查看: 3288|回復: 0
單片機4x4鍵盤,數碼管顯示時間,鬧鐘設置 Proteus仿真程序
*鍵時鐘和鬧鐘光標
#鍵用于控制鬧鐘和時鐘切換
A/B/C/D鍵預留,暫時控制LED2燈
數字鍵用于設置鬧鐘和時鐘時間
#include <reg52.h>
unsigned char ReturnKeyValue=0;
unsigned char KeyN=0;
#define WE8 0xfe
#define WE7 0xfd
#define WE6 0xfb
#define WE5 0xf7
#define WE4 0xef
#define WE3 0xdf
#define WE2        0xbf
#define WE1 0x7f
//sbit dula = P2^6;
//sbit wela = P2^7;
sbit BEEP =P3^0;
sbit LED1 =P3^2;
sbit LED2 = P3^3;
unsigned char CurrentSec_ge=0;
unsigned char CurrentSec_shi=0;
unsigned char CurrentMin_ge=0;
unsigned char CurrentMin_shi=0;
unsigned char CurrentHour_ge=0;
unsigned char CurrentHour_shi=0;
unsigned char SetClockSec_ge=0;
unsigned char SetClockSec_shi=0;
unsigned char SetClockMin_ge=0;
unsigned char SetClockMin_shi=0;
unsigned char SetClockHour_ge=0;
unsigned char SetClockHour_shi=0;
unsigned char ChangeTimeCount =0;
uint TimeKCount         =0;
uint TimeGCount  =0;
uint TimeKflag   =0;
uint num = 0;
uint flag;
uint cflag;
uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar code table1[] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x80};
uint rsec = 0, rmin = 0, rhour = 0;
uint csec = 0, cmin = 1, chour = 0;
void clock();
void delay(uint z);
void displaysec(uint sec);
void displaymin(uint min);
void displayhour(uint hour);
unsigned char AlarmTimeCount =0;
void Alarmclock()
        if(rsec == csec && rmin == cmin && rhour == chour)
      BEEP =0;
      LED1 =0;
          AlarmTimeCount=200;
void delay(uint z)
        uint x,y;
        for(x=0;x<z;x++)
                for(y=0;y<110;y++);
        P2 = WE1;
        if((KeyN==1)||(KeyN==7))
                if(TimeKflag==1)
                          P0 = 0xff;
                           P0 = table[sec%10];
                  P0 = table[sec%10];
        delay(3);
        P2 = WE2;
        if((KeyN==2)||(KeyN==8))
        if(TimeKflag==1)
                  P0 = 0xff;
        P0 = table[sec/10];
          P0 = table[sec/10];
        delay(3);
        P2 = WE3;
        P0 = 0xBF;
        delay(3);
         P2 = WE4;
         if((KeyN==3)||(KeyN==9))
                if(TimeKflag==1)
                          P0 = 0xff;
                            P0 = table[min%10]- 0x80;
        delay(5);
        P2 = WE5;
         if((KeyN==4)||(KeyN==10))
                if(TimeKflag==1)
                          P0 = 0xff;
                                    P0 = table[min/10] ;
        delay(5);
        P2 = WE6;
        P0 = 0xBF;
        delay(3);
        P2 = WE7;
         if((KeyN==5) ||(KeyN==11))
                if(TimeKflag==1)
                          P0 = 0xff;
                            P0 = table[hour%10] - 0x80;
        delay(3);
        P2 = WE8;
        if((KeyN==6)||(KeyN==12))
                if(TimeKflag==1)
                          P0 = 0xff;
                            P0 = table[hour/10];
        delay(3);
函數功能:鍵盤掃描子程序
入口參數:
出口參數:
unsigned char keyscan(void)
         unsigned KeyValue =0;
        unsigned char n=0;
        //掃描第一行
        P1=0xfe;
        n=P1;
        n&=0xf0;
        if(n!=0xf0)
                 P1=0xfe;
                 n=P1;
                 n&=0xf0;
                 if(n!=0xf0)
                  delay(10);
                           switch(n)
                    case(0xe0):KeyValue=1;break;  //
                    case(0xd0):KeyValue=2;break;  //
                    case(0xb0):KeyValue=3;break;        //
                    case(0x70):KeyValue=13;break;        //
        //掃描第二行
        P1=0xfd;
        n=P1;
        n&=0xf0;
        if(n!=0xf0)
                  P1=0xfd;
                  n=P1;
                  n&=0xf0;
                  if(n!=0xf0)
                    delay(10);
                          switch(n)
                        case(0xe0):KeyValue=4;break;          //
                    case(0xd0):KeyValue=5;break;         //
                    case(0xb0):KeyValue=6;break;
                    case(0x70):KeyValue=14;break;
        //掃描第三行
        P1=0xfb;
        n=P1;
        n&=0xf0;
        if(n!=0xf0)
                  P1=0xfb;
                  n=P1;
                  n&=0xf0;
                  if(n!=0xf0)
                delay(10);
                           switch(n)
                    case(0xe0):KeyValue=7;break;
                    case(0xd0):KeyValue=8;break;
                           case(0xb0):KeyValue=9;break;
                    case(0x70):KeyValue=15;break;
        //掃描第四行
        P1=0xf7;
        n=P1;
        n&=0xf0;
        if(n!=0xf0)
                  P1=0xf7;
                  n=P1;
                  n&=0xf0;
                  if(n!=0xf0)
                   delay(10);
                           switch(n)
                    case(0xe0):KeyValue=11;break; //*鍵
                    case(0xd0):KeyValue=10;break; //0鍵
                    case(0xb0):KeyValue=12;break; //#鍵
                    case(0x70):KeyValue=16;break;
        return         KeyValue;
void main ()
