20黑幣
設計一個矩陣鍵盤5*5的計算器,要求有括號的優先級。還有小數點。。寫到小數點就不知道該怎么寫。。請各幫幫忙。
- #include<reg52.h>
- #include<math.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit rs = P2^0;
- sbit rw = P2^1;
- sbit lcden = P2^2;
- uchar code anjian[]={ //鍵盤值
- 'A','(',')','B','C',
- '7','8','9','/','D',
- '4','5','6','*','E',
- '1','2','3','-','F',
- 'G','0','.','+','='
- uchar code shuzhi[]={
- '0','1','2','3','4',
- '5','6','7','8','9'
- double num[20]; //儲存數值
- double value; //儲存結果
- char flag; //運算符判斷
- uchar KeyValue = 30; //按鍵值
- void delay(uint z) //毫秒級延時
- uint x,y;
- for(x=z;x>0;x--)
- for(y=114;y>0;y--);
- /*********************** 定時器0初始化 ***********************/
- //void Init_timer0()
- // EA = 1;
- // ET0 = 1;
- // TR0 = 1;
- // TMOD = 0x01;
- // TH0 = 0xED; //定時5ms
- // TL0 = 0xFF;
- /*********************** 5*5矩陣鍵盤 ***********************/
- void KeyScan()
- P3 = 0xFF; //列掃描
- P1 = 0;
- while(KeyValue == 30)
- if(P3 != 0xFF)
- delay(10);
- if(P3 != 0xFF)
- switch(P3)
- case 0xFE: KeyValue=0; break;
- case 0xFD: KeyValue=1; break;
- case 0xFB: KeyValue=2; break;
- case 0xF7: KeyValue=3; break;
- case 0xEF: KeyValue=4; break;
- P1 = 0xFF; //行掃描
- P3 = 0;
- switch(P1)
- case 0xF7: KeyValue=KeyValue; break;
- case 0xEF: KeyValue=KeyValue+5; break;
- case 0xDF: KeyValue=KeyValue+10; break;
- case 0xBF: KeyValue=KeyValue+15; break;
- case 0x7F: KeyValue=KeyValue+20; break;
- while(P1 != 0xFF); //松手檢測
- /*********************** LCD1602 ***********************/
- void Read_Busy() //判忙函數
- uchar busy;
- P0 = 0xFF;
- rs = 0;
- rw = 1;
- do
- lcden = 1;
- busy = P0;
- lcden = 0;
- }while(busy & 0x80);
- void Write_Cmd(uchar cmd) //寫指令
- Read_Busy();
- rs = 0;
- rw = 0;
- P0 = cmd;
- lcden = 1;
- lcden = 0;
- void Write_Dat(uchar dat) //寫數據
- Read_Busy();
- rs = 1;
- rw = 0;
- P0 = dat;
- lcden = 1;
- lcden = 0;
- KeyValue = 30; //清按鍵值
- void Init_lcd() //lcd初始化
- Write_Cmd(0x38); //16*2顯示
- Write_Cmd(0x0C); //開顯示
- Write_Cmd(0x01); //清屏
- Write_Cmd(0x06); //讀寫一字節后,地址指針加1
- /*********************** 獲取數值 ***********************/
- void GetNum(int x)
- num[x] = anjian[KeyValue] - 48;
- Write_Dat(anjian[KeyValue]);
- KeyScan();
- while(48 <= anjian[KeyValue] && anjian[KeyValue] <= 57)
- num[x] = num[x] * 10 + (anjian[KeyValue] - 48);
- KeyScan();
- /*********************** 運算符號 ***********************/
- void GetFlag()
- switch(anjian[KeyValue])
- case '+':
- flag = '+';
- Write_Dat('+'); break;
- case '-':
- flag = '-';
- Write_Dat('-'); break;
- case '*':
- flag = '*';
- Write_Dat('*'); break;
- case '/':
- flag = '/';
- Write_Dat('/'); break;
- KeyScan();
- GetNum(1);
- /*********************** 計算結果 ***********************/
- void calculate()
- int ge, shi, bai;
- Write_Cmd(0xC0);
- Write_Dat('=');
- switch(flag)
- case '+':
- value = num[0] + num[1]; break;
- case '-':
- value = num[0] - num[1]; break;
- case '*':
- value = num[0] * num[1]; break;
- case '/':
- value = num[0] / num[1]; break;
- if(0 <= fabs(value) && fabs(value) <= 9) //1位數
- ge = fabs(value);
- if(value >= 0)
- Write_Dat(shuzhi[ge]);
- else
- Write_Dat('-');
- if(10 <= fabs(value) && fabs(value) <= 99) //2位數
- shi = fabs(value) / 10;
- ge = (int)fabs(value) % 10;
- if(value >= 0)
- Write_Dat(shuzhi[shi]);
- else
- Write_Dat('-');
- if(100 <= fabs(value) && fabs(value) <= 999) //3位數
- bai = fabs(value) / 100;
- shi = (int)fabs(value) /10 % 10;
- if(value >= 0)
- Write_Dat(shuzhi[bai]);
- else
- Write_Dat('-');
- void main()
- //Init_timer0();
- Init_lcd();
- Write_Cmd(0x80); //第一行顯示字符
- while(1)
- KeyScan();
- if(48 <= anjian[KeyValue] && anjian[KeyValue] <= 57) //獲取0~9數值
- GetNum(0);
- if(anjian[KeyValue] == '=')
- calculate();
- else
- GetFlag();
- /*********************** T0中斷函數 ***********************/
- //void timer0() interrupt 1
- // TL0 = 0xFF;
- // if(anjian[KeyValue] == 'A')
- // Write_Cmd(0x01); //清屏
- // Write_Cmd(0x80); //第一行顯示字符
- // //KeyValue = 0;
(92.65 KB, 下載次數: 85)
2020-6-22 15:53 上傳
仿真圖
