查看: 2993|回復(fù): 0
請(qǐng)教,隨機(jī)排布函數(shù)的設(shè)計(jì)
ID:50562 發(fā)表于 2013-5-26 14:01 | 顯示全部樓層 |閱讀模式
隨機(jī)排布:任一順序的0~9的排列,如:8,3,1,5,4,0,9,7,6,2
用單片機(jī)生成一個(gè)隨機(jī)排列,然后輸出到P2口。
請(qǐng)大神指點(diǎn)啊
程序(有問題)如下:
#include<stdio.h>
#include<REG52.H>
unsigned short rtab[10] = {3, 9, 4, 1, 5, 0, 7, 8, 2, 6};
unsigned short divider[9] = {2, 3, 5, 7, 11, 13, 17, 19, 23};
unsigned short skip[9] = {0, 0, 0, 0, 0, 0, 0, 0, 0};      //skip是在rtab中的偏移
unsigned short temp[9] = {0, 0, 0, 0, 0, 0, 0, 0, 0};      //暫存skip
unsigned short result[10] = {0, 0, 0, 0, 0, 0, 0, 0, 0};   //存放隨機(jī)排布
unsigned int count=1;
void test()        //如果count能夠被divider整除,那么skip++。
int i;
for(i=0;i<=8;i++)
  if(count%divider==0)
   if(skip>=9-i)   //skip[]的進(jìn)制分別是10,9,8,.....,3,2
    skip=0;
    skip++;
   break;
void timer1_int() interrupt 3 using 2     //計(jì)時(shí)器1中斷程序,令count非溢出地加1
if(count>=65531)
  count=1;
  count++;
test();
void swap(unsigned short x,unsigned short y)   //將x,y對(duì)換
unsigned short tep;
tep=x;
x=y;
y=tep;
void refresh()                     //刷新,產(chǎn)生隨機(jī)排布result[10];
//TR1 = 0;
int i=0;
for(i=0; i<=8; i++ )
  temp=skip;
//TR1=1;
for(i=0;i<=8;i++)                        //問題:該循環(huán)中,swap()不能實(shí)現(xiàn)rtab[temp]與rtab[9-i]的對(duì)換
  result=rtab[temp];
  swap(rtab[temp],rtab[9-i]);  //保證下次取到的數(shù)rtab[temp[i+1]]不與已經(jīng)取到的數(shù)result[0~i]重復(fù)
result=rtab[0];
void display()                  //將result數(shù)組的內(nèi)容依次輸出到P2口
int i;
for(i=0; i<=9;i++ )
  P1=i;
  P2=result;
void int0_service() interrupt 2 using 3    //有鍵被按下時(shí),調(diào)用外部中斷1程序
switch(P1)
  case'0':
  case'1':
  case'2':
  case'3':
  case'4':
  case'5':
  case'6':
  case'7':
  case'8':
  case'9':P2=P1;/*save(P1);*/refresh();display();break;
// case'c':clear();break;                                 //清除一位
  case'r':refresh();display();break;                     //刷新
// case'e':enter();P2=enter;break;                       //確定
  default:/*P2=error;*/break;                          //顯示出錯(cuò)
TMOD |= 0x20;             //timer 1, mode 2, 8-bit reload
TH1   = 221;              //初始值
EA    = 1;                //開所有中斷
ET1   = 1;                //開計(jì)時(shí)器1溢出中斷
EX1   = 1;                //開外部中斷1
PX1   = 1;                //設(shè)外部中斷1為高優(yōu)先級(jí)
PT1   = 0;                //設(shè)計(jì)時(shí)器1中斷為低優(yōu)先級(jí)
TR1   = 1;                //計(jì)時(shí)開始
    while(1)                  //當(dāng)按下確定鍵時(shí),開始程序
  if(P1=='e')
   break;
refresh();
  display();
