* Filename:
* usbvideo_attr_GC032A.c
* Project:
* Maui_sw
* Description:
* Image sensor webcam driver function
* Author:
* HISTORY
* Below this line, this part is controlled by PVCS VM. DO NOT MODIFY!!
* $Revision:$
* $Modtime:$
* $Log:$
* Initial revision.
* Upper this line, this part is controlled by PVCS VM. DO NOT MODIFY!!
#include "drv_comm.h"
#include "stdio.h"
#include "isp_if.h"
#include "image_sensor.h"
#include "mm_comm_def.h"
#include "sensor_comm_def.h"
#include "usbvideo_custom.h"
#include "jpeg_enum.h"
#if (defined(WEBCAM_SUPPORT))
MM_ERROR_CODE_ENUM GC032AWebcamFeatureCtrl(kal_uint32 Id, void *In, void *Out, kal_uint32 OutLen, kal_uint32 *RealOutLen)
/* supported feature list */
static const USBVideo_Attr_Info GC032A_ATTR_INFO[] =
{USBVIDEO_ATTRIBUTE_BRIGHTNESS, KAL_TRUE, KAL_TRUE},
{USBVIDEO_ATTRIBUTE_CONTRAST, KAL_TRUE, KAL_TRUE},
{USBVIDEO_ATTRIBUTE_HUE, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_HUE_AUTO, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_SATURATION, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_POWER_LINE_FREQUENCY, KAL_TRUE, KAL_TRUE},
{USBVIDEO_ATTRIBUTE_SHARPNESS, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_BACKLIGHT_COMPENSATION, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_GAMMA, KAL_FALSE, KAL_FALSE},
{USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP, KAL_TRUE, KAL_TRUE},
{USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP_AUTO, KAL_TRUE, KAL_TRUE},
/* supported video size list */
static const USBVideo_Video_Size_Info GC032A_VIDEO_SIZE[] =
{USBVIDEO_VIDEO_SIZE_1, 160, 120, 0xC000, 912382, 38012, 500000, 500000, 500000, 0},
{USBVIDEO_VIDEO_SIZE_2, 320, 240, 0xC000, 912384, 38016, 500000, 500000, 500000, 0},
#if (defined(__JPEG_HW_SUPPORTED__))
{USBVIDEO_VIDEO_SIZE_3, 640, 480, 0x18000, 912384, 38016, 500000, 500000, 500000, 0},
#else
{USBVIDEO_VIDEO_SIZE_3, 640, 480, 0xC000, 912384, 38016, 500000, 500000, 500000, 0},
#endif
/* supported still image size list */
static const USBVideo_Still_Size_Info GC032A_STILL_SIZE[] =
{USBVIDEO_STILL_SIZE_1, 160, 120, 0xC000},
{USBVIDEO_STILL_SIZE_2, 320, 240, 0xC000},
{USBVIDEO_STILL_SIZE_3, 640, 480, 0x18000},
#else
{USBVIDEO_STILL_SIZE_3, 640, 480, 0xC000},
#endif
/* supported compression type list*/
static const USBVideo_Compression_Info GC032A_STILL_COMPRESSION[] =
/* {USBVIDEO_COMPRESSION_1, JPEG_ENCODE_QUALITY_GOOD}, */
{USBVIDEO_COMPRESSION_1, JPEG_ENCODE_QUALITY_LOW},
{USBVIDEO_COMPRESSION_2, JPEG_ENCODE_QUALITY_FAIR}
static const USBVIDEO_VIDEO_SIZE_TYPE GC032A_g_default_video_size = USBVIDEO_VIDEO_SIZE_1;
static const USBVIDEO_STILL_SIZE_TYPE GC032A_g_default_still_size = USBVIDEO_STILL_SIZE_1;
static const USBVIDEO_COMPRESSION_TYPE GC032A_g_default_compression = USBVIDEO_COMPRESSION_1;
