查看: 3622|回復(fù): 9
單片機(jī)藍(lán)牙小車通信問題,朋友們急求答案
ID:711376 發(fā)表于 2020-5-24 18:21 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
8黑幣
DIY的藍(lán)牙小車,在手機(jī)和單片機(jī)通信的時候APP顯示已經(jīng)連接了藍(lán)牙,但點擊APP上設(shè)置的對應(yīng)按鈕時小車沒有反應(yīng),有沒有遇到這種情況的朋友,求解,程序在評論里。
ID:711376 發(fā)表于 2020-5-24 18:22 | 只看該作者
#include <reg52.h>
typedef unsigned int u16;
typedef unsigned char u8;
sbit IN1 = P1^2;
sbit IN2 = P1^3;
sbit IN3 = P1^6;
sbit IN4 = P1^7;
/*sbit EN1 = P1^4;
  sbit EN2 = P1^5;
#define left_motor_go                IN1 =1 , IN2 = 0
#define left_motor_back                IN1 = 0, IN2 = 1
#define right_motor_go                IN3 = 1, IN4 = 0
#define right_motor_back        IN3 = 0, IN4 = 1
u16 receivedata;
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
        for(y = 114; y > 0 ; y--);
void UART_INIT()
        PCON=0x00;
  SCON=0x50;
        EA = 1;
        ES = 1;
        TMOD = 0x20;
  TH1 = 0xfd;
        TL1 = 0xfd;
/*     void  run(void)
     push_val_left  =pwm;
         push_val_right =pwm;
                 if(pwm==10) pwm=0;
                if(pwm==0&&pwm<0) pwm=0;
/*                    PWMµ÷ÖÆµç»úתËÙ                                   */
/*                    ×ó²àµç»úµ÷ËÙ                                        */
/*µ÷½Úpush_val_leftµÄÖµ¸Ä±äµç»úתËÙ,Õ¼¿Õ±È            */
/*                void pwm_out_left_moto(void)
   if(Left_moto_stop)
    if(pwm_val_left<=push_val_left)
                                 Left_moto_pwm=1;
                                        Left_moto_pwm=0;
        if(pwm_val_left>=10)
        pwm_val_left=0;
           Left_moto_pwm=0;
/*                    ÓÒ²àµç»úµ÷ËÙ                                  */
/*  void pwm_out_right_moto(void)
  if(Right_moto_stop)
    if(pwm_val_right<=push_val_right)
                                 Right_moto_pwm=1;
                                         Right_moto_pwm=0;
        if(pwm_val_right>=10)
            pwm_val_right=0;
   else    {Right_moto_pwm=0;        }
/*        void timer0()interrupt 1   using 2
   TH0=0XF8;
         TL0=0X30;
         time++;
         pwm_val_left++;
         pwm_val_right++;
         pwm_out_left_moto();
         pwm_out_right_moto();
void forward()
        left_motor_go;
        right_motor_go;
void left_go()
        left_motor_back;
        right_motor_go;
        delay(700);
        forward();
void right_go()
        delay(50);
        right_motor_back;
        left_motor_go;
        delay(700);
        forward();
void left()
        delay(50);
        right_motor_go;
        left_motor_back;
void right()
        left_motor_go;
        right_motor_back;
void back()
        left_motor_back;
        right_motor_back;
void stop()
        IN1=0;
        IN2=0;
        IN3=0;
        IN4=0;
          IN1=0;IN2=0;IN3=0;IN4=0;
          UART_INIT();
                switch(receivedata)
                        case 'g': forward(); break;
                        case 'b': back(); break;
                        case 'l': left(); break;
                        case 'r': right(); break;
                        case 's': stop(); break;
                        case 'z': left_go(); break;
                         case 'y': right_go(); break;
void UART_SER() interrupt 4
  receivedata=SBUF;
        RI=0;
        SBUF=receivedata;
        while(!TI);
        TI=0;
ID:130231 發(fā)表于 2020-5-25 12:02 | 只看該作者
你可用串口助手,在電腦端連接藍(lán)牙測試,在試機(jī)。先測出APP發(fā)出的字符,電腦端能不能收到。如果能收到,在一一對應(yīng)程序中字符。還有的是波特率也要對得上。
ID:687146 發(fā)表于 2020-5-25 12:51 | 只看該作者
main函數(shù)里沒循環(huán),switch跳出一次程序就結(jié)束了后續(xù)單片機(jī)一直執(zhí)行終斷,根本進(jìn)不去switch,把switch丟終斷里因該就可以了,再不行把字母換成16進(jìn)制的數(shù)字。
ID:487151 發(fā)表于 2020-5-25 13:28 | 只看該作者
ID:711376 發(fā)表于 2020-5-25 14:47 | 只看該作者
zqy181818 發(fā)表于 2020-5-25 12:02
你可用串口助手,在電腦端連接藍(lán)牙測試,在試機(jī)。先測出APP發(fā)出的字符,電腦端能不能收到。如果能收到,在 ...
現(xiàn)在是電腦上的串口助手能控制小車,但是只有一個電機(jī)轉(zhuǎn),手機(jī)App還是沒法控制
ID:711376 發(fā)表于 2020-5-25 14:59 | 只看該作者
2538076292 發(fā)表于 2020-5-25 12:51
main函數(shù)里沒循環(huán),switch跳出一次程序就結(jié)束了后續(xù)單片機(jī)一直執(zhí)行終斷,根本進(jìn)不去switch,把switch丟終斷 ...
我剛開始就是給放到中斷服務(wù)函數(shù)中了,現(xiàn)在用電腦串口助手能控制,但是只有一個電機(jī)轉(zhuǎn)不知道是什么情況,我上午已經(jīng)調(diào)過驅(qū)動,兩個電機(jī)都是可以正常運動的,現(xiàn)在的問題就是只有左輪是轉(zhuǎn)的,而且手機(jī)APP和單片機(jī)之間的通信還是有問題。
ID:687146 發(fā)表于 2020-5-25 17:38 | 只看該作者
嘿嘿嘿a 發(fā)表于 2020-5-25 14:59
我剛開始就是給放到中斷服務(wù)函數(shù)中了,現(xiàn)在用電腦串口助手能控制,但是只有一個電機(jī)轉(zhuǎn)不知道是什么情況, ...
單獨調(diào)試一下驅(qū)動模塊,在main函數(shù)里只加上驅(qū)動函數(shù),在設(shè)定好延時,做個循環(huán)看看電機(jī)轉(zhuǎn)動是否正常。
ID:711376 發(fā)表于 2020-5-25 20:11 | 只看該作者
2538076292 發(fā)表于 2020-5-25 17:38
今天上午就搞過了,電機(jī)可以正常運作,然后現(xiàn)在電腦上的串口助手可以驅(qū)動小車運動了,但是手機(jī)APP和藍(lán)牙模塊之間的通信還是沒法建立,不知道是哪個地方的原因。。。
ID:426480 發(fā)表于 2020-5-26 15:16 | 只看該作者
目前經(jīng)過你的描述可以判斷出,你的51程序正常!串口正常!現(xiàn)需要檢查APP和藍(lán)牙模塊通訊的問題,第一:判斷手機(jī)APP藍(lán)牙是否支持、打開,開始搜索、配對、然后進(jìn)行連接。第二:如果第一步成功接著判斷是否手機(jī)藍(lán)牙發(fā)送消息正常。重點:檢查手機(jī)APP藍(lán)牙連接配對,及消息發(fā)送接收程序的編寫。
