查看: 4204|回復: 1
編譯警告*** WARNING L2: REFERENCE MADE TOUNRESOLVED EXTERNAL
ID:458705 發表于 2020-5-29 12:07 | 顯示全部樓層 |閱讀模式
本人真實小白,網上找到的兩相四線步進電機程序,想用的單片機型號STC 89R52C,用keil4編譯后出現警告如下。
  SYMBOL:  ?C_START
   MODULE:  STARTUP.obj (?C_STARTUP)
   SYMBOL:  ?C_START
   ADDRESS: 000DH
Program Size: data=9.0 xdata=0 code=15
creating hex file from "步進1"...
"步進1" - 0Error(s), 2 Warning(s).
源程序如下:
#include"reg52.h"
#include"INTRINS.H"
#include<absacc.h>
#include<math.h>
void check_addr(void); /*地址核對*/
uchar code slave_addr[4]={00,01,02,255};   /*從機地址*/
uchar idata T0low, T0high,common_count,input_order,cmd_in_permit,interval;
uchar sent_ok,speed_change,start_up,start_end,address_true,i;
uint y1;
uint code add[100]={60006,62771,63693,64154,64430,64614,64746,64845,
64922,64983,65033,65075,65111,65141,65167,65190,65211,65229,65245,65260,
65273,65285,65296,65306,65315,65323,65331,65339,65345,65352,65358,65363,
65368,65373,65378,65382,65387,65390,65394,65398,65401,65404,65407,65410,
65413,65416,65418,65421,65423,65425,65428,65430,65432,65434,65435,65437,
65439,65441,65442,65444,65445,65447,65448,65450,65451,65452,65453,65455,
65456,65457,65458,65459,65460,65461,65462,65463,65464,65465,65466,65467,
65468,65469,65469,65470,65471,65472,65472,65473,65474,65475,65475,65476,
65477,65477,65478,65478,65479,65480,65480,65481};
sbit P2_0=P2^0; /*作輸入步進電機的脈沖信號發送口*/
sbit P2_2=P2^2; /*作輸入步進電機的旋轉方向信號發送口*/
sbit P1_0=P1^0; /*作串口輸出信號的使能口,P1_0=0時接通串口,輸出信號*/
sbit WD=P1^7;   /*看門狗*/
main()
   P2_0=0;
   P2_2=0;  /*步進電機的旋轉方向待試驗后確定*/
   P1_0=1;  /*開機時需要關斷,串口發送功能,需要時再接通*/
   WD=1;    /*看門狗先為1,電平翻轉為喂狗*/
   i=0;
   common_count=0;
   cmd_in_permit=0;
   input_order=0;
   interval=0;
   address_true=1;
   speed_change=0;
   start_up=0;
   start_end=0;
   sent_ok=0;     //允許發送
   EA=1;          /*開放總中斷*/
   TMOD=0x21;
   TH1 = 0xFD;     //波特率9600
   TL1 = 0xFD;
   SCON = 0xd0;    //設定串行口工作方式
   PCON &= 0x00;   //波特率不倍增
   SM2=1;
   TR1=1;
   ES=1;           //啟動定時器1
   T2MOD=00;
   T2CON=0x00;
   RCAP2H=0xEE;    //賦T2的預置值0xA600,25MS,0xB800,20MS,0xCA00,
                   //15MS,0xDC00,10MS,0xEE00,5MS
   RCAP2L=0x00;
   TR2=1;          //啟動定時器
   ET2=1;          //打開定時器2中斷
do
        if(address_true==1)
        address_true=0;
           check_addr();
     if(start_up==1&&start_end==0)   //第一次啟動
   y1=add[common_count];
   T0high=(uchar)(y1>>8);      /*取y1的高8位*/
   T0low=(uchar)(y1&0x00ff);   /*取y1的低8位*/
   TR0=1;
   ET0=1;                      /*允許T/C0中斷*/
   start_end=1;
   if(speed_change==1)
    if(interval>=0&&interval<=0x63)
    if(interval>common_count)
   {common_count=common_count+1; }
    if(interval<common_count)
   {common_count=common_count-1; }
   speed_change=0;
if(sent_ok==1)
   sent_ok=0;
   P1_0=0;
   for(i=0;i<=20;i++){_nop_();}
     TI=0;SBUF=T0high;
     while(TI==0);TI=0;
     TI=0; SBUF=T0low;
     while(TI==0);TI=0;
     P1_0=1;
     for(i=0;i<=20;i++) {_nop_();}
     SM2=1;
while(1);
void timer0(void)interrupt 1 using 3
    P2_0=~P2_0;
    T0high =(uchar)(y1>>8);      /*取y1的高8位*/
    T0low = (uchar)(y1&0x00ff);  /*取y1的低8位*/
    TH0=T0high;                /*高8位T0high送定時器0的TH0*/
    TL0=T0low;                 /*低8位T0low送定時器0的TL0*/
void timer2(void)interrupt 5 using 2
    TF2=0;                     /*T2溢出中斷需軟件清0*/
    speed_change=1;  //速度可以改變標示,以便主程序處理
    WD=!WD;                    /*MAX813喂狗*/
void inte_SERIAL() interrupt 4 using 1 /*串口0中斷服務子程序*/
   uchar key_in;
   key_in=0;
   if(RI)
特請大俠指教,錯誤在哪里;如何修改?
ID:458705 發表于 2020-5-29 20:05 | 顯示全部樓層
又在網上找到另一個步進電機的控制程序,又建一個工程,可是編譯之后仍然出現同樣的警告提示:
不懂英語,翻詞典好像是說要“參考未解決的外部問題”????真不知道哪里出問題?急求解答!!!