static const usbvideo_attr_struct GC032AWebcamAttrPara =
/* min,max,res,def */
{0, 4, 1, 0 }, /*0 USBVIDEO_ATTRIBUTE_BACKLIGHT_COMPENSATION*/
{0, 8, 1, 4 }, /*1 USBVIDEO_ATTRIBUTE_BRIGHTNESS*/
{0, 2, 1, 1 }, /*2 USBVIDEO_ATTRIBUTE_CONTRAST*/
{0, 255, 1, 127 }, /*3 USBVIDEO_ATTRIBUTE_GAIN*/
{0, 2, 1, 1 }, /*4 USBVIDEO_ATTRIBUTE_POWER_LINE_FREQUENCY, 0:Disable, 1:50, 2:60*/
{0, 360, 1 , 0 }, /*5 USBVIDEO_ATTRIBUTE_HUE*/
{0, 255, 1, 64 }, /*6 USBVIDEO_ATTRIBUTE_SATURATION*/
{0, 15, 1, 0 }, /*7 USBVIDEO_ATTRIBUTE_SHARPNESS*/
{100, 220, 60, 160 }, /*8 USBVIDEO_ATTRIBUTE_GAMMA*/
{2500, 6500, 500, 5500}, /*9 USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP*/
{0, 1, 1, 1 }, /*10 USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP_AUTO*/
{0, 0, 0, 0 }, /*11 USBVIDEO_ATTRIBUTE_WHITE_BALANCE_COMP, NOT SUPPORT*/
{0, 1, 1, 1 }, /*12 USBVIDEO_ATTRIBUTE_WHITE_BALANCE_COMP_AUTO*/
{0, 0, 1, 0 }, /*13 USBVIDEO_ATTRIBUTE_DIGITAL_MULTIPLIER, NOT SUPPORT*/
{0, 0, 1, 0 }, /*14 USBVIDEO_ATTRIBUTE_DIGITAL_MULTIPLIER_LIMIT, NOT SUPPORT*/
{0, 1, 1, 0 }, /*15 USBVIDEO_ATTRIBUTE_HUE_AUTO*/
{0, 0, 0, 0 } /*16 USBVIDEO_ATTRIBUTE_MAX_MULTIPLIER, NOT SUPPORT*/
MM_ERROR_CODE_ENUM ErrCode = MM_ERROR_NONE;
switch(Id)
case CAL_FEATURE_WEBCAM_GET_ATTR:
USBVideo_Attr_Value *pWebCamAttr = (USBVideo_Attr_Value *)Out;
USBVIDEO_ATTRIBUTE_TYPE AttrType = pWebCamAttr->type;
if (AttrType <= USBVIDEO_ATTRIBUTE_CT_MAX)
pWebCamAttr->value = 0; /* CT currently is not support */
if (AttrType >= ATTR_PU_START)
switch(pWebCamAttr->req_type)
case USBVIDEO_REQUEST_GET_CUR:
ASSERT(0); /* current value is maintained in ISP driver */
break;
case USBVIDEO_REQUEST_GET_MIN:
pWebCamAttr->value = GC032AWebcamAttrPara.attr_info[GET_ATTR_PU_IDX(AttrType)].min;
break;
case USBVIDEO_REQUEST_GET_MAX:
pWebCamAttr->value = GC032AWebcamAttrPara.attr_info[GET_ATTR_PU_IDX(AttrType)].max;
break;
case USBVIDEO_REQUEST_GET_DEF:
pWebCamAttr->value = GC032AWebcamAttrPara.attr_info[GET_ATTR_PU_IDX(AttrType)].def;
break;
case USBVIDEO_REQUEST_GET_RES:
pWebCamAttr->value = GC032AWebcamAttrPara.attr_info[GET_ATTR_PU_IDX(AttrType)].res;
break;
default:
EXT_ASSERT(0, (kal_uint32)pWebCamAttr->req_type, 0, 0);
break;
ASSERT(0);
break;
case CAL_FEATURE_WEBCAM_SET_ATTR:
const USBVIDEO_ATTRIBUTE_TYPE AttrType = ((USBVideo_Attr_Value *)In)->type;
const kal_uint32 AttrValue = ((USBVideo_Attr_Value *)In)->value;
CAL_FEATURE_CTRL_STRUCT FeatureCtrlPara;
P_IMAGE_SENSOR_FUNCTION_STRUCT pfSensorFunc;
/* Sensor Attributes Set */
/* update attr PU current value */
/* usbvideo_attr_PU_value_list[GET_ATTR_PU_IDX(AttrType)] = AttrValue; */
GC032ASensorFunc(&pfSensorFunc);
FeatureCtrlPara.FeatureCtrlCode = CAL_FEATURE_SET_OPERATION;
switch(AttrType)
case USBVIDEO_ATTRIBUTE_POWER_LINE_FREQUENCY:
FeatureCtrlPara.FeatureSetValue = (1 == AttrValue ? CAM_BANDING_50HZ : CAM_BANDING_60HZ);
