查看: 1692|回復(fù): 0
單片機(jī)電子琴功能實(shí)現(xiàn)問題 記憶,復(fù)讀這一步用數(shù)組實(shí)現(xiàn)不了
ID:775058 發(fā)表于 2020-6-10 15:05 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
隨機(jī)彈奏曲子時(shí),可以實(shí)時(shí)記憶,并可復(fù)讀(重復(fù)播放)。這一步用數(shù)組實(shí)現(xiàn)不了請(qǐng)大神給看看
#include<reg51.h>
#define SMG P0
#define KEY P1                           //定義數(shù)碼管段碼輸出
sbit LED =P2^1 ;
sbit SPK =P2^0;
sbit K1= P3^2;
sbit K2= P3^3;
sbit K3= P3^0;                                  //定義方波輸出口
unsigned int tone1,tone2,i;
/*****標(biāo)準(zhǔn)音符表*****/
//用于使定時(shí)器初值變化以產(chǎn)生相應(yīng)頻率的定時(shí)
unsigned char code yinfu[]={0xfb,0xe9,      //Do
                            0xfc,0x5c,      //Re
                            0xfc,0xc1,      //Mi
                            0xfc,0xef,      //Fa
                            0xfd,0x45,      //So
                            0xfd,0x92,      //La
                            0xfd,0xd0,      //Si
                            0xfd,0xee,      //Do#
                            0x00,0x00     //音符之間的間隔,只要間隔時(shí)間小于65ms時(shí),
                                                        //喇叭不會(huì)發(fā)出聲音,用作拍子之間的短暫停頓
unsigned char code shengri_tone[]={   1,0,1,2,1,4,3,0,
                                      1,0,1,2,1,5,4,0,
                                      1,0,1,8,6,4,3,2,0,
                                      7,0,7,6,4,5,4,0       //0代表不發(fā)聲,即停頓;數(shù)字即為音調(diào)
unsigned char code shengri_beat[]={   24,1,24,48,48,48,72,5,
                                      24,1,24,48,48,48,48,72,5,
                                  };   //節(jié)拍,即tone表各音調(diào)的延時(shí)
unsigned char code button[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code dis[]={0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0xff};
unsigned char code yindiao[]={1,2,3,4,5,6,7,8};
unsigned char tanzou_tone[30];
unsigned char tanzou_beat[30];
/*****15ms延時(shí)子程序,用于節(jié)拍*****/
void delay(void)
       unsigned char n=15;
       while(n--)
              unsigned char i;
              for(i=0;i<125;i++);
/*****定時(shí)器0初始化*****/
void initTimer(void)
      TMOD=0x01;           //定時(shí)器0,工作方式1;定時(shí)器1,工作方式1
      TH0=tone1;
      TL0=tone2;
/*****定時(shí)器0中斷服務(wù)程序*****/
void timer0(void) interrupt 1
      TH0=tone1;
      TL0=tone2;
      SPK=~SPK;                           //取反,以產(chǎn)生方波
/*****演奏子程序1*****/
void play1(void)
       unsigned char m=0;
       unsigned char s;
       unsigned char a=1;
              EA=0;
              LED=0;
              a=shengri_tone[m];            //取音符
              SMG=dis[a-1];
              s=shengri_beat[m];           //取節(jié)拍
              tone1=yinfu[2*a-2];
              tone2=yinfu[2*a-1];
              EA=1;
              while(s--)
                     delay();
             if((!K1)||(!K2))   //發(fā)現(xiàn)按鍵,立即退出播放
              EA=0;
                  SPK=0;
                  SMG=0xff;
                  m=34;        //改過已
              return;
              LED=1;
              m++;
              if(m>=33) return;      //數(shù)值是shengri相關(guān)表中的元素?cái)?shù)量
void play2(void)
       unsigned char m=0;
       unsigned char s;
       unsigned char a=1;
              EA=0;
              LED=0;
              a=tanzou_tone[m];            //取音符
              SMG=dis[a-1];
              s=tanzou_beat[m];           //取節(jié)拍
              tone1=yinfu[2*a-2];
              tone2=yinfu[2*a-1];
              EA=1;
              while(s--)
                     delay();
           if(P1!=0xff)   //發(fā)現(xiàn)按鍵,立即退出播放
              EA=0;
                  SPK=0;
                  SMG=0xff;        //改過已
