查看: 4628|回復: 3
基于FPGA的uart程序設計
  1. module uart_rx(
  2.      clk,
  3.      rst_n,
  4.      bps_start,
  5.      clk_bps,
  6.      rs232_rx,
  7.      rx_data,
  8.      rx_int,
  9.      led
  10.      );
  11. input clk;   //時鐘
  12. input rst_n;  //復位
  13. input rs232_rx; //接收數據信號
  14. input clk_bps;  //高電平時為接收信號中間采樣點
  15. output bps_start; //接收信號時,波特率時鐘信號置位
  16. output [7:0] rx_data;//接收數據寄存器
  17. output rx_int;  //接收數據中斷信號,接收過程中為高
  18. output [7:0] led;
  19. reg [7:0] led;
  20. reg rs232_rx0,rs232_rx1,rs232_rx2,rs232_rx3;//接收數據寄存器
  21. wire neg_rs232_rx;//表示數據線接收到下沿
  22. always @(posedge clk or negedge rst_n) begin
  23.   if(!rst_n) begin
  24.    rs232_rx0 <= 1'b0;
  25.    rs232_rx1 <= 1'b0;
  26.    rs232_rx2 <= 1'b0;
  27.    rs232_rx3 <= 1'b0;
  28.   end
  29.
  30.   else begin
  31.    rs232_rx0 <= rs232_rx;
  32.    rs232_rx1 <= rs232_rx0;
  33.    rs232_rx2 <= rs232_rx1;
  34.    rs232_rx3 <= rs232_rx2;
  35.   end
  36. end
  37. assign neg_rs232_rx = rs232_rx3 & rs232_rx2 & ~rs232_rx1 & ~rs232_rx0;//串口傳輸線的下沿標志
  38. reg bps_start_r;
  39. reg [3:0] num;//移位次數
  40. reg rx_int;  //接收中斷信號
  41. always @(posedge clk or negedge rst_n)
  42.   if(!rst_n) begin
  43.    bps_start_r <=1'bz;
  44.    rx_int <= 1'b0;
  45.   end
  46.   else if(neg_rs232_rx) begin//
  47.   bps_start_r <= 1'b1;  //啟動串口,準備接收數據
  48.    rx_int <= 1'b1;   //接收數據中斷使能
  49.   end
  50.   else if(num==4'd12) begin //接收完有用的信號,
  51.    bps_start_r <=1'b0;  //接收完畢,改變波特率置位,方便下次接收
  52.    rx_int <= 1'b0;   //接收信號關閉
  53.   end
  54.
  55.   assign bps_start = bps_start_r;
  56.
  57.   reg [7:0] rx_data_r;//串口數據寄存器
  58.   reg [7:0] rx_temp_data;//當前數據寄存器
  59.
  60.   always @(posedge clk or negedge rst_n)
  61.    if(!rst_n) begin
  62.      rx_temp_data <= 8'd0;
  63.      num <= 4'd0;
  64.      rx_data_r <= 8'd0;
  65.    end
  66.    else if(rx_int) begin //接收數據處理
  67.     if(clk_bps) begin
  68.      num <= num+1'b1;
  69.      case(num)
  70.        4'd1: rx_temp_data[0] <= rs232_rx;
  71.        4'd2: rx_temp_data[1] <= rs232_rx;
  72.        4'd3: rx_temp_data[2] <= rs232_rx;
  73.        4'd4: rx_temp_data[3] <= rs232_rx;
  74.        4'd5: rx_temp_data[4] <= rs232_rx;
  75.        4'd6: rx_temp_data[5] <= rs232_rx;
  76.        4'd7: rx_temp_data[6] <= rs232_rx;
  77. ……………………
  78. …………限于本文篇幅 余下代碼請從51黑下載附件…………
全部資料51hei下載地址:
uart.7z (1.28 MB, 下載次數: 42)
ID:416262 發表于 2020-6-16 14:47 | 只看該作者
馬克,正需要
ID:810016 發表于 2020-12-19 19:19 | 只看該作者
這個能兩個FPGA板子間進行通信嗎
ID:579775 發表于 2020-12-21 18:26 | 只看該作者
總結的很好
