查看: 11616|回復: 15
基于STM32的ADC仿真+OLED顯示源程序+Proteus仿真
  1. #include "stm32f10x.h"
  2. u8 wd=0;
  3. u8 sd=0;
  4. unsigned char a[80] ;
  5. unsigned char DHT[5];
  6. float ADC_Data = 0 ;
  7.   void ADC1_GPIO_Config(void){
  8.     GPIO_InitTypeDef GPIO_InitStructure;
  9.           RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_ADC1, ENABLE);        //使能ADC1,GPIOC時鐘
  10.
  11.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //
  12.     //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//為什么沒有配置這個????
  13.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;        //模擬輸入
  14.     GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PC4
  15.
  16.          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //
  17.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//為什么沒有配置這個????
  18.
  19.     GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PC4
  20. }
  21. void ADC_Config(void)
  22. {
  23.
  24.   ADC_InitTypeDef ADC_InitStructure;//ADC結構體變量//注意在一個語句快內變量的聲明要放在可執行語句的前面,否則出錯,因此要放在ADC1_GPIO_Config();前面
  25.   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在獨立模式
  26.   ADC_InitStructure.ADC_ScanConvMode =        DISABLE; //使能掃描
  27.   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC轉換工作在連續模式
  28.   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//由軟件控制轉換,不使用外部觸發
  29.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//轉換數據右對齊
  30.   ADC_InitStructure.ADC_NbrOfChannel = 1;//轉換通道為1
  31.   ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC
  32.
  33.   ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
  34.   //ADC1選擇信道14,音序等級1,采樣時間55.5個周期
  35. //  ADC_DMACmd(ADC1, ENABLE);//使能ADC1模塊DMA
  36.   ADC_Cmd(ADC1, ENABLE);//使能ADC1
  37.         ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
  38.   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  39. //  ADC_ResetCalibration(ADC1); //重置.(復位).ADC1校準寄存器
  40. //  while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校準重置完成
  41. //  ADC_StartCalibration(ADC1);//開始ADC1校準
  42. //  while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校準完成
  43. //  ADC_SoftwareStartConvCmd(ADC1, ENABLE); //使能ADC1軟件開始轉換
  44. }
  45. int main(void)
  46. {
  47.          int i = 0 ;
  48.
  49.          delay_init()        ;
  50.    LCD_Init() ;
  51.
  52.
  53.          Key_Init() ;              //按鍵初始化
  54.
  55.          NVIC_Config() ;           //中斷配置
  56. //
  57.          TIME3_init() ;            //定時器配置
  58.           ADC1_GPIO_Config() ;
  59.          ADC_Config() ;
  60.
  61.    while(1)
  62.          {
  63.                  GPIO_SetBits(GPIOA,GPIO_Pin_7) ;
  64.                  if(GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_8) == 1)
  65.                  {
  66.                         ADC_Data = ADC_GetConversionValue(ADC1);
  67.                         Display();                      //菜單顯示
  68.                  }else
  69.                  {
  70.                         LCD_Fill(0x00);  //初始清屏
  71.                  }
  72.
  73.
  74.
  75.         }
  76.
  77. }
仿真.7z (297.18 KB, 下載次數: 752)
收藏收藏10 分享淘帖 頂1 踩
來自 21#
ID:262 發表于 2022-10-13 21:05 | 只看該作者
QI0609 發表于 2022-10-13 20:39
顯示屏沒現象...
我用Proteus8.8打開的效果如圖
ID:631437 發表于 2020-6-15 09:29 | 只看該作者
有漢字顯示的源碼與仿真??
ID:661659 發表于 2020-6-22 15:27 | 只看該作者
這個是實現什么操作的
ID:24075 發表于 2020-6-22 17:30 | 只看該作者
感謝樓主分享 正在學習中
ID:764512 發表于 2020-6-24 00:00 | 只看該作者
謝謝分享
ID:302325 發表于 2020-6-24 11:56 | 只看該作者
51黑  有你更精彩
ID:727465 發表于 2020-6-24 20:53 | 只看該作者
謝謝分享
ID:786934 發表于 2020-6-24 21:23 | 只看該作者
我為什么打不開那個工程文件
ID:623452 發表于 2020-6-27 00:09 | 只看該作者
問一下,在proteus仿真 adc  為啥會卡死!      while(ADC_GetResetCalibrationStatus(ADC1));
ID:712004 發表于 2020-6-29 10:48 | 只看該作者
打不開,別下載了,可惜我的積分
ID:410541 發表于 2020-10-30 14:13 | 只看該作者
謝謝樓主分享啊,這個不錯
ID:688286 發表于 2020-12-21 12:41 | 只看該作者
@唐海 發表于 2020-6-15 09:29
有漢字顯示的源碼與仿真??
可以自己生成字庫顯示
ID:872739 發表于 2021-1-3 19:34 | 只看該作者
怎么在Protuse里面找OLED
ID:442274 發表于 2021-4-25 22:10 | 只看該作者
謝謝 很NICE
ID:504404 發表于 2022-10-13 20:39 | 只看該作者
顯示屏沒現象...