              return;
              LED=1;
              m++;
              if(m>=29) return;
void Delay_xMs (unsigned int x)//延時(shí)函數(shù)
    unsigned int i,j;
    for(i=0;i<x;i++)
       for(j=0;j<3;j++);
void Button_Scan(void)
    i=0;
    P1=0xff;
    P3=0xff;
        if(KEY==button[0])
          Delay_xMs(10);
           if(KEY==button[0])
              tone1=0xfb;
                  tone2=0xe9;
                  SMG=dis[0];
                  EA=1;
        if(KEY==button[1])
          Delay_xMs(10);
           if(KEY==button[1])
              tone1=0xfc;
                  tone2=0x5c;
                  SMG=dis[1];
                   EA=1;
        if(KEY==button[2])
           Delay_xMs(10);
           if(KEY==button[2])
              tone1=0xfc;
                  tone2=0xc1;
                  SMG=dis[2];
                   EA=1;
        if(KEY==button[3])
           Delay_xMs(10);
           if(KEY==button[3])
              tone1=0xfc;
                  tone2=0xef;
                  SMG=dis[3];
                   EA=1;
        if(KEY==button[4])
          Delay_xMs(10);
           if(KEY==button[4])
             tone1=0xfd;
                 tone2=0x45;
                  SMG=dis[4];
                   EA=1;
        if(KEY==button[5])
          Delay_xMs(10);
           if(KEY==button[5])
              tone1=0xfd;
                  tone2=0x92;
                  SMG=dis[5];
                   EA=1;
        if(KEY==button[6])
          Delay_xMs(10);
           if(KEY==button[6])
              tone1=0xfd;
                  tone2=0xd0;
                  SMG=dis[6];
                   EA=1;
        if(KEY==button[7])
          Delay_xMs(10);
           if(KEY==button[7])
              tone1=0xfd;
                  tone2=0xee;
                  SMG=dis[7];
                   EA=1;
        if(KEY==0xff)
           Delay_xMs(10);
           if(KEY==0xff)
             EA=0;
                 SPK=0;
                 SMG=0xff;
         switch(P1)
              case 0xfe:
                          while(KEY!=0xfe);
                          tanzou_tone[i++]=yindiao[0];
                      tanzou_beat[i++]=25;
                          break;
                          case 0xfd:
                           while(KEY!=0xfd);
                          tanzou_tone[i++]=yindiao[1];
                          break;
                          case 0xfb:
                           while(KEY!=0xfb);
                          tanzou_tone[i++]=yindiao[2];
                          break;
                          case 0xf7:
                           while(KEY!=0xf7);
                          tanzou_tone[i++]=yindiao[3];
                          break;
                          case 0xef:
                           while(KEY!=0xef);
                          tanzou_tone[i++]=yindiao[4];
                          break;
                          case 0xdf:
                           while(KEY!=0xdf);
                          tanzou_tone[i++]=yindiao[5];
                          break;
                          case 0xbf:
                           while(KEY!=0xbf);
                          tanzou_tone[i++]=yindiao[6];
                          break;
                          case 0x7f:
                           while(KEY!=0x7f);
                          tanzou_tone[i++]=yindiao[7];
                          break;
         switch(P3)
              case 0xfb:play1();break;
                          case 0xfe:play2();break;
void main(void)
       initTimer();
       SMG=dis[8];
       TR0=1;
       ET0=1;
       SPK=0;
        Button_Scan();
