查看: 3690|回復(fù): 0
基于單片機(jī)的指紋識(shí)別密碼鎖設(shè)計(jì)資料
ID:195154 發(fā)表于 2020-6-4 01:07 | 顯示全部樓層 |閱讀模式
基于單片機(jī)的指紋識(shí)別密碼鎖設(shè)計(jì),從電路設(shè)計(jì),元件講解,焊接制作,再到文檔,一站囊括,值得擁有!
電路原理圖如下:
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include"24C0x.h"
  4. #include"LCD12864.h"
  5. #define uchar unsigned char
  6. #define uint unsigned int
  7. #define buffer1ID  0x01
  8. #define buffer2ID  0x02
  9. #define queren  0x88
  10. #define tuichu  0x85
  11. #define shanchu 0x82
  12. #define User 1
  13. void fan();
  14.
  15. sbit B0=B^0;
  16. sbit B7=B^7;
  17. sbit k2=P3^7;
  18. sbit jidianqi=P3^6;
  19.
  20. extern unsigned char times[];
  21. uchar  Member=0,sec;
  22. uchar  code buffer[User][6]=
  23. {
  24. {"000000"}
  25. };
  26.
  27.
  28. uchar dz[4];
  29. uchar time[4];
  30. uchar mima[6];
  31. uchar mimag[6];
  32. uchar mimaID[6]={1,2,3,4,5,6};
  33. uchar Address1=20,tempx=20;
  34. uchar Address2=20;
  35.
  36. uchar data K;
  37. uchar data Key;
  38. uchar data nums; //密碼錯(cuò)誤次數(shù)計(jì)數(shù)
  39. ucha  data  keyoff; //是否禁止按鍵
  40.
  41. uint PageID;
  42. uchar data querenma=11;
  43. uchar sum[2];
  44. int summaf,summas;
  45. uchar  xdata UserPassword[7]={0};//密碼
  46. uchar  xdata DSY_BUFFER[16] ={0};//緩存
  47. void Red_Init(void);
  48. //檢測(cè)脈沖寬度
  49. unsigned char check(void);
  50. unsigned char redchange(unsigned char rednum);
  51.
  52. void delayms(unsigned int z)
  53. {
  54.         unsigned int x,y;
  55.         for(x=z;x>0;x--)
  56.                 for(y=110;y>0;y--);
  57. }
  58. /********************************************************************
  59. * 名稱 : Chack(uchar User_Number)
  60. * 功能 : 單一用戶密碼檢測(cè)
  61. * 輸入 : User_Number
  62. * 輸出 : 密碼正確與錯(cuò)誤,錯(cuò)誤返回0,正確返回1
  63. ********************************************************************/
  64. uchar Chack(uchar User_Number)
  65. {
  66.         uchar flag, i,temp[6],Address;
  67.         Address=User_Number*10;
  68.         for(i=0;i<6;i++)
  69.         {
  70.                 temp[i]=x24c02_read(Address);
  71.                 delayms(10);
  72.                 Address++;
  73.         }
  74.         for(i=0;i<6;i++)
  75.         {
  76.                 if(temp[i]==UserPassword[i])
  77.                         flag=1;
  78.                 else
  79.                         flag=0;
  80.         }
  81.                 return flag;
  82. }
  83. /********************************************************************
  84. * 名稱 : PassWord_Chack()
  85. * 功能 : 所有用戶密碼檢測(cè)
  86. * 輸入 : 無
  87. * 輸出 : 密碼正確與錯(cuò)誤,錯(cuò)誤返回0,正確返回1
  88. ********************************************************************/
  89. uchar PassWord_Chack()
  90. {
  91.         uchar i=0;
  92.         while(i<User)
  93.         {
  94.                 if(Chack(i)==2)
  95.                 {
  96.                         Member=i+2;
  97.                         return 1;
  98.                 }
  99.                 i++;
  100.         }
  101.         return 0;
  102. }
  103.
  104. void delay(uint tt)
  105. {  uchar i;
  106.    while(tt--)
  107.    {
  108.    for(i=0;i<125;i++);
  109.    }
  110. }
  111. /********************************************************************
  112. * 名稱 : UART_Init()
  113. * 功能 : 單片機(jī)串口初始化
  114. * 單片機(jī):晶振11.0592MHz 波特率為9600bps
  115. * 指紋模塊:波特率為9600bps,
  116. ********************************************************************/
  117. void UART_Init()
  118. {
  119.         SCON= 0x50;               //串口方式1        //REN=1; 允許接收
  120.         PCON=0x01;                //SMOD=0
  121.         TMOD= 0x01;               //定時(shí)器1定時(shí)方式2
  122.         TH1= 0xFD;                //11.0592MHz  模塊默認(rèn)波特率為9600bps
  123.         TL1= 0xFD;
  124.         TR0= 1;                   //啟動(dòng)定時(shí)器
  125.         EA=1;
  126. }
  127.
