控制數(shù)碼管循環(huán)顯示單個數(shù)字,仿真加程序,壓縮包都有
- #include"reg51.h"
- #include"intrins.h"
- #define uchar unsigned char
- #define uint unsigned int
- #define out P0
- uchar code seg[]={0xc0,0xa4,0x99,0x82,0x80,0xf9,0xb0,0x92,0xf8,0x90,0x01};
- void delayms(uint);
- void main(void)
- uchar i;
- while(1)
- {out=seg[i];
- delayms(900);
- i++;
- if(seg[i]==0x01)i=0;
- void delayms(uint j)
- uchar a;
- for(;j>0;j--)
- a=250;
- while(--a);
- a=249;
- while(--a);
控制數(shù)碼管循環(huán)顯示單個數(shù)字.zip
(40.29 KB, 下載次數(shù): 32)
2020-6-19 16:46 上傳
