0xFF);
- //清除全屏
- u8 i;
- u8 j;
- for(i=0;i<8;i++)
- LCD_CMD_COLUNM(i);
復制代碼 |