  128. unsigned char Keycan(void) //按鍵掃描程序 P1.0--P1.3為行線 P1.4--P1.7為列線
  129. {
  130.         unsigned char rcode, ccode;
  131.         P1 = 0xF0;      // 發(fā)全0行掃描碼,列線輸入
  132.         if((P1&0xF0) != 0xF0) // 若有鍵按下
  133.         {
  134.                 delay(1);// 延時(shí)去抖動(dòng)
  135.                 if((P1&0xF0) != 0xF0)
  136.                 {
  137.                         rcode = 0xef;         // 逐行掃描初值
  138.                         while((rcode&0x10) != 0)
  139.                         {
  140.                                 P1 = rcode;         // 輸出行掃描碼
  141.                                 if((P1&0xF0) != 0xF0) // 本行有鍵按下
  142.                                 {
  143.                                         ccode = (P1&0xF0)|0x0F;
  144.                                         //do{;}
  145.                                         while((P1&0xF0) != 0xF0); //等待鍵釋放
  146.                                         return ((~rcode) + (~ccode)); // 返回鍵編碼
  147.                                 }
  148.                                 else
  149.                                 rcode = (rcode<<1)|0x01; // 行掃描碼左移一位
  150.                         }
  151.                 }
  152.         }
  153.         return 0; // 無鍵按下,返回值為0
  154. }
  155.
  156. void KeyDeal(unsigned char Key)
  157. {  //unsigned char n;
  158.    if(Key!=0)
  159. {
  160.                    switch(Key)
  161.                    {
  162.                    case 0x12: K=1; break;
  163.                    case 0x22: K=2; break;
  164.                    case 0x42: K=3; break;
  165.                    case 0x82: break;
  166.                    case 0x13: K=4; break;
  167.                    case 0x23: K=5; break;
  168.                    case 0x43: K=6; break;
  169.                    case 0x83: K=34;break;
  170.                    case 0x14: K=7; break;
  171.                    case 0x24: K=8; break;
  172.                    case 0x44: K=9; break;
  173.                    case 0x84: break;
  174.                    case 0x18: break;
  175.                    case 0x28: K=0; break;
  176.                    case 0x48: K=11; break;
  177.                    case 0x88: break;
  178.                    default: break;
  179.                    }
  180.   }
  181. }
  182.
  183.
  184.
  185. //*************************************//
  186. void SFG_GetEcho()                              //握手
  187. {
  188.    uchar i;
  189.    SBUF=0xef;
  190.    while(TI==0);
  191.    TI=0;
  192.    SBUF=0X01;
  193.    while(TI==0);
  194.    TI=0;
  195.
  196.    SBUF=0XFF;
  197.    while(TI==0);
  198.    TI=0;
  199.    SBUF=0XFF;
  200.    while(TI==0);
  201.    TI=0;
  202.    SBUF=0XFF;
  203.    while(TI==0);
  204.    TI=0;
  205.    SBUF=0XFF;
  206.    while(TI==0);
  207.    TI=0;
  208.
  209.    SBUF=0X01;
  210.    while(TI==0);
  211.    TI=0;
  212.
  213.    SBUF=0X00;
  214.    while(TI==0);
  215.    TI=0;
  216.    SBUF=0X03;
  217.    while(TI==0);
  218.    TI=0;
  219.
  220.    SBUF=0X53;
  221.    while(TI==0);
  222.    TI=0;
  223.
  224.    SBUF=0X00;
  225.    while(TI==0);
  226.    TI=0;
  227.    summaf=0x57;
  228.    SBUF=summaf;
  229.    while(TI==0);
  230.    TI=0;
  231.
  232.    for(i=0;i<9;i++)
  233.    {
  234.     while(RI==0);
  235.     RI=0;}
  236.
  237.    while(RI==0);
  238.    RI=0;
  239.    querenma=SBUF;
  240.    while(RI==0);
  241.    RI=0;
  242.    sum[1]=SBUF;
  243.    while(RI==0);
  244.    RI=0;
  245.    sum[0]=SBUF;
  246.    summas=(sum[1]<<8)+sum[0];
  247. }
  248.