        EA = 1;
        ET1 = 1;
        TMOD = 0x10;
        TR1 = 1;
         TH1 = (65536-46071)/256;
        TL1 = (65536-46071)%256;
        KeyN=0;
        P1=0x0f;
            Alarmclock();
            ReturnKeyValue = keyscan();
                if(ReturnKeyValue!=0)
                      delay(200);
                                switch(ReturnKeyValue)
                                 case 11:
                                    TimeKCount         =10;
                    TimeGCount  =0;
                    TimeKflag   =1;
                                         KeyN++;
                                        if(KeyN>12)
                                         KeyN=0;
                                 break;
                                 case 12:          //顯示鬧鐘時間
                                    ChangeTimeCount++;
                                 break;
                                  case 13:          // 沒用到 可以用于點亮指示燈
                                   case 14:          //
                                   case 15:          // 沒用到 可以用于點亮指示燈
                                   case 16:          //
                                    LED2=~LED2;
                                 break;
                if(ReturnKeyValue<=10)
                 switch(KeyN)
                        case 1:
                                  if(ReturnKeyValue==10)
                                   rsec=0;
                                   CurrentSec_ge =        0;
                                   rsec =  ReturnKeyValue;
                                   CurrentSec_ge =        ReturnKeyValue;
                        break;
                        case 2:
                                   rsec=0*10+CurrentSec_ge;
                                           if(ReturnKeyValue<6)
                                            rsec =  ReturnKeyValue*10+CurrentSec_ge;
                        break;
                        case 3:
                                      rmin=0;
                                      CurrentMin_ge=0;
                                      rmin =  ReturnKeyValue;
                                    CurrentMin_ge   =  ReturnKeyValue;
                        break;
                        case 4:
                                   rmin=0*10+CurrentMin_ge;
                                            rmin =  ReturnKeyValue*10+  CurrentMin_ge;
                        break;
                        case 5:
                                     rhour=0;
                                     CurrentHour_ge=0;
                                           //if(ReturnKeyValue<=4)
                                            rhour =  ReturnKeyValue;
                                                CurrentHour_ge =  ReturnKeyValue;
                        break;
                        case 6:
                                     rhour=CurrentHour_ge;
                                    if(ReturnKeyValue<=2)
                                       if(CurrentHour_ge>=4)
                                                  if(ReturnKeyValue<=1)
                                               rhour =  ReturnKeyValue*10+CurrentHour_ge;
                        break;
                                case 7:
                                   csec=0;
                                   SetClockSec_ge =        0;
                                   csec =  ReturnKeyValue;
                                   SetClockSec_ge =        ReturnKeyValue;
                        break;
                        case 8:
                                   csec=0*10+SetClockSec_ge;
                                            csec =  ReturnKeyValue*10+SetClockSec_ge;
                        break;
                        case 9:
                                      cmin=0;
                                      SetClockMin_ge=0;
                                   cmin =  ReturnKeyValue;
                                    SetClockMin_ge   =  ReturnKeyValue;
                        break;
                        case 10:
                                   cmin=0*10+SetClockMin_ge;
                                            cmin =  ReturnKeyValue*10+  SetClockMin_ge;
                        break;
                        case 11:
                                     chour=0;
                                     SetClockHour_ge=0;
                                            chour =  ReturnKeyValue;
                                                SetClockHour_ge =  ReturnKeyValue;
                        break;
                        case 12:
                                     chour=SetClockHour_ge;
                                       if(SetClockHour_ge>=4)
                                               chour =  ReturnKeyValue*10+SetClockHour_ge;
                        break;
余下篇幅文件里下 矩陣鍵盤數碼管鬧鐘.zip (165.79 KB, 下載次數: 33)
收藏收藏2 分享淘帖 頂 踩
