查看: 2217|回復: 3
請問大神們單片機仿真時LCD不顯示數(shù)值,應該顯示溫度,流量
ID:793364 發(fā)表于 2020-6-29 23:57 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define unchar unsigned char
sbit DQ=P1^0;
sbit RS=P1^1;
sbit RW=P1^2;
sbit EN=P1^3;
sbit p37=P3^6;
sbit p36=P3^7;
sbit p14=P1^4;
sbit p15=P1^5;
sbit p16=P1^6;
unchar table[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x20};
unsigned long int a;
float f,zong;
unsigned int tvalue;
unchar n1,n2,n3,n4,n5,n6,n7,n8,n9;
unchar tflag,d,g,kai,j,j1,j2,b;
void delay
(unsigned int z){int x,y;
for(x=z;x>0;x--)
for(y=120;y>0;y--);
void delay_18B20(unsigned int i)
while(i--);
void wr_com(unsigned char com)
{delay(1);
RS=0;
RW=0;
EN=0;
P2=com;
delay(1);
EN=0;
void wr_dat(unsigned char dat)
delay(1);
RS=1;
RW=0;
EN=0;
P2=dat;
delay(1);
EN=1;
delay(1);
EN=0;
void loop()
unsigned int zong1;
if(g==0)
{zong=(b/100.0)+zong;
g=1;
if(zong>=1000)
a++;
if(a>=1000000)
a=0;
zong1=(int)zong;
n9=a/100000;
n8=a%100000/10000;
n7=a%10000/1000;
n6=a%1000/100;
n5=a%100/10;
n4=a%10;
n3=zong1%1000/100;
n2=zong1%100/10;
n1=zong1%10;
void shuifei()
unchar h1,h2,h3,h4;h4=(j*a)/1000000;
h3=(j*a)%1000000/100000;
h2=(j*a)%100000/10000;
h1=(j*a)%10000/1000;
wr_com(0x80+10);
wr_dat(0x5c);
wr_dat(table[h4]);
wr_dat(table[h3]);
wr_dat(table[h2]);
wr_dat(0x2e);
wr_dat(table[h1]);
void ds1820rst()
unsigned char x=0;
DQ=1;
delay_18B20(4);
DQ=0;
delay_18B20(100);
DQ=1;
delay_18B20(40);
unchar ds1820rd()
unsigned char i=0;unsigned char dat=0;
for(i=8;i>0;i--)
DQ=0;
dat>>=1;
DQ=1;
if(DQ)
dat|=0x80;
delay_18B20(10);
return(dat);
void ds1820wr(unchar wdata)
{ unsigned char i=0;
for(i=8;i>0;i--)
DQ=0;
DQ=wdata&0x01;
delay_18B20(10);
DQ=1;
wdata>>=1;
uint read_temp()
unchar a,b;
ds1820rst();
ds1820wr(0xcc);
ds1820wr(0x44);
ds1820rst();
ds1820wr(0xcc);
ds1820wr(0xbe);
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
tvalue=~tvalue+1;
tflag=1;
tvalue=tvalue*(0.625);
return(tvalue);
void ds1820disp()
unchar t1,t2,t3,t4;
t3=tvalue/1000;
t2=tvalue%1000/100;
t1=tvalue%100/10;
t4=tvalue%10;
wr_dat(0x2d);
if(t3!=0)
        t1=9;
        t2=9;
        t3=10;
        t4=9;
        p37=0;
if(t2>=4)
        p37=0;
else p37=1;
if(tflag==1)
p37=0;
if(t3==0)
t3=10;
t2=10;
wr_dat(table[t3]);
wr_com(0x80+3);
wr_dat(table[t2]);
wr_dat(table[t1]);
wr_dat(0x2e);
wr_dat(table[t4]);
void liuliang()
while(d>=2)
d=0;
b=TH0*256+TL0;
TH0=0x00;
TL0=0x00;
g=0;
loop();
void display1()
wr_com(0x80);
wr_dat(0x54);
wr_dat(0x3a); read_temp();
ds1820disp();
wr_dat(0x00);
wr_dat(0x43);
shuifei();
wr_com(0x80+0x40);
wr_dat(0x46);
wr_dat(0x4c);
wr_dat(0x4f);
wr_dat(0x57);
wr_dat(0x3a);
wr_dat(0x20);
wr_dat(table[n9]);
wr_dat(table[n8]);
wr_dat(table[n7]);
wr_dat (0x2e);
wr_dat(table[n6]);
wr_dat(table[n5]);
wr_dat(table[n4]);
wr_dat(0x20);
wr_dat(0x74);
wr_dat(0x20);
void display2()
wr_com(0x80);
wr_dat(0x54);
wr_dat(0x3a);
read_temp();
ds1820disp();
wr_dat(0x00);
wr_dat(0x43);
wr_com(0x80+10);
wr_dat (table[j2]);
wr_dat(0x2e); wr_dat(table[j1]);
wr_dat(0x5c);
wr_dat(0x2f);
wr_dat(0x74);
wr_dat(0x20);
wr_com(0x80+0x40+5);
wr_dat(0x20);
wr_dat(0x20);
wr_dat(table[n4]);
wr_dat (0x2e);
wr_dat(table[n3]);        wr_dat(table[n2]);
wr_dat(table[n1]);
wr_dat(0x20);
wr_dat(0x6b);
wr_dat(0x67);
void kaiguan1()
if(p14==0)
{ delay(2);
if(p14==0)
{ delay(2);
p36=~p36;
TR0=~TR0;
while(p14==0);
void kaiguan2()
if(p15==0)
{ delay(2);
if(p15==0)
{ delay(2);
kai=~kai;
while(p15==0);
void kaiguan3()
if(p16==0)
{ delay(2);
if(p16==0)
{ delay(2);
j++;
if(j>40)
j=0;
j2=j/10;
j1=j%10;
while(p16==0);
void lcd_init ()
TMOD=0x15;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
TH0=0x00;
TL0=0x00;
EN=0;
wr_com(0x38);
wr_com(0x0c);
wr_com(0x06);
wr_com(0x01);
wr_com(0x40);
wr_dat(0x06);
wr_dat(0x09);
wr_dat(0x09);
wr_dat(0x06);
wr_dat(0x00);
wr_dat(0x00);
wr_dat(0x00);
wr_dat(0x00);
zong=0;
EA=1;
ET1=1;
TR1=1;
TR0=0;
p16=1;
p15=1;
p14=1;
zong=995;
a=199999;
j=20;
j2=2;
j1=0;
kai=0;
lcd_init();
kaiguan1();
kaiguan2();
liuliang();
if(kai==0)
display1();
kaiguan3();
display2();
void time1() interrupt 3
d++;
ID:267932 發(fā)表于 2020-7-1 20:44 | 只看該作者
你仿真接的IO,跟程序壓根對不上啊,這是你寫的程序嘛??????
ID:784384 發(fā)表于 2020-7-1 20:57 | 只看該作者
感覺你LCD連得好像有點問題,要不你換個接法改一下鍵位
ID:709787 發(fā)表于 2020-7-2 11:58 來自觸屏版 | 只看該作者
調(diào)試程序不能急!要知道主流的程序員 ,調(diào)試程序比寫程序用的時間多的多。先把LCD點亮 。再把溫度正確的讀出來 。然后再考慮把溫度顯示在LCD上 。
