查看: 1467|回復(fù): 3
我的單片機(jī)程序有什么問題嗎?求大神!
ID:642999 發(fā)表于 2020-6-19 18:32 | 顯示全部樓層 |閱讀模式
紅外遙控led程序:
我需要按下0x07后開始無限循環(huán)流水燈,等按下0x15后停止!
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. typedef unsigned int u16;
  4. typedef unsigned char u8;
  5. sbit IR=P3^2;
  6. #define led P1
  7. sbit light1=P1^0;
  8. sbit light2=P1^1;
  9. sbit light3=P1^2;
  10. sbit light4=P1^3;
  11. sbit light5=P1^4;
  12. sbit light6=P1^5;
  13. sbit fu=P3^0;
  14. unsigned char  irtime;
  15. bit irpro_ok,irok;
  16. char i,a;
  17. unsigned char IRcord[4];
  18. unsigned char irdata[33];
  19. void Ir_work(void);
  20. void Ircordpro(void);
  21. void tim0_isr (void) interrupt 1 using 1
  22. {
  23.   irtime++;
  24. }
  25. void EX0_ISR (void) interrupt 0
  26. {
  27. static unsigned char  i;
  28. static bit startflag;
  29. if(startflag)
  30. {
  31. if(irtime<63&&irtime>=33)
  32. i=0;
  33. irdata[i]=irtime;
  34. irtime=0;
  35. i++;
  36. if(i==33)
  37. {
  38. irok=1;
  39. i=0;
  40. }
  41. }
  42. else
  43. {
  44. irtime=0;
  45. startflag=1;
  46. }
  47. }
  48. void TIM0init(void)
  49. {
  50. TMOD=0x02;
  51. TH0=0x00;
  52. TL0=0x00;
  53. ET0=1;
  54. TR0=1;
  55. }
  56. void EX0init(void)
  57. {
  58. IT0 = 1;
  59. EX0 = 1;
  60. EA = 1;
  61. }
  62. void delay(u16 i)
  63. {
  64. while(i--);
  65. }
  66. void Delay1ms(unsigned int count)
  67. {
  68. unsigned int i,j;
  69. for(i=0;i<count;i++)
  70. for(j=0;j<120;j++);
  71. }
  72. void Ir_work(void)
  73. {
  74. switch(IRcord[2])
  75. {
  76. case 0x0c:light1=~light1;break;//1
  77. case 0x18:light2=~light2;break;//2
  78. case 0x5e:light3=~light3;break;//3
  79. case 0x08:light4=~light4;break;//4
  80. case 0x1c:light5=~light5;break;//5
  81. case 0x5a:light6=~light6;break;//6
  82. ////////////////////////ÅÜÂí
  83. case 0x07:                     //×óÒÆ
  84. {
  85. IT0 = 1;
  86. EX0 = 1;
  87. EA = 1;
  88. led=0x01;
  89. delay(50000);
  90. while(1)
  91. {
  92. if(a==0)
  93. {
  94. for(i=0;i<8;i++)
  95. {
  96. led=_cror_(led,1);
  97. delay(50000);
  98. break;case 0x15:a=1;
  99. }
  100. }
  101. if(a==1)
  102. {
  103. break;
  104. }
  105. }
  106. }
  107. break;
  108. case 0x09:                     //ÓÒÒÆ
  109. {
  110. led=0x01;
  111. delay(50000);
  112. while(1)
  113. {
  114.   for(i=0;i<8;i++)
  115.   {
  116.    led=_crol_(led,1);
  117.    delay(50000);
  118.   }
  119. }
  120. }
  121. break;
  122. case 0x40:                //Íâ
  123. P1=0;
  124. while(1)
  125. {
  126. light3=1;light4=1;delay(10000);
  127. light3=0;light4=0;delay(10000);
  128. light2=1;light5=1;delay(10000);
  129. light2=0;light5=0;delay(10000);
  130. light1=1;light6=1;delay(10000);
  131. light1=0;light6=0;delay(10000);
