- #include "AD7193.h" // AD7193 definitions.
- /************************ Variables Definitions *******************************/
- unsigned char currentPolarity = 0;
- unsigned char currentGain = 1;
- /************************ Functions Definitions *******************************/
- * @brief Checks if the AD7139 part is present.
- * @return status - Indicates if the part is present or not.
- unsigned char AD7193_Init(void)
- unsigned char status = 1;
- unsigned char regVal = 0;
- status = SPI_Init(0, 1000000, 1, 0);
- regVal = AD7193_GetRegisterValue(AD7193_REG_ID, 1, 1);
- if((regVal & AD7193_ID_MASK) != ID_AD7193)
- status = 0;
- return status;
- * @brief Writes data into a register.
- * @param registerAddress - Address of the register.
- * @param registerValue - Data value to write.
- * @param bytesNumber - Number of bytes to be written.
- * @param modifyCS - Allows Chip Select to be modified.
- * @return none.
- void AD7193_SetRegisterValue(unsigned char registerAddress,
- unsigned long registerValue,
- unsigned char bytesNumber,
- unsigned char modifyCS)
- unsigned char writeCommand[5] = {0, 0, 0, 0, 0};
- unsigned char* dataPointer = (unsigned char*)®isterValue;
- unsigned char bytesNr = bytesNumber;
- writeCommand[0] = AD7193_COMM_WRITE |
- AD7193_COMM_ADDR(registerAddress);
- while(bytesNr > 0)
- writeCommand[bytesNr] = *dataPointer;
- dataPointer ++;
- bytesNr --;
- SPI_Write(AD7193_SLAVE_ID * modifyCS, writeCommand, bytesNumber + 1);
- * @brief Reads the value of a register.
- * @param bytesNumber - Number of bytes that will be read.
- * @return buffer - Value of the register.
- unsigned long AD7193_GetRegisterValue(unsigned char registerAddress,
- unsigned char registerWord[5] = {0, 0, 0, 0, 0};
- unsigned long buffer = 0x0;
- unsigned char i = 0;
- registerWord[0] = AD7193_COMM_READ |
- SPI_Read(AD7193_SLAVE_ID * modifyCS, registerWord, bytesNumber + 1);
- for(i = 1; i < bytesNumber + 1; i++)
- buffer = (buffer << 8) + registerWord[i];
- return buffer;
- * @brief Resets the device.
- * @return none.
- void AD7193_Reset(void)
- unsigned char registerWord[6] = {0, 0, 0, 0, 0, 0};
- registerWord[0] = 0xFF;
- registerWord[1] = 0xFF;
- registerWord[2] = 0xFF;
- registerWord[3] = 0xFF;
- registerWord[4] = 0xFF;
- registerWord[5] = 0xFF;
- SPI_Write(AD7193_SLAVE_ID, registerWord, 6);
- * @brief Set device to idle or power-down.
- * @param pwrMode - Selects idle mode or power-down mode.
- * Example: 0 - power-down
- * 1 - idle
- * @return none.
- void AD7193_SetPower(unsigned char pwrMode)
- unsigned long oldPwrMode = 0x0;
- unsigned long newPwrMode = 0x0;
- oldPwrMode = AD7193_GetRegisterValue(AD7193_REG_MODE, 3, 1);
- oldPwrMode &= ~(AD7193_MODE_SEL(0x7));
- newPwrMode = oldPwrMode |
- AD7193_MODE_SEL((pwrMode * (AD7193_MODE_IDLE)) |
- (!pwrMode * (AD7193_MODE_PWRDN)));
- AD7193_SetRegisterValue(AD7193_REG_MODE, newPwrMode, 3, 1);
- * @brief Waits for RDY pin to go low.
- * @return none.
- void AD7193_WaitRdyGoLow(void)
- while(AD7193_RDY_STATE)
- * @brief Selects the channel to be enabled.
- * @param channel - Selects a channel.
- * Example: AD7193_CH_0 - AIN1(+) - AIN2(-); (Pseudo = 0)
- * AD7193_CH_1 - AIN3(+) - AIN4(-); (Pseudo = 0)
- * AD7193_TEMP - Temperature sensor
- * AD7193_SHORT - AIN2(+) - AIN2(-); (Pseudo = 0)
- * @return none.