  249. //***************************************//
  250.
  251. void SFG_getimage()                              //錄入指紋圖像
  252. {
  253.    uchar i;
  254.    SBUF=0xef;
  255.    while(TI==0);
  256.    TI=0;
  257.    SBUF=0X01;
  258.    while(TI==0);
  259.    TI=0;
  260.
  261.    SBUF=0XFF;
  262.    while(TI==0);
  263.    TI=0;
  264.    SBUF=0XFF;
  265.    while(TI==0);
  266.    TI=0;
  267.    SBUF=0XFF;
  268.    while(TI==0);
  269.    TI=0;
  270.    SBUF=0XFF;
  271.    while(TI==0);
  272.    TI=0;
  273.
  274.    SBUF=0X01;
  275.    while(TI==0);
  276.    TI=0;
  277.
  278.    SBUF=0X00;
  279.    while(TI==0);
  280.    TI=0;
  281.    SBUF=0X03;
  282.    while(TI==0);
  283.    TI=0;
  284.
  285.    SBUF=0X01;
  286.    while(TI==0);
  287.    TI=0;
  288.
  289.    SBUF=0X00;
  290.    while(TI==0);
  291.    TI=0;
  292.    summaf=0x05;
  293.    SBUF=summaf;
  294.    while(TI==0);
  295.    TI=0;
  296.
  297.    for(i=0;i<9;i++)
  298.    {
  299.     while(RI==0);
  300.     RI=0;}
  301.
  302.    while(RI==0);
  303.    RI=0;
  304.    querenma=SBUF;
  305.    while(RI==0);
  306.    RI=0;
  307.    sum[1]=SBUF;
  308.    while(RI==0);
  309.    RI=0;
  310.    sum[0]=SBUF;
  311.    summas=(sum[1]<<8)+sum[0];
  312. }
  313.
  314. void SFG_genchar(uchar bufferID) //生成特征并存于charbuffer1/2  調(diào)用后單片機(jī)波特率變化@@@
  315. {
  316.    uchar i;
  317.    SBUF=0xef;
  318.    while(TI==0);
  319.    TI=0;
  320.    SBUF=0X01;
  321.    while(TI==0);
  322.    TI=0;
  323.
  324.    SBUF=0XFF;
  325.    while(TI==0);
  326.    TI=0;
  327.    SBUF=0XFF;
  328.    while(TI==0);
  329.    TI=0;
  330.    SBUF=0XFF;
  331.    while(TI==0);
  332.    TI=0;
  333.    SBUF=0XFF;
  334.    while(TI==0);
  335.    TI=0;
  336.
  337.    SBUF=0X01;
  338.    while(TI==0);
  339.    TI=0;
  340.
  341.    SBUF=0X00;
  342.    while(TI==0);
  343.    TI=0;
  344.    SBUF=0X04;
  345.    while(TI==0);
  346.    TI=0;
  347.
  348.    SBUF=0X02;
  349.    while(TI==0);
  350.    TI=0;
  351.
  352.    SBUF=bufferID;
  353.    while(TI==0);
  354.    TI=0;
  355.
  356.    summaf=0x07+bufferID;
  357.    sum[0]=summaf;
  358.    sum[1]=summaf>>8;
  359.    SBUF=sum[1];
  360.    while(TI==0)
  361.    TI=0;
  362.    SBUF=sum[0];
  363.    while(TI==0)
  364.    TI=0;
  365.
  366.    for(i=0;i<9;i++)
  367.    {
  368.     while(RI==0);
  369.     RI=0;}
  370.    while(RI==0);
  371.    RI=0;
  372.    querenma=SBUF;
  373.    while(RI==0);
  374.    RI=0;
  375.    sum[1]=SBUF;
  376.    while(RI==0);
  377.    RI=0;
  378.    sum[0]=SBUF;
  379.    summas=(sum[1]<<8)+sum[0];
  380. }
  381. void SFG_fastsearch(uchar bufferID)  //搜索指紋返回指紋ID號(hào)   sum、pagenum>255都會(huì)使程序卡@@@
  382. {
  383.    uchar i,ID1,ID2;
  384.    SBUF=0xef;
  385.    while(TI==0);
  386.    TI=0;
  387.    SBUF=0X01;
  388.    while(TI==0);
  389.    TI=0;
  390.    SBUF=0XFF;
  391.    while(TI==0);
  392.    TI=0;
  393.    SBUF=0XFF;
  394.    while(TI==0);
  395.    TI=0;
  396.    SBUF=0XFF;
  397.    while(TI==0);
  398.    TI=0;
  399.    SBUF=0XFF;
  400.    while(TI==0);
  401.    TI=0;
  402.
