求解決:在顯示距離同時(shí)可以按鍵調(diào)整小車(chē)速度
完整程序如下:
#include<reg52.h>
#include<1602.h>
#include<pwm.h>
sfr T2MOD=0XC9;
sbit Trig = P2^0;
sbit Echo = P2^1;
/*void UsartConfiguration();
unsigned char i; */
sbit IN1 = P3^7;
sbit IN2 = P3^6;
sbit IN3 = P3^5;
sbit IN4 = P3^4;
/************函數(shù)聲明**************/
void forword();
void back();
void right();
void left();
void stop();
unsigned char BiaoTi[]=" distance: ";
unsigned char code ShuZiBiao[15] = {'0','1','2','3','4','5','6','7','8','9','.','C','M'};
unsigned char XianShi[7] ={ 0,0,0,0,0,0,0};
//2、設(shè)定發(fā)送時(shí)間
void Delay10us()
T2MOD = 0; //---- --00 初始化模式寄存器 默認(rèn)向上計(jì)數(shù)
T2CON = 0; //0000 0000 初始化控制寄存器 一個(gè)中斷源,16位自動(dòng)重裝模式
TL2 = (65536 - 10) / 256; //設(shè)置定時(shí)初值
TH2 = (65536 - 10) % 256; //設(shè)置定時(shí)初值
RCAP2L = (65536 - 10) / 256; //設(shè)置定時(shí)重載值
RCAP2H = (65536 - 10) % 256; //設(shè)置定時(shí)重載值
TR2 = 1; //定時(shí)器2開(kāi)始計(jì)時(shí)
IE = 0xA0; //打開(kāi)全局中斷,定時(shí)器2中斷
while(!TF2);
TF2 = 0;
/* TMOD |= 0x01;
TH0 = 0xFF;
TL0 = 0xF6;
TR0 = 1;
while(!TF0);
TF0 = 0; */
void Rstart() //啟動(dòng)超聲波模塊,初始化
Trig=0;
Trig=1;
Delay10us();
Trig=0;
//3、獲取時(shí)間和距離
int gettime()//獲取時(shí)間
unsigned int time = 0;
time = TH2<<8 | TL2; //TH0*256+TL0
return time;
int Getdis(unsigned int time) //獲取距離
unsigned int distance;//整型的原因是方便后續(xù)LCD1602屏顯示
distance = (int)time * 0.085;
TH2=0;
TL2=0;//清空計(jì)時(shí)器·
return distance;
void star()
TH2 = 0;
TL2 = 0;
TR2 = 1;
void end()
TR2 = 0;
void GetOnce() //獲取一次超聲波測(cè)距模塊的距離
Rstart();
while(!Echo);//當(dāng)Echo為零時(shí)等待
star();
while(Echo);//當(dāng)Echo為1計(jì)數(shù)并等待
end();
void delay()
int i;
int j;
for(i=0;i<50;i++)
for(j = 0;j<1000;j++);
unsigned int i,j;
unsigned int dis;
timer0_init();
delayxms(5);
/* UsartConfiguration(); //串口初始化 */
GetOnce();
time = gettime();
dis = Getdis(time);//單位毫米,后面會(huì)用厘米顯示
XianShi[0]=dis/1000;//厘米的百位
XianShi[1]=(dis/100)%10;//厘米的十位
XianShi[2]=(dis/10)%10;//厘米的個(gè)位
XianShi[3]=10;//顯示小數(shù)點(diǎn)
XianShi[4]=dis%10;//厘米的小數(shù)點(diǎn)后一位
XianShi[5]=11;//顯示‘C’
XianShi[6]=12;//顯示'M'
Lcd1602_init(); //初始化函數(shù)
Lcd1602_WriteCom(0x80); //0x80是第一行的第一個(gè)字符的地址
for (i=0;i<11;i++)
Lcd1602_WriteData(BiaoTi[i]);
Lcd1602_WriteCom(0x80+0x40); //0xc0是第二行的第一個(gè)字符的地址
for (j=0;j<7;j++)
Lcd1602_WriteData(ShuZiBiao[XianShi[j]]);
Motor_add_left();
Motor_dec_left();
Motor_add_right();
Motor_dec_right();
forword();
/* if(dis < 150)
back();
delay();
right();
{forword();} */
// 避障
/* i = SBUF;
RI = 0;
if(i == 'q')
forword();
if(i == 'h')
back();
if(i == 'z')
left();
if(i == 'y')
right();
if(i == 't')
stop();
void forword() //前進(jìn)函數(shù)
//第一路電機(jī) 正轉(zhuǎn)
IN1 = 0;
IN2 = 1;
//第二路電機(jī) 正轉(zhuǎn)
IN3 = 0;
IN4 = 1;
void back() //后退
//第一路電機(jī) 反轉(zhuǎn)
IN1 = 1;
IN2 = 0;
//第二路電機(jī) 反轉(zhuǎn)
IN3 = 1;
IN4 = 0;
void right() //右轉(zhuǎn)
// 第一路正轉(zhuǎn)
IN1 = 0;
IN2 = 1;
// 第二路反轉(zhuǎn)
IN3 = 0;
IN4 = 0;
void left() //左拐函數(shù)
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 1;
void stop()
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
/***********定時(shí)器0初始化***********/
void timer0_init()
TMOD=0x01; //定時(shí)器0工作于方式1
TH0=(65536-10)/256;
TL0=(65536-10)%256;
EA = 1;
ET0=1;
TR0=1;
/**************定時(shí)0中斷處理******************/
void timer0_int() interrupt 1
TH0=(65536-10)/256;
TL0=(65536-10)%256;
TIME++;
m1 = countA;
m2 = countB;
if(TIME < m1) //count為占空比
ENA = 1; //輸出高電平
ENA = 0;
if(TIME < m2)
ENB = 1;
ENB = 0;
if(TIME>=100)
TIME=0;