- void AD7193_ChannelSelect(unsigned short channel)
- unsigned long oldRegValue = 0x0;
- unsigned long newRegValue = 0x0;
- oldRegValue = AD7193_GetRegisterValue(AD7193_REG_CONF, 3, 1);
- oldRegValue &= ~(AD7193_CONF_CHAN(0x3FF));
- newRegValue = oldRegValue | AD7193_CONF_CHAN(1 << channel);
- AD7193_SetRegisterValue(AD7193_REG_CONF, newRegValue, 3, 1);
- * @brief Performs the given calibration to the specified channel.
- * @param mode - Calibration type.
- * @param channel - Channel to be calibrated.
- * @return none.
- void AD7193_Calibrate(unsigned char mode, unsigned char channel)
- AD7193_ChannelSelect(channel);
- oldRegValue = AD7193_GetRegisterValue(AD7193_REG_MODE, 3, 1);
- oldRegValue &= ~AD7193_MODE_SEL(0x7);
- newRegValue = oldRegValue | AD7193_MODE_SEL(mode);
- PMOD1_CS_LOW;
- AD7193_SetRegisterValue(AD7193_REG_MODE, newRegValue, 3, 0); // CS is not modified.
- AD7193_WaitRdyGoLow();
- PMOD1_CS_HIGH;
- * @brief Selects the polarity of the conversion and the ADC input range.
- * @param polarity - Polarity select bit.
- Example: 0 - bipolar operation is selected.
- 1 - unipolar operation is selected.
- * @param range - Gain select bits. These bits are written by the user to select
- the ADC input range.
- * @return none.
- void AD7193_RangeSetup(unsigned char polarity, unsigned char range)
- oldRegValue = AD7193_GetRegisterValue(AD7193_REG_CONF,3, 1);
- oldRegValue &= ~(AD7193_CONF_UNIPOLAR |
- AD7193_CONF_GAIN(0x7));
- (polarity * AD7193_CONF_UNIPOLAR) |
- AD7193_CONF_GAIN(range);
- /* Store the last settings regarding polarity and gain. */
- currentPolarity = polarity;
- currentGain = 1 << range;
- * @brief Returns the result of a single conversion.
- * @return regData - Result of a single analog-to-digital conversion.
- unsigned long AD7193_SingleConversion(void)
- unsigned long command = 0x0;
- unsigned long regData = 0x0;
- command = AD7193_MODE_SEL(AD7193_MODE_SINGLE) |
- AD7193_MODE_CLKSRC(AD7193_CLK_INT) |
- AD7193_MODE_RATE(0x060);
- PMOD1_CS_LOW;
- AD7193_SetRegisterValue(AD7193_REG_MODE, command, 3, 0); // CS is not modified.
- regData = AD7193_GetRegisterValue(AD7193_REG_DATA, 3, 0);
- PMOD1_CS_HIGH;
- return regData;
- * @brief Returns the average of several conversion results.
- * @return samplesAverage - The average of the conversion results.
- unsigned long AD7193_ContinuousReadAvg(unsigned char sampleNumber)
- unsigned long samplesAverage = 0;
- unsigned long command = 0;
- unsigned char count = 0;
- command = AD7193_MODE_SEL(AD7193_MODE_CONT) |
- PMOD1_CS_LOW;
- for(count = 0; count < sampleNumber; count++)
- samplesAverage += AD7193_GetRegisterValue(AD7193_REG_DATA, 3, 0); // CS is not modified.
- PMOD1_CS_HIGH;
- samplesAverage = samplesAverage / sampleNumber;
- return samplesAverage;
- * @brief Read data from temperature sensor and converts it to Celsius degrees.
- * @return temperature - Celsius degrees.
- unsigned long AD7193_TemperatureRead(void)
- unsigned long dataReg = 0;
- unsigned long temperature = 0;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
2020-6-18 14:16 上傳
原理圖: 無(wú)
仿真: 無(wú)
上圖4個(gè)代碼文件:
ad7193_generic.zip
(10.93 KB, 下載次數(shù): 27)
2020-6-18 10:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