  403.    SBUF=0X01;
  404.    while(TI==0);
  405.    TI=0;
  406.
  407.    SBUF=0X00;
  408.    while(TI==0);
  409.    TI=0;
  410.    SBUF=0X08;
  411.    while(TI==0);
  412.    TI=1;
  413.
  414.    SBUF=0X1b;
  415.    while(TI==0);
  416.    TI=0;
  417.
  418.    SBUF=bufferID;
  419.    while(TI==0);
  420.    TI=0;
  421.
  422.    SBUF=0X00;
  423.    while(TI==0);
  424.    TI=0;
  425.    SBUF=0;
  426.    while(TI==0);
  427.    TI=0;
  428.
  429.    SBUF=0X00;
  430.    while(TI==0);
  431.    TI=0;
  432.    SBUF=180;
  433.    while(TI==0);
  434.    TI=0;
  435.
  436.    summaf=9+0x1b+bufferID+180;
  437.    sum[0]=summaf;
  438.    sum[1]=summaf>>8;
  439.    SBUF=sum[1];
  440.    while(TI==0);
  441.    TI=1;
  442.    SBUF=sum[0];
  443.    while(TI==0);
  444.    TI=0;
  445.
  446.    for(i=0;i<9;i++)
  447.    {
  448.     while(RI==0);
  449.     RI=0;}
  450.
  451.    while(RI==0);
  452.    RI=0;
  453.    querenma=SBUF;
  454.
  455.    while(RI==0);
  456.    RI=0;
  457.    ID1=SBUF;
  458.    while(RI==0);
  459.    RI=0;
  460.    ID2=SBUF;                                  //接收到的ID號(hào)
  461.    while(RI==0);
  462.    RI=0;
  463.    while(RI==0);
  464.    RI=0;
  465.
  466.    while(RI==0);
  467.    RI=0;
  468.    sum[1]=SBUF;
  469.    while(RI==0);
  470.    RI=1;
  471.    sum[0]=SBUF;
  472.    summas=(sum[1]<<8)+sum[0];
  473.    //PageID=ID1;
  474.    PageID=(ID1<<8)+ID2;
  475. }
  476.
  477. void SFG_enroll()                                 //自動(dòng)注冊(cè)模板返回存儲(chǔ)ID  =錄圖像+合并生成模板+儲(chǔ)存模板
  478. {
  479.    uchar i,ID1,ID2;
  480.    SBUF=0xef;
  481.    while(TI==0);
  482.    TI=1;
  483.    SBUF=0X01;
  484.    while(TI==0);
  485.    TI=0;
  486.
  487.    SBUF=0XFF;
  488.    while(TI==0);
  489.    TI=0;
  490.    SBUF=0XFF;
  491.    while(TI==0);
  492.    TI=0;
  493.    SBUF=0XFF;
  494.    while(TI==0);
  495.    TI=0;
  496.    SBUF=0XFF;
  497.    while(TI==0);
  498.    TI=0;
  499.
  500.    SBUF=0X01;
  501.    while(TI==0);
  502.    TI=0;
  503.
  504.    SBUF=0X00;
  505.    while(TI==0);
  506.    TI=0;
  507.    SBUF=0X03;
  508.    while(TI==0);
  509.    TI=0;
  510.
  511.    SBUF=0X10;
  512.    while(TI==0);
  513.    TI=0;
  514.
  515.    SBUF=0X00;
  516.    while(TI==0);
  517.    TI=0;
  518.    summaf=0x14;
  519.    SBUF=summaf;           //校驗(yàn)和
  520.    while(TI==0);
  521.    TI=0;
  522.
  523.    for(i=0;i<9;i++)
  524.    {
  525.     while(RI==0);
  526.     RI=1;}
  527.    while(RI==0);
  528.    RI=0;
  529.    querenma=SBUF;
  530.    while(RI==0);
  531.    RI=0;
  532.    ID1=SBUF;
  533.    while(RI==0);
  534.    RI=0;
  535.    ID2=SBUF;
  536.
