查看: 6174|回復(fù): 10
STM32狀態(tài)機(jī)思想實(shí)現(xiàn)單擊、雙擊、長(zhǎng)按 源程序
ID:763998 發(fā)表于 2020-5-29 09:35 | 顯示全部樓層 |閱讀模式
/*直接復(fù)制以下代碼,實(shí)現(xiàn),自己在獨(dú)立研究吸收*/
#include "stm32f10x.h"
#include "bitband_cm3.h"
#include "systick.h"
#define N_key    0             //無(wú)鍵
#define S_key    1             //單鍵
#define D_key    2             //雙鍵
#define L_key    3             //長(zhǎng)鍵
#define KEY_AN (GPIOA->IDR & 1<<0)
#define BEEF PCout(3)
*函數(shù)名:delay_us
*功  能:延遲1us
*參  數(shù):us最大2^24/9=1864135us
*返  回:無(wú)
*備  注:無(wú)
void delay_us(u16 us)
        SysTick->LOAD = us * 9;        //裝載計(jì)數(shù)值
        SysTick->VAL = 0;                //清空當(dāng)前值
        SysTick->CTRL |= 1;        //使能計(jì)數(shù)器
        while(!(SysTick->CTRL & (1 << 16)));//等待計(jì)數(shù)結(jié)束
        SysTick->CTRL &=~ 1;//關(guān)閉計(jì)數(shù)
//LED初始化
void LED_Init(void)
#if 0
        RCC->APB2ENR |= 3<<3;//開啟PB/PC口時(shí)鐘
        GPIOB->CRL &=~(0XF<<4*1);//清PB1
        GPIOB->CRL |=(0X3<<4*1);//通用輸出 50M
        GPIOC->CRL &=~(0XF<<4*5);//清PC5
        GPIOC->CRL |=(0X3<<4*5);//通用輸出 50M
        GPIOB->ODR |=(1<<1);//默認(rèn)給高電平,關(guān)燈,
        GPIOC->ODR |=(5<<1);
//        GPIOB->ODR &=~(1<<1);//點(diǎn)燈
//        GPIOC->ODR &=~(5<<1);
        #else
        GPIO_InitTypeDef GPIO_InitStruct;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOB,ENABLE);//開啟PB/PC口時(shí)鐘.
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_1;
        GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;//通用推挽
        GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;//50M
        GPIO_Init(GPIOB, &GPIO_InitStruct);//PB1
        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_5;
        GPIO_Init(GPIOC, &GPIO_InitStruct);//PC5
        GPIO_SetBits(GPIOB, GPIO_Pin_1);//默認(rèn)給高電平,關(guān)燈,不能少了這步,因?yàn)檩敵鰯?shù)據(jù)寄存器默認(rèn)值給低電平
        GPIO_SetBits(GPIOC, GPIO_Pin_5);
//        GPIO_ResetBits(GPIOB, GPIO_Pin_1);//開燈
//        GPIO_ResetBits(GPIOC, GPIO_Pin_5);
//        PBout(1)=0;
//        PCout(5)=0;
        #endif
//按鍵初始化
void KEY_Iint(void)
        RCC->APB2ENR |= 1<<2;//開啟PA口時(shí)鐘
//蜂鳴器初始化
void BEEF_Iint(void)
        RCC->APB2ENR |= 1<<4;//開啟PC口時(shí)鐘
        GPIOC->CRL &=~(0XF<<4*3);//清PC3
        GPIOC->CRL |=(0X3<<4*3);//通用輸出 50M
        驅(qū)動(dòng)層
        1.完成按鍵的消抖,松手檢測(cè)
        2.把過程細(xì)分為一個(gè)個(gè)狀態(tài)
        3.實(shí)現(xiàn)長(zhǎng)按與單擊功能
        按鍵初始態(tài)
        按鍵確認(rèn)態(tài)
        按鍵計(jì)時(shí)態(tài)
        等待按鍵釋放態(tài)
unsigned char key_driver()
    static u8 key_state = 0, key_time = 0;
    u8 key_return = N_key;
    switch (key_state)
      case 0:                                      // 按鍵初始態(tài)
        if (!KEY_AN) key_state = 1;         // 鍵被按下,狀態(tài)轉(zhuǎn)換到按鍵消抖和確認(rèn)狀態(tài)
        break;
      case 1:                                                              // 按鍵消抖與確認(rèn)態(tài)
        if (!KEY_AN)
             key_time = 0;
             key_state = 2;                                                           // 按鍵仍然處于按下,消抖完成,狀態(tài)轉(zhuǎn)換到按下鍵時(shí)間的計(jì)時(shí)狀態(tài),但返回的還是無(wú)鍵事件
             key_state = 0;                                                           // 按鍵已抬起,轉(zhuǎn)換到按鍵初始態(tài)。此處完成和實(shí)現(xiàn)軟件消抖,其實(shí)按鍵的按下和釋放都在此消抖的。
        break;
