查看: 1471|回復: 1
有個錯誤,說缺少什么,咋改呢? 求幫助
ID:757210 發(fā)表于 2020-6-17 23:13 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include"1602.h"
#include"dht11.h"
#define uint  unsigned int
#define void unsigned main
uchar idata temp[]    ="SD:RS:00% T:00 \0";
uchar idata temp_s[]  ="RS:00% TEMP:00  \0";
uchar  idata wsdisplay[]="   WS Over:\0"
uchar  idata ywdisplay[]="   YW Over:\0"
uchar idata title0[]="  Welcome To:\0";
uchar idata title1[]="  ZN System \0" ;
sbit key3=P3^0;
sbit sw1=P3^1
sbit sw2=P3^2
sbit led1=P1^1
sbit led2=P1^2;
sbit baojing=P1^5;
sbit yw=P2^2;
uchar idata set;
uchar idata num1;
uchar idata getdata=35;
uint idata shangxian=85;
uchar idata temp_h,temp_t,fleg;
void conv();
void key();
void kongzhi();
void guangming();
void ywjiance();
void WSjiance();
void autoled();
void guangming()
  led=0;
        if(ss==0)
        led=1;
void zhuanhuan(
  temp[6]=shangxian/10%10+0x30;
  temp[7]=shangxian%10+0x30;
  temp[12]=getdata/10%10+0x30;
  temp[13]=getdata%10+0x30;
  temp[14]=0xdf;
  temp[15]='C';
  temp_s[3]=temp_h/10%10+0x30;
  temp_s[4]=temp_h%10+0x30;
  //temp_s[3]=temp_h/10%10+0x30;
  //temp_s[4]=temp_h%10+0x30;
  temp_s[12]=temp_t/10%10+0x30;
  temp_s[13]=temp_t%10+0x30;
  temp_s[14]=0xdf;
  temp_s[15]='C';
void main(void)
baojing=1;
delay(200);
LCD_Initial();
GotoXY(0,0);
Print(title0);
GotoXY(0,1)
Print(title1)
delay(500);
clock();
delay(100);
   EA=1;
   IT0=1;
   EX0=1;
// IT1=1;
  // EX1=1;
//  IP=0x01;
        delay(10);
        ywjiance();
        WSjiance();
    guangming();
    autoled();
        delay(10);
        RH();
        temp_t=U8T_data_H;
        temp_h=U8RH_data_H;
    zhuanhuan();
    key();
    kongzhi();
    if(key3==0)
     delay(10);
         if(key3==0)
          Display();
          delay(3000);
          LCD_clear();
   GotoXY(0,0)
   Print(temp)
   GotoXY(0,1);
   delay(1);
  //getdate= GetADCResult(0)*3.9;
void  key(
        if(set==0)
                if(sw1==0)
                        delay(50);
            if(sw1==0)
                                if(shangxian>0)  shangxian--;
                                else( shangxian=255);
                if(sw2==0)
                        delay(50);
                        if(sw2==0)
                                if(shangxian<255) shangxian++;
                                else( shangxian=0);
void autoled()
if(key4==0)
      delay(10);
      if(key4==0)
            if(fleg)
                   led3=1;
                     fleg=0;
                  led3=0;
                 fleg=1;
void ywjiance()
  yw=1;
  led2=0;
  if(yw==0)
     delay(500);
     GotoXY(0,0);
     Print(ywdisplay);
         delay(1000);
   baojing=0;
   led2=1;
void WSjiance()
    //hw=0;
   if(hw==1)
   baojing=0;
     baojing=1;
void  kongzhi()
led1=0;
if((temp_h>=shangxian)|(temp_t>35))
GotoXY(0,0);
Print(wsdisplay);
delay(1000);
led1=1;
  led1=        0;
ID:478073 發(fā)表于 2020-6-18 08:00 | 顯示全部樓層
有錯誤了要學會自己排查才有意義,你的代碼要實現什么,是哪幾行,搞清楚了屏蔽部排除就好了