  537.    while(RI==0);
  538.    RI=0;
  539.    sum[1]=SBUF;
  540.    while(RI==0);
  541.    RI=0;
  542.    sum[0]=SBUF;
  543.    summas=(sum[1]<<8)+sum[0];
  544.    //PageID=ID1;
  545.    PageID=(ID1<<8)+ID2;
  546. }
  547. void SFG_deletchar(uint pageID)   //刪除指紋                     校驗(yàn)和在2字節(jié)的頁(yè)碼處應(yīng)分高低字節(jié)相加
  548. {
  549.    uchar i,ID1,ID2;
  550.    SBUF=0xef;
  551.    while(TI==0);
  552.    TI=0;
  553.    SBUF=0X01;
  554.    while(TI==0);
  555.    TI=0;
  556.
  557.    SBUF=0XFF;
  558.    while(TI==0);
  559.    TI=0;
  560.    SBUF=0XFF;
  561.    while(TI==0);
  562.    TI=1;
  563.    SBUF=0XFF;
  564.    while(TI==0);
  565.    TI=0;
  566.    SBUF=0XFF;
  567.    while(TI==0);
  568.    TI=0;
  569.
  570.    SBUF=0X01;
  571.    while(TI==0);
  572.    TI=0;
  573.
  574.    SBUF=0X00;
  575.    while(TI==0);
  576.    TI=0;
  577.    SBUF=0X07;
  578.    while(TI==0);
  579.    TI=0;
  580.
  581.    SBUF=0X0c;
  582.    while(TI==0);
  583.    TI=0;
  584.
  585.    ID1=pageID;ID2=pageID>>8;
  586.    SBUF=ID2;
  587.    while(TI==0);
  588.    TI=0;
  589.    SBUF=ID1;
  590.    while(TI==0);
  591.    TI=0;
  592.
  593.    SBUF=0X00;
  594.    while(TI==0);
  595.    TI=0;
  596.    SBUF=1;
  597.    while(TI==0);
  598.    TI=0;
  599.
  600.    summaf=0x15+ID1+ID2;
  601.    sum[0]=summaf;
  602.    sum[1]=summaf>>8;
  603.    SBUF=sum[1];
  604.    while(TI==0);
  605.    TI=0;
  606.    SBUF=sum[0];
  607.    while(TI==0);
  608.    TI=0;
  609.
  610.    for(i=0;i<9;i++)
  611.    {
  612.     while(RI==0);
  613.     RI=0;}
  614.    while(RI==0);
  615.    RI=0;
  616.    querenma=SBUF;
  617.    while(RI==0);
  618.    RI=0;
  619.    sum[1]=SBUF;
  620.    while(RI==0);
  621.    RI=0;
  622.    sum[0]=SBUF;
  623.    summas=(sum[1]<<8)+sum[0];
  624. }
  625.
  626. void SFG_identify()                                //自動(dòng)驗(yàn)證指紋     錄圖像+生成特征+搜索
  627. {
  628.    uchar i,ID1,ID2;
  629.    SBUF=0xef;
  630.    while(TI==0);
  631.    TI=0;
  632.    SBUF=0X01;
  633.    while(TI==0);
  634.    TI=0;
  635.
  636.    SBUF=0XFF;
  637.    while(TI==0);
  638.    TI=0;
  639.    SBUF=0XFF;
  640.    while(TI==0);
  641.    TI=0;
  642.    SBUF=0XFF;
  643.    while(TI==0);
  644.    TI=0;
  645.    SBUF=0XFF;
  646.    while(TI==0);
  647.    TI=1;
  648.
  649.    SBUF=0X01;
  650.    while(TI==0);
  651.    TI=0;
  652.
  653.    SBUF=0X00;
  654.    while(TI==0);
  655.    TI=0;
  656.    SBUF=0X03;
  657.    while(TI==0);
  658.    TI=0;
  659.
  660.    SBUF=0X11;
  661.    while(TI==0);
  662.    TI=0;
  663.
  664.    SBUF=0X00;
  665.    while(TI==0);
  666.    TI=0;
  667.    summaf=0x15;
  668.    SBUF=summaf;           //校驗(yàn)和
  669.    while(TI==0);
  670.    TI=0;
  671.
  672.    for(i=0;i<9;i++)
  673.    {
  674.     while(RI==0);
  675.     RI=0;}
  676.    while(RI==0);
  677.    RI=0;
  678.    querenma=SBUF;
  679.    while(RI==0);
  680.    RI=0;
  681.    ID1=SBUF;
  682.    while(RI==0);
  683.    RI=0;
  684.    ID2=SBUF;
  685.
