直接數(shù)字頻率合成(DDS):主要介紹了采用直接數(shù)字頻率合成DDS芯片實現(xiàn)正弦信號輸出,并完成調(diào)頻,調(diào)幅功能。它采用美國模擬器件公司(AD公司)的芯片AD9851,并用AT89C51單片機對其控制,首先從DDS芯片的輸出,經(jīng)低通濾波得到正弦信號,然后對該信號進行調(diào)頻,調(diào)幅。其中調(diào)頻部分可以通過在軟件中修改DDS芯片的頻率控制字,相位控制字等來實現(xiàn),而調(diào)幅部分需在DDS輸出正弦信號之后外加一調(diào)幅器實現(xiàn)。調(diào)幅部分將DDS輸出作為載波信號,RC振蕩器提供1KHz振蕩作為調(diào)幅信號,它利用了乘法器MC1496完成對正弦信號調(diào)制。該系統(tǒng)輸出穩(wěn)定度、精度極高,適用于當(dāng)代的尖端的通信系統(tǒng)和精密的高精度儀器。 Abstract This article mainly introduced uses the direct digital frequency to synthesize the DDS chip to realize the sine signal output, and completes the frequency modulation, the amplitude modulation function. It uses the American simulation component company (AD Corporation) chip AD9851, and with the AT89C51 monolithic integrated circuit to its control, first from the DDS chip output, obtains the sine signal after the low pass filter,
