;使用C口作鍵盤(pán)掃描,7段數(shù)碼管顯示按鍵號(hào) ,63系列通用寄存器地址:20~7FH, A0~FFH ,未達(dá)到預(yù)期目的,只用個(gè)位數(shù)顯示按鍵號(hào)時(shí)正常工作,增加按鍵號(hào)轉(zhuǎn)換(用2位數(shù)顯示),則提示“STACK OVERFLOW"--堆棧溢出.編譯后機(jī)器碼容量為1.3KB左右,未超過(guò)CALL跳轉(zhuǎn)范圍——1頁(yè)(2K) 。 #include P16C63A.INC
KEYCODE EQU H'0020' KEYNUM EQU H'0021' CC EQU H'0024' TABADD EQU H'0025' SW EQU H'0026' GW EQU H'0027' ;PD EQU H'0028'
ORG H'0000' GOTO MAIN ORG H'0010'
MAIN MOVLW H'00' TRIS PORTA TRIS PORTB ;RB口全為輸出,用作驅(qū)動(dòng)7段數(shù)碼管 MOVWF KEYNUM MOVLW H'F0' TRIS PORTC ; 設(shè)置RC低四位為輸出,高四位為輸入 MOVLW TABLE MOVWF TABADD MOVLW H'0001' ; MOVWF PD ;用來(lái)判斷按鍵號(hào)是否大于9
LOOP CALL KEYSCAN ; CALL JUDGE ;判斷是按鍵號(hào)是否大于9 ; XORLW H'0001' ; BTFSS STATUS,Z CALL XIAO ; GOTO DASHU XS CALL DISP_2 GOTO LOOP ;循環(huán)掃描、顯示按鍵號(hào)
JUDGE MOVLW H'0A' SUBWF KEYNUM,0 BTFSC STATUS,0 ; C標(biāo)志 ; RETLW 0 ;小于10 ; RETLW 1 ; 10以上的按鍵號(hào) GOTO XIAO GOTO DASHU
XIAO MOVLW 0 MOVWF SW MOVF KEYNUM,0 MOVWF GW RETLW 0 ; GOTO XS
DASHU MOVLW H'01' MOVWF SW MOVLW H'0A' SUBWF KEYNUM,0 MOVWF GW RETLW 0 ; GOTO XS
DISP_2 MOVLW H'02' MOVWF PORTA MOVF SW,0 CALL DISP CALL DELAY
MOVLW H'01' MOVWF PORTA MOVF GW,0 CALL DISP CALL DELAY RETLW 0
DELAY MOVLW 0 MOVWF CC LL DECFSZ CC,1 GOTO LL RETLW 0
DISP ; MOVF KEYNUM,0 ;輸入W,輸出W ADDWF TABADD,0 CALL CONV MOVWF PORTB RETLW 0 CONV MOVWF PCL ;取碼,輸入W(0~F),輸出W TABLE RETLW H'C0' RETLW H'F9' RETLW H'A4' RETLW H'B0' RETLW H'99' RETLW H'92' RETLW H'82' RETLW H'F8' RETLW H'80' RETLW H'90' RETLW H'88' RETLW H'83' RETLW H'C6' RETLW H'A1' RETLW H'86' RETLW H'8E' ;0~F 數(shù)碼管代碼 RETLW H'C0'
KEYSCAN MOVLW H'FE' ;第一行置低(RC0輸出0) MOVWF PORTC NOP MOVF PORTC,0 ;讀RC各端口狀態(tài) ANDLW H'F0' ;屏蔽低四位,只需要低四位來(lái)判斷 MOVWF KEYCODE ;保存端口狀態(tài) MOVLW H'F0' SUBWF KEYCODE,0 ;與初值比較,看是否有鍵按下 BTFSS STATUS,Z ;有鍵按下(不等于初值,Z為零)則結(jié)束掃描 GOTO GETNUM1
MOVLW H'FD' ;第二行置低(RC1輸出0) MOVWF PORTC NOP MOVF PORTC,0 ;讀RC各端口值 ANDLW H'F0' ;屏蔽低四位,只需要低四位來(lái)判斷 MOVWF KEYCODE ;保存端口狀態(tài) MOVLW H'F0' SUBWF KEYCODE,0 ;與初值比較,看是否有鍵按下 BTFSS STATUS,Z ;有鍵按下(不等于初值,Z為零)則結(jié)束掃描 GOTO GETNUM2
MOVLW H'FB' ;第三行置低(RC2輸出0) MOVWF PORTC NOP MOVF PORTC,0 ;讀RC各端口值 ANDLW H'F0' ;屏蔽低四位,只需要低四位來(lái)判斷 MOVWF KEYCODE ;保存端口狀態(tài) MOVLW H'F0' SUBWF KEYCODE,0 ;與初值比較,看是否有鍵按下 BTFSS STATUS,Z ;有鍵按下(不等于初值,Z為零)則結(jié)束掃描 GOTO GETNUM3
MOVLW H'F7' ;第四行置低(RC3輸出0) MOVWF PORTC NOP MOVF PORTC,0 ;讀RC各端口值 ANDLW H'F0' ;屏蔽低四位,只需要低四位來(lái)判斷 MOVWF KEYCODE ;保存端口狀態(tài) MOVLW H'F0' SUBWF KEYCODE,0 ;與初值比較,看是否有鍵按下 BTFSS STATUS,Z ;有鍵按下(不等于初值,Z為零)則結(jié)束掃描 GOTO GETNUM4 FH RETLW 0 ; 子程序返回
QUDOU MOVF PORTC,0 ;去抖處理 SUBWF KEYCODE,0 BTFSC STATUS,Z GOTO QUDOU GOTO FH