  132. }
  133. break;
  134. case 0x19:        //Àï
  135. P1=0;
  136. while(1)
  137. {
  138. light1=1;light6=1;delay(10000);
  139. light1=0;light6=0;delay(10000);
  140. light2=1;light5=1;delay(10000);
  141. light2=0;light5=0;delay(10000);
  142. light3=1;light4=1;delay(10000);
  143. light3=0;light4=0;delay(10000);
  144. }
  145. break;
  146. ///////////////////////ÅÜÂí
  147. case 0x42:          //7
  148. P1=0;
  149. light1=1;delay(30000);light3=1;delay(30000);light5=1;delay(10000);
  150. light2=1;delay(30000);light4=1;delay(30000);light6=1;break;
  151. case 0x52:          //8
  152. P1=0;
  153. light2=1;delay(30000);light4=1;delay(30000);light6=1;delay(10000);
  154. light1=1;delay(30000);light3=1;delay(30000);light5=1;break;
  155. case 0x4a://9
  156. P1=0xFF;delay(50000);P1=0x00;;delay(50000); break;
  157. case 0x43:              //·µ»Ø
  158. P1=0;
  159. {
  160. light1=1;light6=1;delay(10000);
  161. light1=0;light6=0;delay(10000);
  162. light2=1;light5=1;delay(10000);
  163. light2=0;light5=0;delay(10000);
  164. light3=1;light4=1;delay(10000);
  165. light3=0;light4=0;delay(10000);
  166. light2=1;light5=1;delay(10000);
  167. light2=0;light5=0;delay(10000);
  168. light1=1;light6=1;delay(10000);
  169. light1=0;light6=0;delay(10000);
  170. }
  171. break;
  172. case 0x16:              //0
  173. IR=0;
  174. break;
  175. case 0x0d:         //C
  176. P1=0;
  177. light1=1;delay(30000);light1=0;delay(30000);
  178. light6=1;delay(30000);light6=0;delay(30000);
  179. light5=1;delay(30000);light5=0;delay(30000);
  180. light2=1;delay(30000);light2=0;delay(30000);
  181. light3=1;delay(30000);light3=0;delay(30000);
  182. light4=1;delay(30000);light4=0;delay(30000);
  183. break;
  184. case 0x45:P1=0x00;break;//È«¹Ø
  185. case 0x47:P1=0xFF;break;//È«¿ª
  186. case 0x44:fu=~fu;//¸´Î»
  187. default:break;
  188. }
  189. irpro_ok=0;
  190. }
  191. void Ircordpro(void)
  192. {
  193. unsigned char i, j, k,cord,value;
  194. k=1;
  195. for(i=0;i<4;i++)
  196. {
  197. for(j=1;j<=8;j++)
  198. {
  199. cord=irdata[k];
  200. if(cord>7)
  201. value=value|0x80;
  202. if(j<8)
  203. {
  204. value>>=1;
  205. }
  206. k++;
  207. }
  208. IRcord[i]=value;
  209. value=0;
  210. }
  211. irpro_ok=1;
  212. }
  213. void main(void)
  214. {
  215. P1=0x00;
  216. fu=0;
  217. a=0;
  218. EX0init();
  219. TIM0init();
  220. while(1)
  221. {
  222. if(irok)
  223. {
  224. Ircordpro();
  225. irok=0;
  226. }
  227. if(irpro_ok)
  228. {
  229. Ir_work();
  230. }
  231. }
  232. }
ID:328014 發(fā)表于 2020-6-20 01:16 | 顯示全部樓層
你這個程序看起是沒有問題的 正常
ID:642999 發(fā)表于 2020-6-20 09:48 | 顯示全部樓層
可是不能實現(xiàn)讓它按0x07開始流水燈,按下0x15后停止
ID:642999 發(fā)表于 2020-6-24 19:16 | 顯示全部樓層
你可以把我要求的寫出來嗎?我做不出來!