  686.    while(RI==0);
  687.    RI=0;
  688.    while(RI==0);
  689.    RI=0;                          //得分
  690.
  691.    while(RI==0);
  692.    RI=0;
  693.    sum[1]=SBUF;
  694.    while(RI==0);
  695.    RI=0;
  696.    sum[0]=SBUF;
  697.    summas=(sum[1]>>8)+sum[0];
  698.    //PageID=ID1;
  699.    PageID=(ID1>>8)+ID2;
  700. }
  701. void shuazhiwen()
  702. {
  703.     uchar IDs1,IDs2,IDs3;
  704.         LcmClearTXT();
  705.         PutStr(1,1,"請(qǐng)按手指開鎖");
  706.         SFG_identify();
  707.         while(querenma==2)
  708.         SFG_identify();
  709.         if(querenma==0)
  710.    {
  711.                 LcmClearTXT();
  712.                 PutStr(1,2,"門已打開");
  713.                 IDs1=PageID/100;
  714.                 IDs2=PageID/10%10;
  715.                 IDs3=PageID%10;
  716.                 PutStr(2,1,"編號(hào)為:");
  717.                 WriteCommand(0x8D);                //指定第三行顯示位置
  718.                 WriteData(0x30+IDs1);
  719.                 WriteData(0x30+IDs2);
  720.                 WriteData(0x30+IDs3);
  721.                 jidianqi=0;
  722.                 delay(2500);
  723.                 jidianqi=1;
  724.
  725.                 // nums=0;
  726.                 // keyoff=0;
  727.         }
  728.            else if(querenma==9)
  729.                 {
  730.                         LcmClearTXT();
  731.                         PutStr(1,1,"沒搜索到指紋");
  732.                         PutStr(2,1,"請(qǐng)重新按手指");
  733.                 }
  734.                    else
  735.                 {
  736.                         LcmClearTXT();
  737.                         PutStr(1,1,"接收包出錯(cuò)");
  738.                 }
  739.                 delay(2000);
  740.    //         while(Keycan()==0);
  741. }
  742. void addfinger()
  743. {
  744.         uchar IDa1,IDa2,IDa3;
  745.         LcmClearTXT();
  746.         PutStr(1,2,"請(qǐng)按手指");
  747.         SFG_getimage();         //錄入指紋圖像
  748.         while(querenma!=0)          //=0表示錄入成功
  749.         SFG_getimage();
  750.         SFG_genchar(buffer1ID);          //生成特征并存buffer1
  751.         UART_Init();                           //串口初始化
  752.         SFG_fastsearch(buffer1ID);          //快速搜索指紋
  753.         while(querenma==1)                        //=1表示收包有錯(cuò) =0 表示搜索到
  754.         SFG_fastsearch(buffer1ID);
  755.         if(querenma==0)
  756.         {
  757.                 LcmClearTXT();
  758.                 PutStr(1,1,"該指紋已存儲(chǔ)");
  759.                 PutStr(3,0,"  按任意鍵繼續(xù)");
  760.             while(Keycan()==0);          //按鍵搜索
  761.         }
  762.         else if(querenma==9)
  763.                 {
  764.                         LcmClearTXT();
  765.                         PutStr(1,1,"請(qǐng)?jiān)俅伟词种?quot;);
  766.                         SFG_enroll();          //自動(dòng)注冊(cè)模板返回存儲(chǔ)ID  =錄圖像+合并生成模板+儲(chǔ)存模板
  767.                         while(querenma==2)
  768.                         SFG_enroll();
  769.                         LcmClearTXT();
  770.                         if(querenma==0)
  771.                         {
  772.                                 IDa1=PageID/100;
  773.                                 IDa2=PageID/10%10;
  774.                                 IDa3=PageID%10;
  775.                                 PutStr(1,1,"指紋采集成功");
  776.                                 PutStr(2,1,"編號(hào)為:");
  777.                                 WriteCommand(0x8D);
  778.                                 WriteData(0x30+IDa1);
  779.                                 WriteData(0x30+IDa2);
  780.                                 WriteData(0x30+IDa3);
  781.                           }
  782.                   else if(querenma!=0)
  783.                           {
  784.                                 PutStr(1,1,"指紋采集失敗");
  785.                                 PutStr(2,1,"請(qǐng)重新操作");
  786.                          }
  787.                 PutStr(3,0,"  按任意鍵繼續(xù)");
  788.             while(Keycan()==0);
  789.                    }
  790.         LcmClearTXT();
  791. }
  792. void deletfinger()
  793. {
