查看: 3143|回復(fù): 0
單片機(jī)+Proteus仿真矩陣鍵盤噴泉燈程序
單片機(jī)源程序如下:
#include<reg52.h>                 //庫(kù)文件
#define uchar unsigned char//宏定義無符號(hào)字符型
#define uint unsigned int  //宏定義無符號(hào)整型
                            初始定義
unsigned char code seg7code[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e };
unsigned char k;
uchar jiange=2;  //間隔時(shí)間
uchar chixu=1;   //持續(xù)時(shí)間
                            延時(shí)函數(shù)
void delay10ms(void) //延時(shí)程序
        unsigned char i,j;
        for(i=20;i>0;i--)
        for(j=248;j>0;j--);
                            鍵盤函數(shù)
void Getch ( )        //取鍵值函數(shù)
unsigned char X,Y,Z;
P1=0x0f; //先對(duì)P3 置數(shù) 行掃描
if(P1!=0x0f) //判斷是否有鍵按下
        delay10ms(); //延時(shí),軟件去干擾
        if(P1!=0x0f) //確認(rèn)按鍵按下
                X=P1; //保存行掃描時(shí)有鍵按下時(shí)狀態(tài)
                P1=0xf0; //列掃描
                Y=P1;    //保存列掃描時(shí)有鍵按下時(shí)狀態(tài)
                Z=X|Y; //取出鍵值
switch ( Z ) //判斷鍵值(那一個(gè)鍵按下)
                                case 0xee: k=0; break; //對(duì)鍵值賦值
                                case 0xed: k=1; break;
                                case 0xeb: k=2; break;
                                case 0xe7: k=3; break;
                                case 0xde: k=4; break;
                                case 0xdd: k=5; break;
                                case 0xdb: k=6; break;
                                case 0xd7: k=7; break;
                                case 0xbe: k=8; break;
                                case 0xbd: k=9; break;
                                case 0xbb: k=10;break;
                                case 0xb7: k=11;break;
                                case 0x7e: k=12;break;
                                case 0x7d: k=13;break;
                                case 0x7b: k=14;break;
                                case 0x77: k=15;break;
/**********************T0中斷服務(wù)程序*******************/
        void timer0(void)interrupt 1 using 1
        static uint count=0;
        static uint state=0;
        static uchar i=0;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        count++;
        if(count <200)  //10s
                P2=0x00;
                P3=0x00;
        else if(count==200)
                P2=0xFF;
                P3=0xFF;
        else if(count<200+180*jiange)
                if(count %(20*jiange) ==0)
                        state=count;
                        P2=(0xFF)^(1<<i);
                        i++;
                        if(i==8) i=0;
                else if(state+20*chixu==count)
                        P2=(0xFF);
                        state=0;
                else if(count<200+180*jiange+100)
                        P2=0xFF;
                        P3=0xF0;
    count=0;
                            主函數(shù)
void main(void)
  uchar key=0;
        TMOD=0x01;//定時(shí)器工作方式1
        TH0=(65536-50000)/256;//定時(shí)器附初值
        EA=1; //開全局中斷
        ET0=1;//開定時(shí)器中斷
  TR0=1;//啟動(dòng)定時(shí)
                Getch();                //調(diào)用取鍵值函數(shù)
   if((k<8)&&(k>0))  //矩陣鍵盤前兩行修改持續(xù)時(shí)間
                 chixu=k;
         else if(k>=8)   //矩陣鍵盤后兩行修改間隔時(shí)間
                jiange=k-7;
                              結(jié)束
全部資料51hei下載地址:
噴泉燈.rar (67.92 KB, 下載次數(shù): 23)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