ErrCode = pfSensorFunc->SensorFeatureCtrl(CAL_FEATURE_CAMERA_BANDING_FREQ, &FeatureCtrlPara, NULL, 0, NULL);
break;
case USBVIDEO_ATTRIBUTE_BRIGHTNESS:
FeatureCtrlPara.FeatureSetValue = AttrValue;
ErrCode = pfSensorFunc->SensorFeatureCtrl(CAL_FEATURE_CAMERA_EV_VALUE, &FeatureCtrlPara, NULL, 0, NULL);
break;
case USBVIDEO_ATTRIBUTE_CONTRAST:
ErrCode = pfSensorFunc->SensorFeatureCtrl(CAL_FEATURE_CAMERA_CONTRAST, &FeatureCtrlPara, NULL, 0, NULL);
break;
case USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP_AUTO:
if (AttrValue > 0) /* auto */
FeatureCtrlPara.FeatureSetValue = CAM_WB_AUTO;
ErrCode = pfSensorFunc->SensorFeatureCtrl(CAL_FEATURE_CAMERA_WB, &FeatureCtrlPara, NULL, 0, NULL);
/* Bin: dothing, because will set by USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP */
break;
case USBVIDEO_ATTRIBUTE_WHITE_BALANCE_TMP:
if (AttrValue > 5800)
FeatureCtrlPara.FeatureSetValue = CAM_WB_DAYLIGHT;
else if (AttrValue >= 4800)
FeatureCtrlPara.FeatureSetValue = CAM_WB_INCANDESCENCE;
else if (AttrValue >= 3800)
FeatureCtrlPara.FeatureSetValue = CAM_WB_FLUORESCENT;
else /* if (AttrValue >= 2800) */
FeatureCtrlPara.FeatureSetValue = CAM_WB_TUNGSTEN;
break;
default:
break;
break;
case CAL_FEATURE_WEBCAM_GET_ATTR_INFO:
((P_CAL_FEATURE_WEBCAM_GET_ATTR_INFO_STRUCT)Out)->pWebCamAttrInfo = GC032A_ATTR_INFO;
((P_CAL_FEATURE_WEBCAM_GET_ATTR_INFO_STRUCT)Out)->WebCamAttrInfoNum = sizeof(GC032A_ATTR_INFO) / sizeof(GC032A_ATTR_INFO[0]);
break;
case CAL_FEATURE_WEBCAM_GET_VIDEO_SIZE:
((P_CAL_FEATURE_WEBCAM_GET_VIDEO_SIZE_STRUCT)Out)->pWebCamVideoSizeInfo = GC032A_VIDEO_SIZE;
((P_CAL_FEATURE_WEBCAM_GET_VIDEO_SIZE_STRUCT)Out)->WebCamVideoSizeInfoNum = sizeof(GC032A_VIDEO_SIZE) / sizeof(GC032A_VIDEO_SIZE[0]);
break;
case CAL_FEATURE_WEBCAM_GET_STILL_SIZE:
((P_CAL_FEATURE_WEBCAM_GET_STILL_SIZE_STRUCT)Out)->pWebCamStillSizeInfo = GC032A_STILL_SIZE;
((P_CAL_FEATURE_WEBCAM_GET_STILL_SIZE_STRUCT)Out)->WebCamStillSizeInfoNum = sizeof(GC032A_STILL_SIZE) / sizeof(GC032A_STILL_SIZE[0]);
break;
case CAL_FEATURE_WEBCAM_GET_COMPRESSION:
((P_CAL_FEATURE_WEBCAM_GET_COMPRESSION_STRUCT)Out)->pWebCamCompressionInfo = GC032A_STILL_COMPRESSION;
((P_CAL_FEATURE_WEBCAM_GET_COMPRESSION_STRUCT)Out)->WebCamCompressionInfoNum = sizeof(GC032A_STILL_COMPRESSION) / sizeof(GC032A_STILL_COMPRESSION[0]);
break;
case CAL_FEATURE_WEBCAM_GET_DEFAULT_IDX:
((P_CAL_FEATURE_WEBCAM_GET_DEFAULT_IDX_STRUCT)Out)->WebCamVideoSizeIdx = GC032A_g_default_video_size;
((P_CAL_FEATURE_WEBCAM_GET_DEFAULT_IDX_STRUCT)Out)->WebCamStillSizeIdx = GC032A_g_default_still_size;
((P_CAL_FEATURE_WEBCAM_GET_DEFAULT_IDX_STRUCT)Out)->WebCamCompressionIdx = GC032A_g_default_compression;
break;
default:
ErrCode = MM_ERROR_INVALID_PARAMETER;
break;
return ErrCode;
#else
return MM_ERROR_NONE;
#endif
