只需一步,快速開(kāi)始
查看: 2089|回復(fù): 2
有沒(méi)有大神可以指導(dǎo)一下為什么仿真的時(shí)候濕度顯示一直是0
本帖最后由 Zzboy 于 2020-6-26 11:52 編輯
#include <reg52.h>
#include "1602.h"
#include "dht.h"
#include "2402.h"
sbit buzzer=P2^0;
//定義LED燈
sbit Led=P1^6;                //除濕燈
sbit fan=P1^5;
sbit Key_HH1 = P3^4;
sbit Key_HH2 = P3^5;
//定義標(biāo)識(shí)
volatile bit FlagStartRH = 0;  //開(kāi)始溫濕度轉(zhuǎn)換標(biāo)志
volatile bit FlagKeyPress = 0; //有鍵按下
//定義溫濕度傳感器用外部變量
extern U8  U8FLAG,k;
extern U8  U8count,U8temp;
extern U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
extern U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
extern U8  U8comdata;
extern U8  count, count_r;
U16 temp;
S16  humidity;
S16 idata  HH;  //濕度上限
char * pSave;
//定義變量
U16 RHCounter;
//數(shù)據(jù)初始化
void Data_Init() {
    RHCounter = 0;
    Led = 1;
    HH = 85;
//定時(shí)器0初始化
void Timer0_Init() {
    ET0 = 1;        //允許定時(shí)器0中斷
    TMOD = 1;       //定時(shí)器工作方式選擇
    TL0 = 0x06;
    TH0 = 0xf8;     //定時(shí)器賦予初值
    TR0 = 1;        //啟動(dòng)定時(shí)器
//定時(shí)器0中斷
void Timer0_ISR (void) interrupt 1 using 0 {
    TL0 = 0x06;
    //每2秒鐘啟動(dòng)一次溫濕度轉(zhuǎn)換
    RHCounter ++;
    if (RHCounter >= 1000) {
        FlagStartRH = 1;
        RHCounter = 0;
//存入設(shè)定值、
void Save_Setting() {
    pSave =  (char *)&HH;
    wrteeprom(2, *pSave);          //存濕度上限值RH低8位
    DELAY(500);
    pSave ++;
    wrteeprom(3, *pSave);          //存濕度上限值RH高8位
    DELAY(500);
//載入設(shè)定值、
void Load_Setting() {
    *pSave++ = rdeeprom(2);
    *pSave = rdeeprom(3);
    if ((HH>99)||(HH<0)) HH = 85;
* 名稱(chēng) : Main()
* 功能 : 主函數(shù)
void main() {
    U16 i, j, testnum;
    EA = 0;
    Timer0_Init();  //定時(shí)器0初始化
    Data_Init();
    EA = 1;
    L1602_init();
//    L1602_string(1,1," Welcome to H   ");
    //延時(shí)
    for (i=0; i<500; i++)
        for (j=0; j<1000; j++)
    //清屏
    L1602_string(1,1,"Hum:  %    H:  % ");
    //載入濕度上限設(shè)定值
    Load_Setting();
    L1602_char(1, 13, HH/10+48);
    L1602_char(1, 14, HH%10+48);
    while(1) {
        //溫濕度轉(zhuǎn)換標(biāo)志檢查
        if (FlagStartRH == 1) {  //定時(shí)器
            TR0 = 0;
            testnum = RH();
            FlagStartRH = 0;
            //讀出濕度,只取整數(shù)部分
            TR0 = 1;
            humidity = U8RH_data_H;
            //顯示濕度
            L1602_int(1,2,humidity);
        if (!Key_HH1) {     //上下限處理
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            if (!Key_HH1) {
                if(HH>0)
                    HH--;
                else HH=0;
                Save_Setting();
        if (!Key_HH2) {
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            if (!Key_HH2) {
                if(HH>99)
                    HH=99;
                else HH++;
                Save_Setting();
        if (humidity > HH) {
            fan=0;
            Led = 0;  //燈打開(kāi)
            buzzer=0;
            DELAY(5000);
            Led = 1;  //濕度燈關(guān)
            buzzer=1;
            DELAY(5000);
        } else {
            fan=1;
濕度控制.zip
69.92 KB, 下載次數(shù): 5
ID:764088 發(fā)表于 2020-7-6 11:26 | 只看該作者
1)先查,傳感器 傳 回的值是否正確;不對(duì) 就調(diào)換 傳感器硬件
2) 傳感器 值 轉(zhuǎn)換對(duì)否,不對(duì),調(diào)試 轉(zhuǎn)換軟件,
3)顯示驅(qū)動(dòng) 環(huán)節(jié) 是否工作?
ID:332444 發(fā)表于 2020-7-6 11:40 | 只看該作者
測(cè)試1602傳給值看顯示是否正常這樣去排除
