查看: 1561|回復: 0
51單片機生成波形頻率
ID:780752 發表于 2020-6-28 02:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
sbit wr=P3^6;
sbit rd=P3^2;
sbit key0=P1^0;
sbit key1=P1^1;
sbit key2=P1^2;
sbit key3=P1^3;
sbit key4=P1^4;
unsigned char flag;
unsigned char const code
SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,0x4f,0x4c,0x49,0x46,0x43,0x41,0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xa,0xc,0xd,0xe,0x10,0x12,0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,0x76,0x79,0x7c};
unsigned char keyscan()
unsigned char keyscan_num,temp;
P1=0xff;
temp=P1;
if(~(temp&0xff))
  if(key0==0)
   keyscan_num=1;
  else if(key1==0)
   keyscan_num=2;
  else if(key2==0)
   keyscan_num=3;
  else if(key3==0)
   keyscan_num=4;
  else if(key4==0)
   keyscan_num=5;
   keyscan_num=0;
  return keyscan_num;
void init_DA0832()
rd=0;
wr=0;
void sin()
unsigned int i;
do{
  P2=SIN_code[i];
  i=i+1;
}while(i<256);
i=0;
void square()
EA=1;
ET0=1;
TMOD=1;
TH0=0xff;
TL0=0x83;
TR0=1;
void triangle()
P2=0x00;
do{
  P2=P2+1;
}while(P2<0xff);
P2=0xff;
do{
  P2=P2-1;
}while(P2>0x00);
P2=0x00;
void sawtooth()
P2=-0xff;
do{
  P2=P2+1;
}while(P2<0xff);
P2=-0xff;
void trapezoida()
unsigned char i;
P2=0x00;
do{
  P2=P2+1;
}while(P2<0xff);
P2=0xff;
for(i=255;i>0;i--)
  P2=0xff;
do{
  P2=P2-1;
}while(P2>0x00);
P2=0x00;
init_DA0832();
do{
  flag=keyscan();
}while(!flag);
  switch(flag)
   case 1:
    do{
     flag=keyscan();
     sin();
    }while(flag==1);
    break;
   case 2:
    square();
    do{
     flag=keyscan();
    }while(flag==2);
    TR0=0;
    break;
   case 3:
    do{
     flag=keyscan();
     triangle();
    }while(flag==3);
    break;
   case 4:
    do{
     flag=keyscan();
     trapezoida();
    }while(flag==4);
    break;
   case 5:
    do{
     flag=keyscan();
     sawtooth();
    }while(flag==5);
    break;
   default:
    flag=keyscan();
    break;
void timer0(void) interrupt 1
P2=~P2;
TH0=0xff;
TL0=0x83;
TR0=1;
