查看: 4260|回復: 0
51單片機多功能萬年歷溫度(12864液晶顯示)
給大家分享一個基于51單片機的多功能萬年歷12864液晶顯示,溫度補償,同時更新時間溫度,與電腦同步。可以設置鬧鐘
#include <reg51.h>
#include "value.h"
#include "nongli.h"
uchar n_nian,n_yue,n_ri;
bit flag_200ms = 1;
uchar menu_1;
uchar flag_clock_en;        //鬧鐘標志位
uchar flag_clock_kai;        //鬧鐘開標志位
uchar flag_c_en;
bit flag_100ms;
sbit beep=P2^7;        //蜂鳴器IO口
sbit dq=P3^2;          //18b20 IO口的定義
uint temperature ;    //溫度變量
/************ 延時函數  *****************/
void delay_uint(uint z)
   while(z--);
* 名稱 : delay_1ms()
* 功能 : 延時1ms函數
* 輸入 : q
* 輸出 : 無
void delay_1ms(uint q)
        uint i,j;
        for(i=0;i<q;i++)
                for(j=0;j<115;j++);
uchar dis_lcd[10];
#include "lcd12864bu.h"
/******************顯示時間函數***************************/
void dis_shijian()        //顯示時間
        write_shu16(3*2,1*8,shi,0);
        write_shuzi(1,3*2,3*8,fuhao[1],0);
        write_shu16(3*2,4*8,fen,0);
        write_shuzi(1,3*2,6*8,fuhao[1],0);
        write_shu16(3*2,7*8,miao,0);
        write_shu16(1*2,6*8,nian,0);
        write_shu16(1*2,10*8,yue,0);
        write_shu16(1*2,14*8,ri,0);
        write_shu16(2*2,4*8,n_yue,0);
        write_shuzi(1,2*2,6*8,fuhao[0],0);
        write_shu16(2*2,7*8,n_ri,0);
        if(week==0)
     write_yhanzi(1,4,7*16,xingqi[0]);
    if(week==1)
     write_yhanzi(1,4,7*16,xingqi[1]);
    if(week==2)
     write_yhanzi(1,4,7*16,xingqi[2]);
    if(week==3)
     write_yhanzi(1,4,7*16,xingqi[3]);
    if(week==4)
     write_yhanzi(1,4,7*16,xingqi[4]);
    if(week==5)
     write_yhanzi(1,4,7*16,xingqi[5]);
    if(week==6)
     write_yhanzi(1,4,7*16,xingqi[6]);
    if(week==7)
     week=0;
        write_shu18b20(3*2,10*8,temperature,0);
        write_shuzi(1,3*2,12*8,dian,0);
/************初始化顯示*****************/
void init_12864_dis() //初始化顯示
        cs1=1; //左屏開顯示
        cs2=0;
         write_yhanzi(7,0,16,dzrl);           //多功能電子日歷
         write_yhanzi(2,2,0,yangli);           //陽(0) 歷(1)
         write_yhanzi(2,4,0,nongli);           //農(0) 歷(1)
        //         write_yhanzi(2,6,0,0x00);   //時間
        //  write_yhanzi(2,6,0,shijian);   //時間
        write_shu16(1*2,4*8,0x20,0);
         write_yhanzi(1,2,4*16,qita[0]);   //年
         write_yhanzi(1,2,6*16,qita[1]);   //月
         write_yhanzi(2,4,5*16,qita[6]);   //星期
         dis_shijian();        //顯示時間
         write_yhanzi(1,6,7*16,wendu_fuhao);   //℃
/***********************18b20初始化函數*****************************/
void init_18b20()
        bit q;
        dq = 1;                                //把總線拿高
        delay_uint(1);            //15us
        dq = 0;                                //給復位脈沖
        delay_uint(80);                //750us
        dq = 1;                                //把總線拿高 等待
        delay_uint(10);                //110us
        q = dq;                                //讀取18b20初始化信號
        delay_uint(20);                //200us
        dq = 1;                                //把總線拿高 釋放總線
/*************寫18b20內的數據***************/
void write_18b20(uchar dat)
        uchar i;
        for(i=0;i<8;i++)
        {                                         //寫數據是低位開始
                dq = 0;                         //把總線拿低寫時間隙開始
                dq = dat & 0x01; //向18b20總線寫數據了
                delay_uint(5);         // 60us
                dq = 1;                         //釋放總線
                dat >>= 1;
/*************讀取18b20內的數據***************/
uchar read_18b20()
        uchar i,value;
        for(i=0;i<8;i++)
                dq = 0;                         //把總線拿低讀時間隙開始
                value >>= 1;         //讀數據是低位開始
                dq = 1;                         //釋放總線
                if(dq == 1)                 //開始讀寫數據
                        value |= 0x80;
                delay_uint(5);         //60us        讀一個時間隙最少要保持60us的時間
        return value;                 //返回數據
/*************讀取溫度的值 讀出來的是小數***************/
uint read_temp()
        uint value;
        uchar low;                           //在讀取溫度的時候如果中斷的太頻繁了,就應該把中斷給關了,否則會影響到18b20的時序
        init_18b20();                   //初始化18b20
        write_18b20(0xcc);           //跳過64位ROM
        write_18b20(0x44);           //啟動一次溫度轉換命令
        delay_uint(50);                   //500us
        write_18b20(0xbe);           //發出讀取暫存器命令
        EA = 0;
        low = read_18b20();           //讀溫度低字節
        value = read_18b20();  //讀溫度高字節
        EA = 1;
        value <<= 8;                   //把溫度的高位左移8位
        value |= low;                   //把讀出的溫度低位放到value的低八位中
        value *= 0.625;               //轉換到溫度值 小數
        return value;                   //返回讀出的溫度 帶小數
全部資料51hei下載地址:
單片機多功能萬年歷溫度(12864液晶顯示).zip (275.64 KB, 下載次數: 112)
收藏收藏5 分享淘帖 頂 踩