      case 2:        // 按下鍵時(shí)間的計(jì)時(shí)狀態(tài)
        if(KEY_AN)
             key_return = S_key;                        // 此時(shí)按鍵釋放,說明是產(chǎn)生一次短操作,回送S_key
             key_state = 0;                                                           // 轉(zhuǎn)換到按鍵初始態(tài)
        else if (++key_time >= 100)                     // 繼續(xù)按下,計(jì)時(shí)加10ms(10ms為本函數(shù)循環(huán)執(zhí)行間隔)
             key_return = L_key;                        // 按下時(shí)間>1000ms,此按鍵為長(zhǎng)按操作,返回長(zhǎng)鍵事件
             key_state = 3;                                                           // 轉(zhuǎn)換到等待按鍵釋放狀態(tài)
        break;
      case 3:        // 等待按鍵釋放狀態(tài),此狀態(tài)只返回?zé)o按鍵事件
        if (KEY_AN) key_state = 0;                             // 按鍵已釋放,轉(zhuǎn)換到按鍵初始態(tài)
        break;
    return key_return;
        業(yè)務(wù)邏輯層
        1.單擊、雙擊、長(zhǎng)按的分配
unsigned char key_read()
    static u8 key_m = 0, key_time_1 = 0;
    u8 key_return = N_key,key_temp;
    key_temp = key_driver();
    switch(key_m)
        case 0:
            if (key_temp == S_key )
                 key_time_1 = 0;               // 第1次單擊,不返回,到下個(gè)狀態(tài)判斷后面是否出現(xiàn)雙擊
                 key_m = 1;
                 key_return = key_temp;        // 對(duì)于無(wú)鍵、長(zhǎng)鍵,返回原事件
            break;
        case 1:
            if (key_temp == S_key)             // 又一次單擊(間隔肯定<500ms)
                 key_return = D_key;           // 返回雙擊鍵事件,回初始狀態(tài)
                 key_m = 0;
            {                                  // 這里500ms內(nèi)肯定讀到的都是無(wú)鍵事件,因?yàn)殚L(zhǎng)鍵>1000ms,在1s前低層返回的都是無(wú)鍵
                 if(++key_time_1 >= 30)
                      key_return = S_key;      // 500ms內(nèi)沒有再次出現(xiàn)單鍵事件,返回上一次的單鍵事件
                      key_m = 0;               // 返回初始狀態(tài)
             break;
    return key_return;
        單擊:300ms~1000ms之間
        雙擊:300ms內(nèi)
        長(zhǎng)按:超過1s
        單擊:控制LED1
        雙擊:控制LED2
        長(zhǎng)按:控制蜂鳴器
int main(void)
        LED_Init();
        KEY_Iint();
        BEEF_Iint();
                switch(key_read())
                        case N_key:
                                delay_ms(10);
                        break;
                        case S_key:
                                PBout(1)=!PBout(1);
                        break;
                        case D_key:
                                PCout(5)=!PCout(5);
                                break;
                        case L_key:
                                BEEF = !BEEF;
                                break;
        return 0;
評(píng)分
參與人數(shù) 3黑幣 +68 收起 理由
AAA_MCU + 12 很給力!
hzd530 + 6
查看全部評(píng)分
ID:85865 發(fā)表于 2020-6-28 08:17 | 顯示全部樓層
這個(gè)可以有
ID:763998 發(fā)表于 2020-6-28 09:22 | 顯示全部樓層
哈哈哈,差點(diǎn)失去發(fā)帖的動(dòng)力,幸好有你
ID:790159 發(fā)表于 2020-6-29 10:18 | 顯示全部樓層
已學(xué)習(xí) ,感謝樓主分享
ID:82098 發(fā)表于 2021-4-25 20:13 | 顯示全部樓層
四個(gè)按鍵如何處理?敬請(qǐng)指教!
ID:519089 發(fā)表于 2021-7-14 21:06 | 顯示全部樓層
學(xué)習(xí)了,,,支持原創(chuàng)
ID:584195 發(fā)表于 2021-11-15 18:22 | 顯示全部樓層
可以帶我寫指針函數(shù)的寫法嗎?
ID:809754 發(fā)表于 2022-8-5 16:23 | 顯示全部樓層
很多按鍵呢  怎么搞
ID:165291 發(fā)表于 2022-11-14 20:08 | 顯示全部樓層
多按鍵有必要這么寫么?
ID:52721 發(fā)表于 2023-1-11 11:10 | 顯示全部樓層
對(duì)于單鍵而言,是個(gè)很不錯(cuò)的選擇。
ID:890367 發(fā)表于 2023-1-11 18:24 來自觸屏版 | 顯示全部樓層
多按鍵呢