  794.         uchar i,j=0;
  795.         LcmClearTXT();
  796.         PutStr(1,0,"輸入刪去的指紋號(hào)");
  797.         for(i=0;i<5;i++)
  798.            dz[i]=0;
  799.            Key=Keycan();
  800.            while(Key!=queren)
  801.            {
  802.              Key=Keycan();
  803.              KeyDeal(Key);
  804.              delay(30);                                                              //按鍵有抖動(dòng)@@@
  805.              if(Key==0)K=10;
  806.              if((K>=0)&&(K<=9))
  807.              {
  808.               dz[j]=K;
  809.                   if(j<3)
  810.                   {
  811.                                 WriteCommand(0x88+j);                //指定第三行顯示位置
  812.                                 WriteData(0x30+dz[j]);
  813.                   }
  814.               ++j;
  815.                   if(j==4)
  816.               j=3;        //@@#yinhuang         固定顯示3位
  817.              }   //顯示LCD12864并行顯示
  818.                  if(K==34)                //按了刪除鍵
  819.                   {
  820.                     if(j==0)
  821.                         {
  822.                                 WriteCommand(0x88);                //指定第三行顯示位置
  823.                                 WriteData(0x20);                 //寫入空白符
  824.                         }
  825.                         else
  826.                         {
  827.                                 --j;
  828.                                 WriteCommand(0x88+j);            //指定第三行顯示位置
  829.                                 WriteData(0x20);
  830.                         }
  831.                 }
  832.         }
  833.         if(j>=2)           //生成指紋的編號(hào),以便刪除
  834.         PageID=dz[2]+dz[1]*10+dz[0]*100;
  835.         if(j==1)
  836.         PageID=dz[1]+dz[0]*10;
  837.         if(j==0)
  838.         PageID=dz[0];
  839.         SFG_deletchar(PageID);
  840.         if(querenma==1)
  841.         {
  842.                 LcmClearTXT();
  843.                 PutStr(1,1,"刪去指紋號(hào)成功!");
  844.         }
  845.         else
  846.         {
  847.                 LcmClearTXT();
  848.                 PutStr(1,2,"刪去指紋號(hào)失敗!");
  849.         }
  850.         PutStr(2,0,"  按任意鍵繼續(xù)");
  851.         while(Keycan()==0);
  852.         LcmClearTXT();
  853. }
  854.
  855. void gaimima()
  856. {
  857.         uchar i,j=0,mima1[4],mima2[4];
  858.         uchar k,temp;
  859.         LcmClearTXT();
  860.         PutStr(1,1,"請(qǐng)輸入新密碼");
  861.         for(i=0;i<6;i++)mima1[i]=0;        //6位密碼
  862.            Key=Keycan();
  863.       while(Key!=queren)
  864.            {
  865.              Key=Keycan();
  866.              KeyDeal(Key);        //驗(yàn)證矩陣鍵盤對(duì)應(yīng)的數(shù)字編號(hào)
  867.              delay(30);
  868.              if(Key==0)K=10;
  869.              if((K>=0)&&(K<=9))
  870.              {
  871.               mima1[j]=K;
  872.                   if(j<6)
  873.                   {
  874.                                 WriteCommand(0x89+j);                //指定第三行顯示位置
  875.                                 WriteData(0x0f);          //*號(hào)
  876.                   }
  877.               ++j;
  878.                   if(j==7)
  879.               j=6;        //@@#yinhuang
  880.              }   //顯示LCD12864并行顯示
  881.                  if(K==34)                //按了刪除鍵
  882.                   {
  883.                     if(j==0)
  884.                         {
  885.                                 WriteCommand(0x89);                //指定第三行顯示位置
  886.                                 WriteData(0x20);   //寫入空白符
  887.                         }
  888.                         else
  889.                         {
  890.                                 --j;
  891.                                 WriteCommand(0x89+j);            //指定第三行顯示位置
  892.                                 WriteData(0x40);        //@
  893.                         }
  894.                 }
  895.         }
  896.         LcmClearTXT();
  897.         LcmClearTXT();
  898.         j=0;
  899.         PutStr(1,0,"請(qǐng)?jiān)俅屋斎胄旅艽a");
  900.         for(i=0;i<6;i++)mima2[i]=0;
