查看: 4264|回復(fù): 10
下面是單片機的六路搶答器,求高手幫忙注釋一下,很多地方不懂啊!
ID:51006 發(fā)表于 2013-6-17 12:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    #include <reg52.h>
        unsigned char code table[]={0xc0,0xf9,0xa4,
    0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xc0};
        sbit start=P3^6;
        sbit reset=P3^7;
        sbit key1=P1^0;
        sbit key2=P1^1;
        sbit key3=P1^2;
        sbit key4=P1^3;
        sbit key5=P1^4;
        sbit key6=P1^5;
        sbit key7=P1^6;
        sbit key8=P1^7;
        sbit jia=P3^4;
        sbit jian=P3^5;
        bit action = 0;
        uchar second=10,a[7]={0};
        uchar timer0_count = 0;
        uchar number=0;
        uchar number_display = 0;
        uchar k;
        void delay(uint z)
                uint x,y;
                for(x=z;x>0;x--)
                        for(y=120;y>0;y--);
        void display(uchar number,uchar second)
                P2 = 0x01;
                P0 = table[second];
                delay(1);
                P2 = 0x02;
                P0 = table[number];
                delay(1);
                P2 = 0x04;
                P0 = table[a[0]];
                delay(1);
                P2 = 0x08;
                P0 = table[a[1]];
                delay(1);
                P2 = 0x10;
            P0 = table[a[2]];
                delay(1);
                P2 = 0x20;
                P0 = table[a[3]];
                delay(1);
                P2 = 0x40;
                P0 = table[a[4]];
                delay(1);
                P2 = 0x80;
                P0 = table[a[5]];
                delay(1);
        void start_keyscan()
            void fengling();
                while(start == 0)
                    key7=0;
                        display(number_display,second);
                        if(start == 1)
                            key7=1;
                                action  = 1;
                                TR0 = 1;
        uchar key_scan8()
                if(key1 == 0)
                        delay(8);
                        if(key1 == 0)
                                number  = 1;
                                number_display = number;
                                if(key2 == 0)
                        delay(8);
                        if(key2 == 0)
                                number  = 2;
                if(key3 == 0)
                        delay(8);
                        if(key3 == 0)
                                number  = 3;
                if(key4 == 0)
                        delay(8);
                        if(key4 == 0)
                                number  = 4;
                if(key5 == 0)
                        delay(8);
                        if(key5 == 0)
                                number  = 5;
                if(key6 == 0)
                        delay(8);
                        if(key6 == 0)
                                number  = 6;
                if(number_display != 0)
                        return number_display;
                        return 0;
        void reset_keyscan()
                if(reset == 0)
                        delay(8);
                        if(reset == 0)
                                number_display = 0;
                               second=10;
                TMOD=0x01;
                TH0=(65536-50000)/256;
                TL0=(65536-50000)%256;
                EA=1;
                ET0=1;
                TR0=0;
                P2=0x00;
                    reset_keyscan();
                        start_keyscan();
                         if(jia==0&&a[number-1]<9)
                 delay(10);
                 while(jia==0)
                     a[number-1]=a[number-1]+1;
            if(jian==0&&a[number-1]>0)
                 delay(10);
                     while (jian==0)
                     a[number-1]=a[number-1]-1;
                        while(action)
                         while(!key_scan8())
                                if(second == 0)
                                        second = 10;
                                        break;
                                        TR0 = 0;
                                        key7=0;
                                        delay(80);
                 key7=1;
                                        action = 0;
                                        break;
        void timer0() interrupt 1
                timer0_count ++;
                if(timer0_count == 20)
                        second --;
                        timer0_count = 0;
          if(second==0)
                           key7=0;
                           delay(60);
                           key7=1;
無效樓層,該帖已經(jīng)被刪除
無效樓層,該帖已經(jīng)被刪除
ID:1 發(fā)表于 2013-6-17 15:25 | 只看該作者
是一個八路搶答器的單片機程序
ID:76287 發(fā)表于 2015-4-7 19:03 | 只看該作者
不懂,但是還是要頂,安撫樓主受傷心靈,每一個新手都是痛苦的開始,快樂的結(jié)局
ID:439073 發(fā)表于 2019-4-18 14:53 | 只看該作者
道到我的單片機里沒用呀
ID:370231 發(fā)表于 2019-4-18 15:20 | 只看該作者
在學習技術(shù)的時候,一定要多動腦筋,遇到問題后,三思而后問。
ID:515274 發(fā)表于 2019-4-18 16:08 | 只看該作者
key_scan8這個函數(shù)檢測8個按鍵是否有按下的,檢測到按鍵后返回number_display。
ID:1105312 發(fā)表于 2023-12-20 14:51 | 只看該作者
六路搶答器怎么做,在線求
ID:1105312 發(fā)表于 2023-12-20 14:52 | 只看該作者
下載進我的單片機了沒用呀
ID:1062320 發(fā)表于 2023-12-22 09:23 | 只看該作者
這段代碼看起來是為了一個帶有按鈕的七段數(shù)碼管計數(shù)器,可以用來遞增和遞減數(shù)字。它還包括一個倒計時器,從10倒數(shù)到0,下載進單片機沒用有可能是你的引腳不對 比如原來是P1.0-7引腳,但是你單片機可能不是這個接口