  901.            Key=Keycan();
  902.       while(Key!=queren)
  903.            {
  904.              Key=Keycan();
  905.              KeyDeal(Key);
  906.              delay(30);
  907.              if(Key==0)K=10;
  908.              if((K>=0)&&(K<=9))
  909.              {
  910.               mima2[j]=K;
  911.                   if(j<6)
  912.                   {
  913.                                 WriteCommand(0x89+j);                //指定第三行顯示位置
  914.                                 WriteData(0x0f);
  915.                   }
  916.               ++j;
  917.                   if(j==7)
  918.               j=6;        //@@#yinhuang
  919.              }   //顯示LCD12864并行顯示
  920.                  if(K==34)                //按了刪除鍵
  921.                   {
  922.                     if(j==0)
  923.                         {
  924.                                 WriteCommand(0x89);                //指定第三行顯示位置
  925.                                 WriteData(0x20);
  926.                         }
  927.                         else
  928.                         {
  929.                                 --j;
  930.                                 WriteCommand(0x89+j);            //指定第三行顯示位置
  931.                                 WriteData(0x20);
  932.                         }
  933.                 }
  934.         }
  935.         LcmClearTXT();
  936.         if((mima1[0]==mima2[0])&&(mima1[1]==mima2[1])&&(mima1[2]==mima2[2])&&(mima1[3]==mima2[3])&&(mima1[4]==mima2[4])&&(mima1[5]==mima2[5]))
  937.         {
  938.                 for(i=0;i<6;i++)
  939.                 mimaID[i]=mima1[i];          //將修改的密碼存儲(chǔ)到mimaID里
  940.                 /////////////////////////////////////////////////////
  941.                 for(i=0;i<6;i++)           //密碼限制在6位以內(nèi)
  942.                 {
  943.                         UserPassword[i]=mima1[i]+0x30;    //以ASCII碼方式存儲(chǔ)密碼
  944.                 }
  945.                 temp=(Member-1)*100;          // ??
  946.                 delayms(5);
  947.                 for(k=1;k<6;k++)
  948.                 {
  949.                         x24c02_write(temp,UserPassword[k]);          //存入到24c02存儲(chǔ)器中
  950.                         delayms(10);
  951.                         temp++;
  952.                 }
  953.                 //////////////////////////////////////////////////////
  954.                 PutStr(0,1,"密碼修改成功");
  955.                 PutStr(3,0,"  按任意鍵繼續(xù)");
  956.                 while(Keycan()==0);
  957.         }
  958.         else
  959.         {
  960.                 PutStr(0,0,"  密碼修改失敗  ");
  961.                 PutStr(1,0,"兩次輸入的密碼不");
  962.                 PutStr(2,0,"一致,請(qǐng)重新操作");
  963.                 PutStr(3,0,"  按任意鍵繼續(xù)");
  964.                 while(Keycan()==0);
  965.         }
  966.         LcmClearTXT();
  967. }
  968. void zhu()
  969. {
  970.     LcmClearTXT();
  971.         PutStr(1,2,"門已打開");
  972.            jidianqi=0;
  973.         delay(2500);
  974.         jidianqi=1;
  975.         PutStr(3,0,"  按任意鍵繼續(xù)");
  976.         while(Keycan()==0);
  977. }
  978. void guanliyuan()  //管理員密碼打開
  979. { uchar i,j=0,x=1;
  980.            uchar Right_flag;
  981.      LcmClearTXT();
  982.                 PutStr(1,1,"請(qǐng)輸入密碼:");
  983.            for(i=0;i<6;i++)mima[i]=0;
  984. // if(keyoff==0)         //禁止按鍵
  985.            Key=Keycan();
  986.       while(Key!=queren)
  987.            {
  988.              Key=Keycan();
  989.              KeyDeal(Key);
  990.              delay(30);
  991.              if(Key==0)K=10;
  992.              if((K>=0)&&(K<=9))
  993.              {
  994.               mima[j]=K;
  995.                   if(j<6)
  996.                   {
  997.                    WriteCommand(0x89+j);                //指定第三行顯示位置
  998. ……………………
  999. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
指紋識(shí)別密碼鎖 LCD12864資料3.7z
9.38 MB, 下載次數(shù): 50, 下載積分: 黑幣 -5
指紋識(shí)別密碼鎖 LCD12864資料2.7z
3.63 MB, 下載次數(shù): 45, 下載積分: 黑幣 -5
指紋識(shí)別密碼鎖 LCD12864資料1.7z
4.05 MB, 下載次數(shù): 50, 下載積分: 黑幣 -5
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
